I've just purchased a -10 non return valve thingie from Earls, it will be fitted on the return line from the can to the sump, they don't do -12 so it will have some adaptors, Damn these things cost.
Fingers crossed this will help if there is oil being pushed up the hose.
Eastern creek on Sunday, I'm hoping this helps.
I should have went dry sump at the start of the build, things would have been so much simpler.
remember to remove the spring out of the valve, otherwise it won't drain back.
The one I'm getting doesn't have a spring (sort of), it is a flap which only needs .5psi to seal, the guy said it will flow until a 0.5psi backpressure hits it.
P/N 251010
At least I hope that how it works, for almost $300 I would hate to get the wrong part.
Gotta love earls retail pricing.
I use the same "valve" occasionally in some of the boats I do dry sumps for.
They work okay in theory but can cause more issues than they solve when the engine isn't breathing right to begin with.
Finaly sorted my oil problems, my return line to the sump and the hot side head drain/vent fittings were to low on the sump, on hard right hand corners the oil would push UP the drain/vent.
In essance I had a - 12 restrictor filling the head and a self filling catch can on anything that involved turning right.
With the catch can return line having the one way valve and the head drain/vent being moved to the turbo oil return all issues were solved.
The drain/vent on the cold side are right at the top of the sump and are not causing any issues.
I did a new PB of 1:52 at the creek last Sunday too, after doing 2 sessions of testing I got up it a bit on the 3rd and the car loved it, not a drop of oil anywhere.
Im stoked, FINALY.
one question, what fittings are used for the oil cap drain?
i assume the fitting allows for the oil cap to still be used? ie. be able to twist on and off
It's an earls fitting, it is rubbing the bonnet though (by so little it isnt funny) will have to try to change the angle it sits at to avoid this. The fitting does allow the cap to spin easily.
Woohooo, and my theory from all those months ago was right....so time to open a workshop for me haha
Good work on the pb :)
Thanks mate, it was something so simple in the end, so simple we didnt even concider it, D'oh!
Im stoked, FINALY.
mlr: would it be too much trouble to bother you for some photos of the setup please??
iplen: nice nice
do you have the part number for this fitting?
thanks!
Im taking the car to work this weekend to put on the maintanance ramps, Ill take some photos of it when its up there and the undertray is off.
this might be a silly comment.i have a similar set to r32 stuart but without the line from the oil filler cap.You guys are saying to drain back to sump from catch can i haven't drained back .When i empty my catch can ther is only water in it.im pretty sure you dont want that going back into your sump .Am i on the right track here
thanks
If you are getting water out of your oil catch can you have issues.. Big ones.. Exquisit, will try to get the part number for you, and will upload some shots when I am on a PC instead of the phone..
Edited by iplen
The oily water in the catch can gets there by the little bit of oil and heat sucking the water out of the atmosphere, Im not saying you should have a heap of water in it but it does get in, expecially when the catch can doesnt drain back it will build up over time, and due to the fact that the inside of the catch can doesnt get very hot the water doesnt cook off.
Put some oil on the stove and heat it up and then let it cool 10 or 20 times, the oil will turn watery when it cools, simple physics is simple.
The same happens in the sump but because the sump oil gets hot it cooks off the water.
This alsois why big deisel engines have fuel/water seperators, the deisel in the tank gets warm and when it cools it absorbs water.
Put even simplyer (?) sit in you car on a cold day, the windows will fog up, this is due to the air inside is warmer than the air outside thus causing condensation.
This is the one way valve
This the hot side head drain/vent which goes to the turbo drain
Hot side head fitting
Front 25 head drain blocked
This is the regulator that was fitted to drop the oil pressure from the TOMEI from 140 psi @ 6000rpm to 105psi at 6000rpm
From the regulator a bleed line goes to the sump
This is the fitting in the side of the head that has the restrictor, the restrictors in the block are both blocked off, this feeds the head oil, it takes 5 minutes to swap a restrictor, another external line geos to the VCT.
The 25 head has 26 covers with mines baffles, the head vents to the catch can Via -12 fittings, the catch can has 2 30mm filters under the pod cover plate.
Time for a Scotch...................
  • 1 month later...
    • Have a look at that (shitty) pic I posted. You can see AN -4 braided line coming to a -4 to 1/8 BSPT adapter, into a 1/8 BSPT T piece. The Haltech pressure sender is screwed into the long arm of the sender and factory sender (pre your pic) into the T side. You can also see the cable tie holding the whole contraption in place. Is it better than mounting the sender direct to your engine fitting......yes because it removes that vibration as the engine revs out 50 times every lap and that factory sender is pretty big. Is it necessary for you......well I've got no idea, I just don't like something important failing twice so over-engineer it to the moon!
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
