  • Replies 177
Tie rod ends are the same as ball joints, right?
If so, ring Nissan, they can organise those for you.
Otherwise do what I suggested before when you PM'd me, and search.
People here are happy to help, but you have to try and do some research.
Searching for ball joints found my thread from two months ago, and also enlightened me on my irritating wiper problem. Awesome!
And not sure where that relay was, but looks like the 4WD relay to me.
Tie rod end is on the end of the steering rack, the ball joint is on the ends of both the upper and lower control arms linking the hub upright together.
Ball joint go with what Ryan found in his topic, as for the tie rod end go to Nissan.
have had a search on the relay, cant find what it is only that its a bracket relay. will ring nissan tomorrow and see if they can find it out
(25233M)
http://nissan.epcdat...ric/252/25233M/
found this too where i can order it,
http://www.amayama.c...37AL800&cur=AUD
Edited by adambruv
ill buy the 2 lights, just in case one side is better quality, if so i can put both in and both sides will look the same :)
thanks for your help mate!
for postage ill go EMS/AIR
what postage would i pick ? b or c ?
thanks
Two headlights via EMS will be around $200... from experience :(
gave main north nissan a call about the relay, they couldn't even tell me what it done, only that they could get 1 for $150 in japan, 2-3 weeks wait, going to a couple of wreckers on friday, see if i can get me one :)
Is this a build thread or a repair thread? Are you just fixing this up to be a nice daily or do you want it to be unique?
If it's the latter, rip off the flares, find an aero bar and fit some aftermarket overfenders. :banana:
Granted these examples are not a M35, but you may get the idea...
What I'm getting at though, is that if you're planning on modifying it you may be able to save some decent coin in the long run by just getting it on the road, looking however it does, and then using overfenders instead of the standard stuff..?
but wont buying 4 overfenders cost more than buying one standard flare?
    • Have a look at that (shitty) pic I posted. You can see AN -4 braided line coming to a -4 to 1/8 BSPT adapter, into a 1/8 BSPT T piece. The Haltech pressure sender is screwed into the long arm of the sender and factory sender (pre your pic) into the T side. You can also see the cable tie holding the whole contraption in place. Is it better than mounting the sender direct to your engine fitting......yes because it removes that vibration as the engine revs out 50 times every lap and that factory sender is pretty big. Is it necessary for you......well I've got no idea, I just don't like something important failing twice so over-engineer it to the moon!
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
