  • Replies 71
Yeh there is the possibility of going to sydney to get somewhere like CRD to install and tune it, but the only issue with sydney is i would have to get them to put in everything at the same time. Im planning on getting a hypergear r33 kai hi flow turbo, injectors (700cc or so), fuel pump (probably nismo in tank), clutch (got no idea what sort, suggestions?), ebc (profec b spec), z32 afm, 3" metal intake pipe and the nistune/z32 ecu)
So to get all that done in one hit theyd need the car for a fair while not to mention how big of a hit my wallet would take in one go.
Any place is going to need it for a fare while..?
Wouldn't mean because it's local you get to drive it home each afternoon after they have done one thing
Local is going to be the same as Sydney in time it takes and when you get to drive again.
Yeh, Im completely aware of that, But i meant to make it worth while going to sydney or somewhere I would have to get everything done at once otherwise the cost of driving up and back would make it not worthwhile after a couple of trips. Whereas here i could get a few things done at intervals, like fuel pump, ebc and nistune install and tune on stock turbo. Then get it back and wait a while/ save a bit more. Then get clutch, injectors, turbo and afm done a bit later. Not to mention if I get it done here its a lot closer to take it back to someone who has worked on it and knows the car a bit.
Edited by Mitcho_7
It's not rocket science and regardless of preference I find it hard to believe any workshop can't tune any ECU of your choice.
Best thing to do really is call around, talk to a bunch of workshops both local and in Syd and see who you feel comfortable with regardless of where they are. Slight inconvenience now (such as taking it to Syd) might save you a lot of trouble in the long run.
Up to you, but I think you are making a bad decision if you get hardware that only one workshop can work on. For the price, get a second hand Power FC then anyone can tune it. Everyone works on haltechs as well and vipec is becoming popular as well (though without the support or history of haltech).
I've gone to different workshops to get issues resolved, if you are stuck with one workshop and they into a problem they can not solve, you are stuffed. I've also learn't to spend the big money and get something done right with the best gear in the first place, but understand everyone has a budget.
I think the thing thats going to kill me with these upgrades is paying the labor costs to put everything in because im generally pretty unskilled when it comes to cars and dont trust myself not to stuff it up. Ideally if i was competant i would put everything in at home and get the car towed to be tuned to save on labor costs. But ive got no idea how to put in a new clutch, injectors, fuel pump, ebc and solder the z32 afm wires or change out my turbo for a high flowed one. Not to mention itd probably be really awkward to try and do that sorta stuff on a driveway with a jack and stands rather than a hoist. But i guess if you wanna do upgrades, you got to be willing to pay what it costs...
Nistune nistune nistune do it.
I spent days and hours upon hours researching it.
Just say stfu to local tuners and go to Sydney.
Also go the 32 Ecu with a window switch to control VCT
People might say keep it local but really?
Cheaper and possibly better tune you can't go wrong heading up to Sydney.
Where abouts did you get your nistune setup?
Purchased the Ecu online here
Also the VCT switch can pop up on here or you can google them and plenty of places sell them.
They go under the name of MSD rpm window switch
Turns things on and off at programmed rpm's such as your VCT
Chips I am purchasing online from nistune
Type 2 board if I remember correctly
    • Hey Dave, welcome aboard! Good to see another soon-to-be Stagea owner here. The wagons are awesome — plenty of space, still got that Skyline DNA, and loads of potential if you’re into mods. Definitely post up pics when you get it, everyone here loves seeing new builds. What model/year are you looking at?
    • See if you can thermal epoxy a heatsink or two onto it?
    • The other problem was one of those "oh shit we are going to die moments". Basically the high spec Q50s have a full electric steering rack, and the povo ones had a regular hydraulic rack with an electric pump.  So couple of laps into session 5 as I came into turn 2 (big run off now, happily), the dash turned into a christmas tree and the steering became super heavy and I went well off. I assumed it was a tyre failure so limped to the pits, but everything was OK. But....the master warning light was still on so I checked the DTCs and saw – C13E6 “Heat Protection”. Yes, that bloody steering rack computer sitting where the oil cooler should be has its own sensors and error logic, and decided I was using the steering wheel too much. I really appreciated the helpful information in the manual (my bold) POSSIBLE CAUSE • Continuing the overloading steering (Sports driving in the circuit etc,) “DATA MONITOR” >> “C/M TEMPERATURE”. The rise of steering force motor internal temperature caused the protection function to operate. This is not a system malfunction. INSPECTION END So, basically the electric motor in the steering rack got to 150c, and it decided to shut down without warning for my safety. Didn't feel safe. Short term I'll see if I can duct some air to that motor (the engine bay is sealed pretty tight). Long term, depending on how often this happens, I'll look into swapping the povo spec electric/hydraulic rack in. While the rack should be fine the power supply to the pump will be a pain and might be best to deal with it when I add a PDM.
    • And finally, 2 problems I really need to sort.  Firstly as Matt said the auto trans is not happy as it gets hot - I couldn't log the temps but the gauge showed 90o. On the first day I took it out back in Feb, because the coolant was getting hot I never got to any auto trans issues; but on this day by late session 3 and then really clearly in 4 and 5 as it got hotter it just would not shift up. You can hear the issue really clearly at 12:55 and 16:20 on the vid. So the good news is, literally this week Ecutek finally released tuning for the jatco 7 speed. I'll have a chat to Racebox and see what they can do electrically to keep it cooler and to get the gears, if anything. That will likely take some R&D and can only really happen on track as it never gets even warm with road use. I've also picked up some eye wateringly expensive Redline D6 ATF to try, it had the highest viscosity I could find at 100o so we will see if that helps (just waiting for some oil pan gaskets so I can change it properly). If neither of those work I need to remove the coolant/trans interwarmer and the radiator cooler and go to an external cooler....somewhere.....(goodbye washer reservoir?), and if that fails give up on this mad idea and wait for Nissan to release the manual 400R
    • So, what else.... Power. I don't know what it is making because I haven't done a post tune dyno run yet; I will when I get a chance. It was 240rwkw dead stock. Conclusion from the day....it does not need a single kw more until I sort some other stuff. It comes on so hard that I could hear the twin N1 turbos on the R32 crying, and I just can't use what it has around a tight track with the current setup. Brakes. They are perfect. Hit them hard all day and they never felt like having an issue; you can see in the video we were making ground on much lighter cars on better tyres under brakes. They are standard (red sport) calipers, standard size discs in DBA5000 2 piece, Winmax pads and Motul RBF600 fluid, all from Matty at Racebrakes Sydney. Keeping in mind the car is more powerful than my R32 and weighs 1780, he clearly knows his shit. Suspension. This is one of the first areas I need to change. It has electronically controlled dampers from factory, but everything is just way too soft for track work even on the hardest setting (it is nice when hustling on country roads though). In particular it rolls into oversteer mid corner and pitches too much under hard braking so it becomes unstable eg in the turn 1 kink I need to brake early, turn through the kink then brake again so I don't pirouette like an AE86. I need to get some decent shocks with matched springs and sway bars ASAP, even if it is just a v1 setup until I work out a proper race/rally setup later. Tyres. I am running Yoko A052 in 235/45/18 all round, because that was what I could get in approximately the right height on wheels I had in the shed (Rays/Nismo 18x8 off the old Leaf actually!). As track tyres they are pretty poor; I note GTSBoy recently posted a porker comparo video including them where they were about the same as AD09.....that is nothing like a top line track tyre. I'll start getting that sorted but realistically I should get proper sized wheels first (likely 9.5 +38 front and 11 +55 at the rear, so a custom order, and I can't rotate them like the R32), then work out what the best tyre option is. BTW on that, Targa Tas had gone to road tyres instead of semi slicks now so that is a whole other world of choices to sort. Diff. This is the other thing that urgently needs to be addressed. It left massive 1s out of the fish hook all day, even when I was trying not too (you can also hear it reving on the video, and see the RPM rising too fast compared to speed in the data). It has an open diff that Infiniti optimistically called a B-LSD for "Brake Limited Slip Diff". It does good straight line standing start 11s but it is woeful on the track. Nismo seem to make a 2 way for it.
