he is such a good guy... didnt think he would still remember me
told him the issue and he did say the problem I have is one that could occur due to valves.. although he did say that valve problems are pretty rare
he also said he had a method of determining whether it is actually the valves without opening the head!
so will def be getting the car looked over by him (not sure if i should tell PT though)
was going to call him tomorrow but he called me lol... was very impressed! should have just gone to him again lol
Edited by usmair
I might have misinterpreted him
i think he meant due to the cost involved in changing springs... it might be financially better to 'do' the head (if i wanted to) seeing as we're spending $ on labour regardless
I can understand this, a full reco'd head might be better value than doing just the springs on your head. Though you'd want to make sure it was a reputable company that supplied it.
Usually valve float occurs at a resonant point in the rev range meaning that the power falls away momentarily. You usually see the mixtures do weird things at that point as the exhaust valve stays open longer.
If your exhaust back pressure is high you will usually float the exhaust valve on a turbocharged car given the profiling of the inlet is similar to the exh.
Does the power stay on higher at lower boost levels?
Tuner said power isnt falling momentarily... it just starts to lose power consistently after 6300RPM... its not like it temporarily loses power then jumps back up :S
the back pressue shouldnt be an issue... its got big front pipes and a 3.5" exhaust
the power is staying similar thought! it made 317kw on 22 psi with a boost leak under the plenum from a gasket
what does that suggest?? (sorry complete noob here)
he didnt mention anything about knocking... just seems to be stuck at 320kw
Which makes it sound more like a flow issue, and not exhaust side as that tends to send temps up and hence detonate.
Which leaves valves, intake, leaks??, turbo, cam timing etc.
"peak power right now is at 6300... car just starts struggling to breath and loses power"
Sounds like an exact thing i had.. Drop a set of Tomei TypeB 9.15mm in. Ignore what everyone says about running standard cams and try again and you won't live to regret.
Everyone is always talking highly of Unigroup but i find the car's he tunes runs quite low power and they are only in RWD/2WD? Too safe of a tune perhaps? Who knows...
can you please provide further details of your situation?? even the tuner said standard cams are perfect for -9s
yeh Yavuz only has a 2 wheel dyno so readings are in RWD... he does tune them to last so they might be slightly lower in power perhaps...
    • Then, shorten them by 1cm, drop the car back down and have a visual look (or even better, use a spirit level across the wheel to see if you have less camber than before. You still want something like 1.5 for road use. Alternatively, if you have adjustable rear ride height (I assume you do if you have extreme camber wear), raise the suspension back to standard height until you can get it all aligned properly. Finally, keep in mind that wear on the inside of the tyre can be for incorrect toe, not just camber
    • I know I have to get a wheel alignment but until then I just need to bring the rear tyres in a bit they're wearing to the belt on the inside and brand new on the outside edge. I did shorten the arms a bit but got it wrong now after a few klms the Slip and VDC lights come on. I'd just like to get it to a point where I can drive for another week or two before getting an alignment. I've had to pay a lot of other stuff recently so doing it myself is my only option
    • You just need a wheel alignment after, so just set them to the same as current and drive to the shop. As there are 2 upper links it may also be worth adding adjustable upper front links at the same time; these reduce bump steer when you move the camber (note that setting those correctly takes a lot longer as you have to recheck the camber at each length of the toe arm, through a range of movement, so you could just ignore that unless the handling becomes unpredictable)
    • I got adjustable after market rear camber arm to replace the stock one's because got sick of having to buy new rear tyres every few months. Can anyone please let me know what the best adjustment length would be. I don't have the old ones anymore to get measurements. I'm guessing the stock measurement minus a few mm would do it. Please any help on replacing them would be fantastic I've watched the YouTube clips but no-one talks about how long to set the camber arm to.
    • Heh. I copied the link to the video direct, instead of the thread I mentioned. But the video is the main value content anyway. Otherwise, yes, in Europe, surely you'd be expected to buy local. Being whichever flavour of Michelin, Continental or Pirelli suits your usage model.
