lol now now fellas
this was suppose to be 10k build... that 10k has already been spent and ill ive ended up with is 320kw and another broken box haha
ah well... it is what it is...
now the issue is what to do...
get another 33 box (which I can get for $500) + plus install and whack that in and drive like a pussy for the rest of my life
or fork out 4-5k for a OS/PPG gearset
cost vs benefit really
How many boxes will you do till you put a 'big box'
In? If you do 4, you're half way there and are still stuck with a standard box. You shouldn't be busting them with the power you have UNLESS you have no mechanical sympathy!
I say do it and do it properly. Costs less in the long run!
They can either work for or against you. At Huntley it really works. You just need a bigger engine to turn the cogs. *hint hint, nudge nudge* ;)
I got something in the pipe line.... hahaha a few more months mate
http://www.rhdjapan.com/os-giken-close-gear-kit-3-speed-nissan-rb26dett-input-shaft-50042
its 1st, 2nd and 3rd that cop the abuse so it would be perfect right?
thoughts?
Well that would be the same as mine as I decided to go for OEM 5th gear for highway.
That's about 3K? Try greenline.
What clutch?
That is often the cause of broken boxes.
I've got 360rwkw or so, and I can launch from 8000rpm with sticky tyres, smack second - no problems. Even flat changing 3rd-4th wasn't a problem... Run after run.
Anyone @ Drag Battle can verify :)
Not sure now.
I bought my 5 speed with big input shaft for $2,760 delivered from greenline 4 years ago. You will need all the Series 3 internals to run it.
Make sure you buy the billet centre plate from OS.
I have a spare OSG billet centre plate here ;)
Or a Trust/Quaife H-pattern dog box. :whistling:
changing gears easier would save you 5k
cost benefit ratio for you being nicer to your car is very high, and would allow you to be quicker at the strip.... as you would get to the end
lol
yeah but fatz he wants to chirp second
    • Ok thanks..that was my second question if i can somehow bypass this even with Nistune(that is all i have right now...aparat from stock ECU. So with some aftemarket it can by "bypassed" or make it work?  I know there is Link or Haltech (mainly used). We have ECUmaster here so i will gather some info about it.
    • Yes. You will need to get the original boost sensor and wire it in. That is.... if you plan to use a stock ECU - even a Nistuned ECU. The Nissan ECU will not operate correctly without it connected. And yes, it will do annoying stuff like you are experiencing. You will almost certainly be better off with some aftermarket ECU, than trying to hunt down rare sensors.
    • Ok so ABS/TCS is "not" the problem. Yeah i know now about the ABS with Nistune(i told that to the Nistune guy) but iam not 100% why or why i dont have ABS. ABS cube is in the engine (always has been) but i had braked couple of times rly hard and brakes just locked and scream. Does all Skylines have ABS cube? That boost sensor https://www.sau.com.au/forums/topic/367633-wtb-r34-gtt-turbo-pressure-sensor-pics-inside/ Is this it? I need to ask but i have a picture of engine bay and i do not see that (100% is not in that place) If i do not have this the car can do what mine is?(cutting around 4000 rpm) Here is the pic of my engine bay(only one i have) BUT i think i dont have that cuz loom was used from my RB20DE NEO and i know (obviously) that it does not have boost control or any wire to that...) so maybe that is the problem? (i dont know for 100% if that car where the engine is from had that)...but i dont have the loom from that
    • I'm with you here. It's either loom has an issue, OR, injectors are not functioning properly. It could even be they're just constantly dribbling, hence the wet, but not firing.
