This here is my unopened rb25. Has a surge tank,
044 pump, 750bosch injectors, e85 fuel and an apexi
Power fc. Turbo is a hks 3037 .63 rear housing with a
Garrett front cover. Tuned by smmotorsports making
344.1rwkw on only 15.8 psi. Since October last year
I've done 5 drift events, Phillip island sprints and
Winton Vic time attack over Easter. Engine still has
no signs Of wear.
Hmmmm interesting, my car has tested the limits of that turbo in every way and with a 0.82 rear on the same turbo with every supporting mod possible the best we ran was a 320-330kw...... 344 required 20psi bleeding to 18 and that is with the bigger rear housing!
yeah, I think we can conclude it's a happy dyno, however it's definatley a 300+ car and would be an assload of fun
Yep not doubting that part! It is an awesome combo and tried and tested many times! Good result and welcome to the club haha
  • Like 1
Good to have people around who are willing to try and test combos so you know what works :D Your car has become a bit of a benchmark for the GT3076R's ability, I reckon!
Well we have found the limit with this combo and will be looking to improve where possible, the 3076 and RB25 were made for each other :yes:
:ph34r: swap it for Hypergears VNT and get 400kw.. do it!! :yes:
Edited by AngryRBGTX
Not convinced on that as yet! Good result for sure but there are other ways to make power on mid frame turbos! You should know, you are about to try ;)
srsly?
it's written on the chart :P
:laugh:
I know i'm probably going to be shot down in a ball of flames for this.... but is there any real point in shooting for 400?
surely it's just useless power unless you have a very very good and expensive setup
@ 320+ rwkw in a 1.4 tonne chassis I needed to run NT05's just to have a hope of traction, and on your average tyres it was already game over.
seems to me like it's just inviting the motor to pop for power that you will never use beyond a dick measuring contest
No need for flames, it is a pretty decent comment and something i have also said in regards to my car... My tuner was saying i should go to the 35r frame turbos but i said i was overall happy with the performance....
Overall i think mine needs a little extra spool and maybe more in the top end for drag and long open circuits.... For street and hill climbs i would be running gate pressure anyway so it gives you all options.
My car is only running RSR 265's but once warm i can start to get them to grip up, of course i cant launch the car on them but that is where MT tyres will come into play!
As an all round car to do all events i dont see boost settings allowing 330kw, 360kw and 390kw to be a problem as you cover all bases and still have a damn fast car!
Of course bragging rights too :P You know, coz racecar!
I would love to have more because i can! But the old 3037 has nothing more to give! I will continue to seach for a better way haha
Finally some results. Slap us with a teaser.
Sent from my HTC One XL using Tapatalk 2
Haha yeah some results for you finally! And it went over 500rwhp as planned ;)
Well the meth injection is finally installed after months and months.
Was hoping to join the club but might fall a little short of 300 :(
Looks like the old 2835 pro s is maxing out and we have had to tune to fight off knock rather than outright power.
Back up to JEZ tonight to finish the tune and try a couple of things (cam gear adjustment, adjust afr etc)
You never know, I may get there buy I am a little doubtful.
Ah damn! Well i hope it goes well! Shame i hadnt picked mine up from its tune today or i would have popped in and said G'day!
I stay in this club with 390kw :woot:
    • I got back to Japan in January and was keen to get back on track as quickly as possible. Europe is god-awful for track accessibility (by comparison), so I picked up a first-gen GT86 in December just to have something I could jump into right away. The Skyline came over in a container this time and landed in early January. It was a bit battered after Europe, though—I refused to do anything beyond essential upkeep while it was over there. The clutch master cylinder gave out, and so did the power steering. I didn’t even bother changing the oil; it was the same stuff that went in just before I left Japan the first time. Naughty. Power steering parts would’ve cost double with shipping and taxes, so knowing I’d be heading back to Japan, I just postponed it and powered through the arm workout. It took a solid three months to get the car back on the road. Registration was a nightmare this time around. There were a bunch of BS fees to navigate, and sourcing parts was a headache. I needed stock seats for shaken, mistakenly blew 34k JPY on some ENR34 seats—which, of course, didn’t fit—then ended up having the car’s technical sheet amended to register it as a two-seater with the Brides. Then there’s the GT86. Amazing car. Does everything I want it to do. Parts are cheap, easy to find, and I don’t care what anyone says—it’s super rewarding to drive. I’ve done a few basic mods: diff ratio, coilovers, discs, pads, seat, etc. It already had a new exhaust manifold and the 180kph limiter removed, so I assume it’s running some kind of map. I’ve just been thrashing it at the track non-stop—mostly Fuji Speedway now, since I need something with higher speed after all that autobahn time. The wheels on the R34 always pissed me off—too big, and it was a nightmare getting tires to fit properly under the arches. So I threw in the towel and bought something that fits better. Looks way cleaner too (at least to me)—less hotboy, less attention-seeking. Still an R34, though. Now for future plans. There are a few things still outstanding with the car. First up, the rear subframe needs an overhaul—that’s priority one. Next, I need to figure out an engine rebuild plan. No timeline yet, but I want to keep it economical—not cutting corners, just not throwing tens of thousands at a mechanic I can barely communicate with. And finally, paint. Plus a bit of tidying up here and there.
    • I assume clearances were all a-okay?
