what about torque, even if your making over 300kw's , what about how much torque? thats what puts you in the seat right?? 700nm here people lol :thumbsup: cock swinging time lol
Edited by SliverS2
Hub dynos can read actual torque figures. actually they will calculate both tractive effort and engine torque.
34GeeTeeTee: its interesting to compare my previous set up with yours.. similar in some ways!
heres mine.. shows calculated engine torque. went bloody hard when it was like this. im kicking myself for changing to the short runners and rb26 head set up
