I feel ripped off reading this :closedeyes:
I thought this was the end result thread lol... Guess we wait 2 more weeks :D
I'm with a few others, not so sure the -9s will hold 28-30psi. They generally always fall over so very keen to see end result
If they dont hold till top end, it will have a big fat meaty midrange :thumbsup: .
i hate to nit pick but 'Eflex' is Caltex's higher % ethanol blend, 70-85
'Flex-fuel' is the ability to run anything from 100% unleaded to 85% (or whatever your highest E%) ethanol. I know you knew what you were referring to, but just to save other people the confusion.
Fantastic to see more people getting in on it though!! More ethanol users the better!! Get on it people!! :D
Ethanol fuels are fantastic for turbos that are maxxed out on 98. On my rb25 with hks gtrs size turbo so ~245rwkw on 98 fuel maxxed out, then I changed to the caltex eflex fuel and made 280rwkw with even more response!
Ethanol fuels work very well on the smaller turbos that appear to be maxxed out on 98. Go for it!
for the people that have done flex fuel setups using decent boost levels
are your 98 or close to maps just done with a lot of timing pulled out or is the boost dependant on ethanol%? assuming any of the ecus support that kind of setup?
boost same, timing varies.
depends how you think of it... i think of it as timing at '0' (rather than negative) for the 98 map, which is then advanced depending on the ethanol %.
different parts of the map obviously vary in how much the timing is advanced but don't worry about the 98 map as i'm assuming that's already been sorted for most people as that's their fuel of choice.
really? i would have thought the boost would be lower if your e85 % is lower...
e.g. if i have 100% 98 then I'd expect to run 22psi or so... anything higher could possibly cause big problems....
will check with the Tuner tomorrow on this....
evc 6 i set at 21psi i think, 98 or E85, it's all the same :)
we believe the pistons are N1's, so not fully forged (not 100% on this, will have to try and confirm with Midori one day...) so i'm never going to run stratospheric boost and i didn't think running Eflex/E85 will help much in that department anyway.
if we were going with variable boost, then that would have to be controlled via the G4 i'm assuming... i don't know if this requires extra hardware/extra Link kit etc...
and even if we could, i don't know if i would run extra boost on Eflex/E85... why? i've got all the extra timing over 98, in the 400rwkw for pure E85, ~650nm of torque... don't see the point of stressing the engine anymore to be honest... it's not like it's underpowered :banana:
aaah
your situation is different to mine i guess... i got tiny -9s so I want to cram as much boost through them as I can to make the power lol
I just spoke to Chea and he confirmed that my boost will also vary depending on the ethanol percentage in the tank
Boost, Fuel & Timing will all change accordingly to ethanol %
mine is getting a Haltech boost solenoid so the boost will be controlled by the Haltech ECU too
oookkk bit of a hiccup
gave a hit in 2nd and went for 3rd and the gearbox went BANG!
no more 3rd gear :( box is goooonnneee
anyone in sydney have a GTR box for sale??
if i dont get one by the weekend I'm going to have to push the mods back
    • For once a good news  It needed to be adjusted by that one nut and it is ok  At least something was easy But thank you very much for help. But a small issue is now(gearbox) that when the car is stationary you can hear "clinking" from gearbox so some of the bearing is 100% not that happy... It goes away once you push clutch so it is 100% gearbox. Just if you know...what that bearing could be? It sounding like "spun bearing" but it is louder.
    • Yeah, that's fine**. But the numbers you came up with are just wrong. Try it for yourself. Put in any voltage from the possible range and see what result you get. You get nonsense. ** When I say "fine", I mean, it's still shit. The very simple linear formula (slope & intercept) is shit for a sensor with a non-linear response. This is the curve, from your data above. Look at the CURVE! It's only really linear between about 30 and 90 °C. And if you used only that range to define a curve, it would be great. But you would go more and more wrong as you went to higher temps. And that is why the slope & intercept found when you use 50 and 150 as the end points is so bad halfway between those points. The real curve is a long way below the linear curve which just zips straight between the end points, like this one. You could probably use the same slope and a lower intercept, to move that straight line down, and spread the error out. But you would 5-10°C off in a lot of places. You'd need to say what temperature range you really wanted to be most right - say, 100 to 130, and plop the line closest to teh real curve in that region, which would make it quite wrong down at the lower temperatures. Let me just say that HPTuners are not being realistic in only allowing for a simple linear curve.
    • I feel I should re-iterate. The above picture is the only option available in the software and the blurb from HP Tuners I quoted earlier is the only way to add data to it and that's the description they offer as to how to figure it out. The only fields available is the blank box after (Input/ ) and the box right before = Output. Those are the only numbers that can be entered.
    • No, your formula is arse backwards. Mine is totally different to yours, and is the one I said was bang on at 50 and 150. I'll put your data into Excel (actually it already is, chart it and fit a linear fit to it, aiming to make it evenly wrong across the whole span. But not now. Other things to do first.
    • God damnit. The only option I actually have in the software is the one that is screenshotted. I am glad that I at least got it right... for those two points. Would it actually change anything if I chose/used 80C and 120C as the two points instead? My brain wants to imagine the formula put into HPtuners would be the same equation, otherwise none of this makes sense to me, unless: 1) The formula you put into VCM Scanner/HPTuners is always linear 2) The two points/input pairs are only arbitrary to choose (as the documentation implies) IF the actual scaling of the sensor is linear. then 3) If the scaling is not linear, the two points you choose matter a great deal, because the formula will draw a line between those two points only.
