yeah my bro in law ended up in hospital after too many rockstars, and another mate had to have meds for heart palpitations caused by an excessive red bull intake..But fark Trev, my best was Melbourne to Rockhampton in about 22hours solo. But you have smashed that..well done..
Though I have heard the western red bull is something special ;)
Yeah I prob wasn't far off those blokes on the trip over. My heart wanted out of my chest.was surprisingly calm behind the wheel but a fruit loop when getting fuel etc. I couldn't write my details when I arrived at the hotel and had to get reception to do it for me. Was the only time I've had more than 2 at a time.
Anyways not relevant to thread. Back on topic.
  • 1 month later...
May I join?
R32 GTST
Stock RB25DET
Kando T67 10cm
Tial 44mm Wastegate
6Boost exhaust manifold
3" exhaust with single muffler
Random FMIC
Freddy Plenum
Bosch ID1000 injectors
Turbosmart FPR800
Walbro 400lph E85 compatible running E85
Splitfire Coilpacks
post-32498-0-35033400-1346680949_thumb.jpg post-32498-0-15284200-1346681004_thumb.jpg
  • 7 months later...
mods: Stock Plenum, Stock Manifolds (Intake and Exhaust), Stock airbox w/ Trust Greddy Panel Filterz32 w/ Tomei Plug, Metal Intake Pipe 3" to 4", Blitz Return Flow Intercooler, Garret GTX3076R IW 0.82, Custom Dump/Front to Highflow 3" Metal Cat, Stainless Steel Catback to Apexi Active Tail Silencer. Splitfires and Iridium plugs.
fuel:e85: via Walbro 400lph e85 Pump and Nismo 740cc
power:301rwkw
oil: Currently Motul 300V will switch to 6100
useage: Street Driven but will begin trackdays. Have a Low Boost setting 270rwkw
lifespan: 2 years at 150rwkw, 2 months at 260rwkw and a few runs on the dyno at 301rwkw - soon to be picked up today.
failure: Overheated - Cooling system was overhauled, Hoses, Waterpump, Thermostat and Koyorad Aluminium Radiator
comments:The price for this entry ticket has been very hefty and to be honest, I really didn't take into account what would really be involved when embarking on this journey!
Dyno graph and how many boosts? Sorry to gear about the overheat.... The stock engines are the way to go with E85 though so as Scott said have a spare one handy, i will eventually :)
Apologies, I mistook failure to be 'failures that have occured along the way'. It appears I can't edit the post at work, probably since we're still on Internet Explorer 6. So for now, as of Today, it's happy story and really glad to share this with you all. Can't wait till 5 o'clock to go pick it up and drive it for the first time at this power level.
It was pretty funny talking to the workshop yesterday. They advised they hit 290kw since it wouldn't make any more with the stock airbox. I literally told them I wanted to get into the '300kw Unopened 25 Club'. haha
Took a bit of boost to get there when compared to others (19PSI). The stock airbox was believed to be responsible. Eventually had to resort to making several holes in the airbox to open it up. Set-up looks very factory. Graph for below:
(Not sure how to create Thumbnail view, Sorry)
Edited by tranman
I'm part of this club too! Wooo!
Actually, i only made 296rwkw :glare: lol.....is there a 500 plus club now?? :P
EDIT; just read first page haha
mods: power fc, nismo 740s, avcr, gt3076r .82 rear, 45mm turbosmart gate
fuel: BP98
power: 296rwkw
oil: Castrol Edge 10-60
useage: 7 years of constant abuse
lifespan: unlimited
failure: none :D
comments: motor is pulled out for rebuild, chasing minimum 500rwkw
Thanks
Edited by MR 33
  • Like 1
Yep there is, now take your GT37 and go join it haha.... Looking forward to following your build :yes:
Hi Tranman , I'd like to see your intake from the Z32 to the GTX3076R if possible because many claim its difficult to do .
Do we know for sure if the std GTS25T airbox can't support 300 RWKW , I still have mine and it has a cleanable Piper Cross element in it . I'd also like to see the box mods as I like stealth and I'm using the same IC as yours . The airbox in R33 GTRs must be significantly better if it supports more than 290-300 RWKW .
Good effort , cheers A .
Edited by discopotato03
Just make a flange on inside of airbox bolting to AFM, then run a pipe straight out the bottom to a ppod filter! Had that set up for years, passed DECC an everything LOL i even had the stock panel filter in place above the pipe
Lol awesome! :P
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
