Spool RB32 Stroker Kit
Coming Soon
SPOOL RB30 91mm Stroker Crank Kit
Nissan RB30 - RB32 Stroker Kit:
  • SPOOL Billet 4340 full counter weight 91mm Stroker Crankshaft
  • SPOOL I Beam Forged Conrods with L19 Bolts
  • CP Custom Pistons
  • 9310 Gudgeon Pins (4.5mm wall thickness)
Sawwwce ;)
Discuss.
https://www.sau.com.au/forums/topic/388487-spool-rb32/
I see your RB32 and I raise you an RB34:
http://spool.directf...roker-crank-kit
FACEPALM!
If only there was more than one RB34 thread on this forum...
Will be interesting to compare This kit to Nittos kit.
Edited by 045HOW
https://www.sau.com.au/forums/topic/388487-spool-rb32/#findComment-6192172
FACEPALM!
It would be very interesting to compare. Nitto's 3.2l kit costs a lot more than the spool 3.4 atm. Has anyone actually compared any of the spool products alongside the nitto items to compare quality and watnot?
https://www.sau.com.au/forums/topic/388487-spool-rb32/#findComment-6192773
yea thats what i was getting at... it probably comes from the same bread shop like 90% of the gear on the market
which means price war!
https://www.sau.com.au/forums/topic/388487-spool-rb32/#findComment-6194220
FACEPALM!
Apologies I thought you were unaware of the rb34 kit and had just noticed the rb32 kit.
Why would you choose the rb32 over the rb34? Cheaper? Rev higher?
https://www.sau.com.au/forums/topic/388487-spool-rb32/#findComment-6194708
I presume its cheaper. The longer the stroke the higher the piston speed at a given rpm so I guess the 32 is less stressed.
https://www.sau.com.au/forums/topic/388487-spool-rb32/#findComment-6195150
Well side by side won't tell you much other than the sizing/weight with things like rods etc.
Need to actually properly test it, install it, drive it etc.
Unfortunately there are little results around even after a bit of time :(
https://www.sau.com.au/forums/topic/388487-spool-rb32/#findComment-6195183
Totally understand where you're coming from but the cost of manufacturing a 91mm crank compared to a 94mm crank is so small it's not worth mentioning. I'd take a gamble and say the pricing will be the same as the 3.4 RRP. Any cheaper is ripping himself off, as long as it's cheaper than Nitto he shouldn't have a drama selling them
https://www.sau.com.au/forums/topic/388487-spool-rb32/#findComment-6195202
as r31nismoid said unless there is back to back comparission the only differences would be price,
i still am yet to personally see an rb34 spool kit, seen plenty of nitto r32 (probably as nitto is local in sydney and spool is qld i think)
though the customers have said they bought the 90mm stroke as they think the 95mm stroke would be an over stroke for their application,
which is along the lines of what r33_racer was saying, all depends on what the motor is going to be used for will depend on which crank is best
plus spool appear to use cp pistons
nitto use JE/SRP
(which the cp workers used to work at JE/SRP before starting their own company, so end of the day same piston quality)
in theroy the benifits/ differences i can notice other then the srokes;
nitto cranks have slight knife edging and the rods with big end oil squirters
spool cranks from what ive seen in pictures/ read are fully counter weighted aka gives the crank more throw (encourages it throw itself in the rotating directing)
https://www.sau.com.au/forums/topic/388487-spool-rb32/#findComment-6198259
I think it's more a case of there were a few NITTO strokers getting around early on. No doubt via reduced pricing for market penetration by a few places etc.
Yet the SPOOL RB34 results really haven't been seen anywhere or in at least volume of half a dozen type thing.
Understand the in-house goes first as you can't really sell something that's going to mince itself due to poor materials or something, but it's taking really long?
https://www.sau.com.au/forums/topic/388487-spool-rb32/#findComment-6199340
once again never seen a jun stroker crank, which after googling looks like a full counter weighted crank too (bout all i can tell)
seen a few normal 26 and N1 26 cranks, 2.8 HKS cranks, fair few nothing special rb30 cranks and nitto 3.2 cranks, would like to see more variety but all depends on our cutomers, plus once the machining is done most the time we rarely hear of any results
https://www.sau.com.au/forums/topic/388487-spool-rb32/#findComment-6199924
    • Yeah, it's getting like that, my daughter is coming over on Thursday to help me remove the bonnet so I can install the Carbuilders underbonnet stuff,  I might get her to give me a hand and remove the hardtop, maybe, because on really hot days the detachable hardtop helps the aircon keep the interior cool, the heat just punches straight through to rag top I also don't have enough hair for the "wind in the hair" experience, so there is that....LOL
    • Could be falling edge/rising edge is set wrong. Are you getting sync errors?
    • On BMWs what I do because I'm more confident that I can't instantly crush the pinch welds and do thousands of USD in chassis damage is use a set of rubber jacking pads designed to protect the chassis/plastic adapter and raise a corner of the car, place the aforementioned 2x12 inch wooden planks under a tire, drop the car, then this normally gives me enough clearance to get to the front central jack point. If you don't need it to be a ramp it only needs to be 1-1.5 feet long. On my R33 I do not trust the pinch welds to tolerate any of this so I drive up on the ramps. Before then when I had to get a new floor jack that no longer cleared the front lip I removed it to get enough clearance to put the jack under it. Once you're on the ramps once you simply never let the car down to the ground. It lives on the ramps or on jack stands.
