  • Replies 177
Any chance you can give us a break down of the cost to buy and deliver the front bar?
sure mate
Item Name:M35 Stagea Front BarBid
Shipping Method:Sea / ContainerDelivery
Shipping Category:C
Item Cost: 14,800¥
Japanese Domestic Freight: 4,000¥
Import Monster Commission: 2,960¥
Total Japan Costs: 21,760¥
Exchange Rate: $1AUD buys: 80¥
Import Duty: 740¥
Container Freight Cost:$125.00
Australian Domestic Freight: $70.00
Sub Total: $476.25
GST: $47.63
Total: $523.88
Edited by adambruv
Just a quick question regarding your car's flares. Given your car started life as an ARX, are they ARX flares or Axis flares? I think the overall shape of both are the same, but the main difference is that Axis flares have a rubber gasket that goes between the fender and the plastic flare - you can just make it out in the image below. My guess is that because the Axis flares are painted, the gasket stops vibrations between the flare and body that would otherwise cause the paint to chip on the flare (ARX flares being usually unpainted). I assume you have ordered the black Axis fender from eBay. Hopefully the gasket on a black Axis is not black (It's hard to tell in the second image) as that will stand out on your lighter coloured car.
web.jpg?ver=13284022090001web.jpg?ver=13284022100001
For what it's worth, I reckon when it's finished it will look great. A gold Axis will be very unique - unless the one below is not yours in pre-accident days, in which case it won't be so unique biggrin.gif.
web.jpg?ver=13284032700001
oh wow, does the number-plate say synergy motorsport ? if it does thats the same car :D
i still need the chrome on the bonnet and also another grill, anyone able to help out ? :)
thanks
Edited by adambruv
  • 3 weeks later...
350Z parts?
oh.... when my car was new, it failed the Vic roadworth on the drivers side tie rod... Ben at Northshore sorted out the parts, but they were the 350Z part, plus a conversion kit for M35.. Extra packet in the package.
Cool down pplz..... Valium and redbull for all
Josh, is that the same Valium that gets rid of the cigarette smoke smell from your car?whistling.gif
http://www.skylinesa...ost__p__6242922
Edited by HER_M35
    • You know how your car rolled through a fence in your last jacking escapade? Scissor jacks increase the likely hood of that sort of thing happening immensely!
    • http://calfinn.com.au/product/1500kg-standard-trolley-jack-cj-2t-c/1500kg-standard-trolley-jack-cj-2t-c   I have this and fits under a S3 33 GTR with no issues. Purchased in 2009 and not one issue. It was $950 back then. Not cheap but something so important isn’t worth cheaping out on.
    • Just trying to get my head around this. At 5psi of boost, you turn on your wmi pump, and then you're using a 3000cc injector, to allow flow upto the actual engine, where you have your 6x200cc injectors and a 500cc injector. If the above is correct, what advantage are you obtaining by having the 3000cc injector blocking flow, is this just incase a line breaks between that injector and the motor you can stop flow immediately? Or are the 6x200cc and 500cc less injectors and just spray nozzle?
    • Welcome! New member myself, but I had an R33 back in 2002. Best advice I could give, based on my experience: if you're running the factory turbo, be very conservative with boost. I made the mistake of just fiddling around with the boost controller and cranking the boost for fun, and the end result was my intake pipes popping off frequently from the constant deluge of oil that was being blown into the recirc by the stressed-out turbo, which itself was siphoning oil from the engine and farting it out both sides of its centre bearing (or something to that effect). If I could do it all again, I would have gotten a new turbo and had a tune dialled in professionally and then just left it alone! Funny you mention the metal shavings in the gearbox, as I had the same thing - the probe plug (magnetic drain plug, essentially) would come out caked with shavings. At least it was doing its job. Not sure if that's just sacrificial wear and part of the deal, or if my gearbox was shagged, but I wasn't abusing it. Enjoy the R33 - they're a dying breed, and if they weren't $35k+ on CarSales in Queensland, I might have picked up one of those again, instead of the 370GT I own now (though I'm loving the 370GT, that big 3.7L V6 just hits different).
    • Howdy folks. I owned an R33 back in 2002, which was thoroughly beyond my capacity (financially speaking) to maintain/insure, so we parted ways in 2004. Fast forward 21 years (to literally yesterday, in fact) and I'm now the proud owner of a 2007 V36 370GT. I'm happily surprised by how much power the VQ37VHR makes, compared to the RB25DET, considering the latter is turbocharged. I had planned to add a turbo at some point but I'm on the fence about whether I'll even need it (though I do love the sudden onset of extra torque). Any other 370GT owners around the traps, I'd love to hear about your experiences with this car (good and bad).
