Hey everyone iv tried searching google and all that but I keep getting mixed answers. Now I'm putting a sr in my BMW and I have a sr box and a rb20 box either one will work I just want to know what one is better I don't want stupid answers only people that have used both. The sr box is out of a 180 type x and the 20 box is out of my old 32. The sr will be running a td06h-20g so I'm hoping around 260kw which the 20 box handled before. Anyone thats thinking buy a rb25 box I know they are better but a pain to fit up to a sr. Any info would be gold
RB20 and RB25 gearboxes bolt to the backs of RBs. So I would expect you would have the same issues using an RB20 box on an SR as you would an RB25 box on an SR.
The SR20 and RB20 internals are very similar though, with the same PPG and OS Giken part numbers anyway. So general health and age would be the determining factor one would think.
I would be sticking with the SR20 gearbox behind an SR20. Just be sensible with the sprung centre clutch and use good quality Castrol fluid and would be ok provided the car isnt being clutch kicked like a wet, stray dog
Yeah that's what I would do. I just don't want to put a weaker box on when I have both available I already need a custom shaft so I don't care about that. Also the shifter is in different locations the 20 box seems to line up near perfect. I'm not to worried about gearing as the diff in using (m3 LSD) is already in the 3.8 regon I think so that would decide most of how the car reacts.
They are for most part the same box, no real difference, just made for a different car. So go with the SR20 for ease of use. As for RB25 gearbox, you can buy SR20 adaptor plates so no cut and shut necessary. Running 260rwkw that's the path I'd heel heading down, personally.
I don't think it really matters which box you use. My experience has been that Nissan makes near indestructible gearboxes. (Although I have heard of 1 person who managed to lunch 3 RB boxes in a matter of months - probably using a VHD multi-plate clutch, and sidestepping the clutch at 7000 rpm.)
Since you are using a SR engine, it makes good sense to use a SR gearbox, IMHO.
another thing i've been told is that the SR has longer raitos. may want to scope that out for yourself though.
RB tops at around 200, SR at 240ish. (Same diff ) but again, double check that...
I can tell you now my 20 box seen more the 200 got 215 (nismo 260 cluster) before I slowed down on a private road of course diff is the main controll of top speed so the m3 diff would benefit from a shorter ratio box
Yuh, not even close to correct.  The RB20 will see over 180 km/h in 4th easily, run to much much more than 200 in 5th.  The main differences in ratios between SR cars and RB cars is that the RB diffs are shorter than 4:1 and the SR diffs are taller than 3.7:1.  The SR gearbox ratios are therefore better suited to the longer diff gears.
Bsa.  Just use the SR gearbox.  It is better suited to your engine and your diff ratio.
Edited by GTSBoy
    • I haven’t pulled the injectors to watch them spray yet but they are clicking from the cas and all of the spark plugs are wet with fuel. I’ve thought the cylinders were being flooded from the beginning and was hoping fuel pressure would fix it. Tonight I am going to pull the rail and watch the injectors spray. Don’t know how to test/diagnose if the plugs are firing in correct sequence but that should be a timing thing and as far as timing goes my car still has the half moon for the cas can only install it 1 way. And my mechanical timing is 100% correct I posted photos above. Confirmed with the balancer on and off.
    • I checked spark on all cylinders and they all visually have spark with the plug pulled and grounded, but plug 1 is the only one that fouled. This was a running swap that blew up and was rebuilt by a machine shop, put a new wiring specialties harness and did all gaskets, studs, and bolts while it was out.  compression is 135-150 across all cylinders. Aside from that from my understanding with the z32 ecu and maf the car should start regardless. The wiring for TPS and the dual 02 sensor/ dual knock sensor stuff shouldn’t actually stop the car from starting or even running well, (just slightly rich)  they just give fault codes. Car supposedly is supposed to start as long as you have z32 afm and ecu with the nistune base map and that’s info coming from a well known and trusted tuner who does a lot with SR/RB (Rsenthalpy). After more trouble shooting today where I’m at right now is that the cas is sending signal to the injectors they click while spinning the rotor, Fuel pressure is now set at 43psi, all cylinders have good compression and all of the plugs looked great (just wet with fuel) except for cylinder 1 which was very black (cylinder 1 has 150psi compression). all of the coils generate spark if pulled out and grounded out on the head. On the fuel pump car just pops into the exhaust. On starting fluid car will fire off. Hard to tell if all cylinders are firing off but definitley a couple. sounds like all of them but it’s only for 3-5 seconds hard to tell.
    • Final update!!! Got the front bar fitted and sprayed and all sorted now. My cutouts worked great and the indicators aren’t just falling off. 😂
    • Is this a brand new LSD? if so, have you followed any break/bed in procedure for it? Usually involves heaps of figure 8 patterns, a fluid flush.
    • It's TWO steering wheels actually. 😛 one for each hand They are wheels, and they steer!
