Guest two.06l
over the last 3-4 months i have noticed a decline in the quality and consistency in shell optimax fuel.just switched to mobil sygnergy 8000 and the difference is unbelieveable.Able to run more timing and boost without a hint of detonation has this stuff been kept a secret or am i just ignorant of its existence or use.
https://www.sau.com.au/forums/topic/38750-optimax-fuel-quality/
  • Replies 82
It was proven many years ago that optimax was only good for 2 weeks... Before its oct whould drop down to around the 94-93 mark... Making it about the same as regular....
It would be impossible to get pure fresh optimax.... Unless you work for shell and are getting it straight from the 500million litre tanks.......
I noticed the same thing at Eastern Creek on Monday. Took the car for a spin with a tank full of BP Ultimate. At around 3pm I went out to refill at the nearest petrol station (Shell). Went back to the track with exactly the same car settings for a couple more sessions. I noticed that it was running roughly. I couldn't think of anything else other than the Optimax causing this.
while in adelaide i always used bp ultimate, as we dont have optimax. Mobil 8000 isnt as common in SA and we have the idea that it doesnt get much of a turnover so we dont really use that either. When i first brought the car up to sydney i filled it with optimax and i certainly noticed less power plus it just didnt run as clean or strong. So far havent been dissappointed with ultimate.
whats the bottom line with fuel going "off"? in my understanding that would be dropping its octane level. Ive heard that sitting for even a month or 2 can have it go down. Where does this 1 year thing come from?
optimax is a molecule expanded fuel that means they start with 92 ulp and play around (wont go into details, boring stuff) and make it reach 98... whereas mobile and bp fuels are initially refined to 98 octane they are not expanded... thus optimax is more unstable on a molecular level and more vunerable to chemical reactions such as reactions with oxygen, which is evident in the tanker trucks that trasport fuel and even in your fuel tank... optimax thus will only last a month max in your tank before significantly degrading itself...id expect bp to last 9-12 months before the same processes. bottom line optimax is way crappier, but is good if you use it straight away and it freshish off the supplier..
Yep noticed much the same as everyone has previously stated. I had, and I do mean HAD to fill up, and the only fuel that was around was optimax, didn't want to use it but yeah nothing else around, so I decided that I would only put $10 in just to get me to where I knew the next BP was. And I swear that 40min drive was so shitful, the car almost stalled so many times coming up to lights and just ideling at the lights, couldn't work out WTF was wrong only conclusion that I could draw was that the change in fuel didn't agree with my car and tune. Filled up at BP, full tank still ran like a bag of shit for another 15min then cleared up and was sweet. Never using optimax again.
I filled up Optimax only whenever I got that 4c dicsount coupons from Coles (being dirty old, tight ass Thursday petrolhead :)) Shell is on my way home from work
When I have no coupons I went a bit further down the road (100m) for BP Ultimate....
Never pay attention to any differences between the two, but I use up a full tank of Optimax in around 7-10 days anyway so may not feel the effect of the fuel going off before the next refill anyway. Car is my daily driver to work and my shopping cart too.
Also, I found km per tanks is not a difference between BP & Optimax, just a matter of how heavy my right foot is. Turned off my boost controller (stock boost) and drive below 2500rpm since last month, now I refill every 10 days instead of 7 days as I used to be.
Hey, more $$$ for future mods :)
i once used the octane booster, car felt much more smooth
Some brands of Octane booster is known to cause your plugs to foul, causing it not to perform 100% and may lead to engine damage in the long run.
I would stay away from them, unless I really have to use it, e.g. in the outback where no premiums available.
yes, shell is crap. bp is the gear.
imho,
shell opticrap < mobil synergy 8000 < bp ultimate
:werd: Altho I've never been able to notice a more than negligible difference between Mobil 8000 and Ultimate. For some reason I prefer Ultimate tho.
As s13drifter began to explain, the reason to stay away from Opticrap is the fact that they achieve the 98 octance via the use of additives which expand the molecules, rather than refining it for a 98 octane.
    • 2001 BE5D Subaru Legacy B4 RSK (3rd gen) EJ208 (pink injector) Twin Turbo 280PS 5-speed manual Full time 4WD "RSK" grade which means all of the above LQC option which means stock rear spoiler  I got it primarily to export to someone outside Japan who was interested. These BE5 Legacy B4 RSKs are going through a bit of a resurgence right know in Japan as they are one of the few cars from the "turbo, manual, RWD/4WD, 280hp gentleman's agreement era" cars that don't require stupid money to purchase. Which for some people might be a good opportunity to get as a base for restoration. If I can't find anyone to purchase it I will certainly be doing that myself over the long term. Why? Because it's properly fast in stock form, handles well enough for a GT sedan, there's still enough aftermarket and (if you can wait a while) genuine part support to make it a restoration candidate (<-- that will only get worse over time so it's a case of do it now or choose get a BL5 4th Gen). Mechanically it's fine, has only 89,200kms on the odometer. The problem with this car is that the body and exterior trims are weathered from at least the last 10 years being parked outdoors. I'm the 3rd owner, the first owner was the one that had it for 14 years and barely drove it, had a low-speed front impact (which didn't damage anything behind the radiator support) and got it fixed and sold it. The 2nd owner put most of the kms on it and parked it outside for the last 10 years, hence the door rubbers have seen better days but if you overlook those cosmetic details, it presents pretty nicely. There is some minor rust on the LH rear wheel arch which I'll have looked at too at some stage.  Also as you'd expect from a car this age, the clear top coat is gone, leaving a satin finish on the roof.  Mechanically it's fine (as you would expect from a car with less than 100K kms) but the steering does feel slightly vague around the centre position at higher speeds. So first on the list is to get the steering rack bushes looked at. There's also the Lock button on the remote which doesn't work, but the Open button does.... it means that the anti-theft system thinks it's always open? It seems like if you open the car and don't start the engine within 3 mins or so the anti-theft kicks in again without any beeps or signals. So if you got to start it after that, it won't. You have to push the open button again. That's how I understand it anyway. Just a small irritation but not a big problem to sort out. There's only one mod, the Wangan SPL muffler. Just a tad louder than stock. It's a really good mod for those who don't want to wake the neighbours but still want to hear a more prominent unequal length header EJ20 sound. Anyway I hope to get all those things done eventually, that is unless someone wanted to import it to their country from Japan (where I live). I'm open for negotiations as I really would like a Skyline... but this will definitely suffice in the meantime 🙂 *Disclaimer: This is how I picked it up from the dealer, minus the stuff on the back seat. I haven't cleaned the engine bay or done a thorough exterior clean, aside from spray painting the wipers.
    • Wow, even with the Audi logo centre caps. I love OEM wheel mismatches.
    • Welcome!  Can't go wrong with a Stag.
    • Looks good. Nice height.
    • Hey all, a little help from the Stagea hive mind plz.. I'm days away from buying either a 2002 Stagea 250tRS AR-X Four, premium leather, power seats and all the old switches etc that go with it, or a 2002 Stagea 250tRS VR-X Four AERO, pov pack, cloth seats etc, with coil overs, sports zorst, comes with original zorst and suspension and parts. (I think I've got the models right?) Both are VQ25DET, have 160000kms, both straight no rust both with $2000+ in recent servicing receipts, both ride on aftermarket 18" rims. The Aero has a replaced turbo as well. I like the cool factor of the Aero car but the AR-X has never been modified. Neither have been driven hardly at all in the last 5 years. Any thoughts on which one or does it come down to personal preference? davemoto
