In-car video showing the 34 boosting hard on full boost or its not true? Nah man but Im sure we would all love to see
When I get the boost controller sorted and I can
Find an appropriate "private road" or track :yes:
At the moment I haven't kept the throttle down long enough to enjoy, once it starts getting loose in 3rd I back off... Need better rubber for sure
ku36 tyres arent that bad, what width are they on the rear?
265.... Either KU36, RS-Rs or Achillies 123s.... Just cheapies as they won't last long anyway :D
don't waste your $$$ on KU36
they are pretty decent for what they are but kuhmo have increased their price in the last 12 months and you can get Nittio NT05's or Federal RSR for less.
imho for a street car go with the Nitto's or if you can stretch the wallet grab some advan AD08's
I usually run the NT05's all round and with my suspension setup they give me effortless traction in 2nd right up to about 310rwkw (e85 on 16psi) - beyond that i need to think about what i'm doing
+1 for AD08's, great tyre. Once they get the heat into them they are awesome
I'm using 265/35R18 RS-R's on the back and they only just manage to grip 2nd with 280rwkw and a toight like a toiga diff (shimmed).
Have you tried them out at Barbs dude? I found my KU36's are ok on the street, but they really come alive when you get some heat into them on the track.
Thanks mate... Will hopefully get it sorted before Texi...
360kw was the highest run... It was run @ 357kw on the final tune for safety... The reason for the different power figures is the 3 boost levels and also the % of ethanol.... My power ranges from 311kw to 357kw depending in boost and E content :)
Hope that makes sense?
Do you have a dyno sheet, or did I miss it ?
Don't KU36s last longer than RSR though? I know RSR is a more grippy tyre but they really don't last.
Edited by Rolls
The KU36's have a treadwear of 180, the RSR's are 140. So not a huge difference. I know my KU36's lasted about 1 track day and maybe 8000km's, so they don't last either.
What type of driving would that be, around a track ?
would they last longer with normal street driving and occasional short blasts?
I drove it hard at the track and spun out on a couple of occasions, so I have no doubt that took off a fair chunk of life. But I only got in 10, maybe 12 laps. On the street I drive pretty sedately with the odd 1st, 2nd, 3rd bursts. So they don't last very long, but no doubt without the track abuse they would last longer.
I think you'll find that if you don't destroy the compound on the tyres by tracking them hard, doing skids, etc. etc. then they would last a fair bit longer. But I'd be surprised if you got more than 15-20k km's out of them.
I have KU 36 on the front, but they sat for 2 years so maybe hard now? They gripped real well compared to other tyres.... Was happy with them. I have some shit sumitomo or something on the rear hence why I have no grip....
Rolls - sorry mate, I have 4 dyno sheets, just haven't had time to scan them.... I have 98 sheet, gate pressure E85 vs 98, low boost E85 vs 98 and then just high boost on E85.... Will get them
In here and in the RB 25 thread soon.... Sorry over been slack :)
Oh dont be soft mate thats when it just starts getting fun when ya doing 130km/h in 3rd and the rears start breaking loose :nyaanyaa: (even though they are only nankangs) lol Looking forward to checking your setup out at texi next weekend dude sounds like a sweet setup :banana: Hoping my big brakes are gunna be on my car by then too and possibly some semis lol
Haha come say g'day and have a look :) plumb back and low boost will be like light beer through a straw.... But, what can you do :(
For sure dude I might have to wind down the boost too im a track/witches hat amatuer so see how i go lol :whistling:
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
