  • Replies 87
HE checked it all its pretty easy to check as he has the afm in the cooler piping
so he is checking it to make sure its all good
looks pretty perfect cant complain for the price as it didnt cost extra to bolt on and made the same power less 3-4kw of his gt3071
i ran a poorly built monsta t3 about 5 years ago lasted 3 and a half yeaers on 17psi before i sold the car and upgraded ive seen alot of people run turbos off ebay there seems to be more people having problems with cheap inlet manifold and highmounts over turbos
but this turbo doesnt look like many people on here have tried it YET :)
It sounds too good.
He bought an eBay turbo, with a tune for a completely different turbo, bolted up perfectly and ran it, WITHOUT TUNING IT, and made 260rwkw. That is more power than I am making at the moment with a bigger turbo, more boost and a full tune.
he has been giving it a really hard time and no signs of wear of shaft play YET but we will wait and see
lol @ checking for wear and shaft play after less than 24 hours of it being installed... :rofl2:
MOST AWESOME POST EVER ON SAU. Nearly pissed myself laughing
Yet he's considering spending what will likely end up being ~$700 on a temp turbo?
WTF?
Cutting spending on education clearly isn't working. Then again, someone has to fit my tyres....
It sounds too good.
For the moment, have to call bulls***, as much as i'm for a good cheap deal, this one seems too cheap and too good, and the graph looks like it was done with excel....
If he's actually done it, f*** yeah and well done. full tune and more boost should make ~300rwkw? Good work.
hahaha excel i dont even know how to use word lol
its all legit nothing has been done to alter the reading its a real dyno read from his car with this $400 bolt on turbo
i guess everyone can say what they like at the end of the day its not my car
he wanted to test it and its proven to be really good
y dont others off here try the same if you doubt it
after all its only $400 and could always sell the turbo to the guys on calaisturbo or r31 club
i wonder who else s face palming them selves arfet a 400 turbo tuned for a different turbo makes decent power
    • I'm looking for some real world experiences/feed back from anyone who has personally ran a EFR7670 with a 1.05 exhaust housing or a .83 I'm leaning towards the .83 because its a street car used mostly for spirited driving in the canyons roads. I"m not looking for big numbers on paper. I want a responsive powerband that will be very linear to 8000 rpm. I dont mind if power remains somewhat flat but dont want power to drop off on top. The turbo I've purchased is a 1.05, although the mounting flange T3 vs T4 and internal vs external waste gates are different on both housings, I not concern about swapping parts or making fabrication mods to get what I want. Based on some of the research I've done with chat gpt, the 1.05 housing seems to be the way to go with slightly more lag and future proofing for more mods but recommends .83 for best response/street car setup. AI doesn't have the same emotions as real people driving a GTR so I think you guys will be able to give me better feed back 😀
    • Surely somebody has one in VIC. Have you asked at any shops?  Is this the yearly inspection or did you get a canary?
    • This is where I share pain with you, @Duncan. The move to change so many cooling system pieces to plastic is a killer! Plastic end tanks and a few plastic hose flanges on my car's fail after so little time.  Curious about the need for a bigger rad, is that just for long sessions in the summer or because the car generally needs more cooling?
    • So, that is it! It is a pretty expensive process with the ATF costing 50-100 per 5 litres, and a mechanic will probably charge plenty because they don't want to do it. Still, considering how dirty my fluid was at 120,000klm I think it would be worth doing more like every 80,000 to keep the trans happy, they are very expensive to replace. The job is not that hard if you have the specialist tools so you can save a bit of money and do it yourself!
    • OK, onto filling. So I don't really have any pics, but will describe the process as best I can. The USDM workshop manual also covers it from TM-285 onwards. First, make sure the drain plug (17mm) is snug. Not too tight yet because it is coming off again. Note it does have a copper washer that you could replace or anneal (heat up with a blow torch) to seal nicely. Remove the fill plug, which has an inhex (I think it was 6mm but didn't check). Then, screw in the fill fitting, making sure it has a suitable o-ring (mine came without but I think it is meant to be supplied). It is important that you only screw it in hand tight. I didn't get a good pic of it, but the fill plug leads to a tube about 70mm long inside the transmission. This sets the factory level for fluid in the trans (above the join line for the pan!) and will take about 3l to fill. You then need to connect your fluid pump to the fitting via a hose, and pump in whatever amount of fluid you removed (maybe 3 litres, in my case 7 litres). If you put in more than 3l, it will spill out when you remove the fitting, so do quickly and with a drain pan underneath. Once you have pumped in the required amount of clean ATF, you start the engine and run it for 3 minutes to let the fluid circulate. Don't run it longer and if possible check the fluid temp is under 40oC (Ecutek shows Auto Trans Fluid temp now, or you could use an infrared temp gun on the bottom of the pan). The manual stresses the bit about fluid temperature because it expands when hot an might result in an underfil. So from here, the factory manual says to do the "spill and fill" again, and I did. That is, put an oil pan under the drain plug and undo it with a 17mm spanner, then watch your expensive fluid fall back out again, you should get about 3 litres.  Then, put the drain plug back in, pump 3 litres back in through the fill plug with the fitting and pump, disconnect the fill fitting and replace the fill plug, start the car and run for another 3 minutes (making sure the temp is still under 40oC). The manual then asks for a 3rd "spill and fill" just like above. I also did that and so had put 13l in by now.  This time they want you to keep the engine running and run the transmission through R and D (I hope the wheels are still off the ground!) for a while, and allow the trans temp to get to 40oC, then engine off. Finally, back under the car and undo the fill plug to let the overfill drain out; it will stop running when fluid is at the top of the levelling tube. According to the factory, that is job done! Post that, I reconnected the fill fitting and pumped in an extra 0.5l. AMS says 1.5l overfill is safe, but I started with less to see how it goes, I will add another 1.0 litres later if I'm still not happy with the hot shifts.
