dori34 Posted February 7, 2012 Share Posted February 7, 2012 had to remove my washer bottle filler neck as my battery had to be fully pushed against the chassis. so gonna have to connect a clear hose and run it from the washer bottle into the engine bay. dodgey but it'll work Link to comment https://www.sau.com.au/forums/topic/390549-plazmaman-plenum-on-rb25det-neo/page/3/#findComment-6222479 Share on other sites More sharing options...
Hanaldo Posted February 7, 2012 Author Share Posted February 7, 2012 had to remove my washer bottle filler neck as my battery had to be fully pushed against the chassis. so gonna have to connect a clear hose and run it from the washer bottle into the engine bay. dodgey but it'll work I'll just ditch the stock washer bottle and buy a small universal one. Either relocate it to somewhere else in the engine bay if it fits, otherwise to the boot. Stock one is ugly anyway Link to comment https://www.sau.com.au/forums/topic/390549-plazmaman-plenum-on-rb25det-neo/page/3/#findComment-6222492 Share on other sites More sharing options...
boostn0199 Posted February 7, 2012 Share Posted February 7, 2012 I'll just ditch the stock washer bottle and buy a small universal one. Either relocate it to somewhere else in the engine bay if it fits, otherwise to the boot. Stock one is ugly anyway washer bottles are overated lol just bin it and dont run one. Link to comment https://www.sau.com.au/forums/topic/390549-plazmaman-plenum-on-rb25det-neo/page/3/#findComment-6222579 Share on other sites More sharing options...
PM-R33 Posted February 7, 2012 Share Posted February 7, 2012 Come on, not even Phil's? My ears are burning... Link to comment https://www.sau.com.au/forums/topic/390549-plazmaman-plenum-on-rb25det-neo/page/3/#findComment-6223420 Share on other sites More sharing options...
Hanaldo Posted February 7, 2012 Author Share Posted February 7, 2012 My ears are burning... It had to be done Link to comment https://www.sau.com.au/forums/topic/390549-plazmaman-plenum-on-rb25det-neo/page/3/#findComment-6223433 Share on other sites More sharing options...
KiwiRS4T Posted February 7, 2012 Share Posted February 7, 2012 A lot of people put the battery in the boot (for cars that don't already have it there) and get a fabricator to make a combined washer bottle/catch can to fit in the available space (some with cut outs for the intercooler piping). I am too cheap for that and I have found that my washer bottle can share the space with the piping by making some new brackets. I may have to go with the flexible filer hose as above^^^ but am not prepared to lose either front or rear washers they are good for an extra 10kw at least! Link to comment https://www.sau.com.au/forums/topic/390549-plazmaman-plenum-on-rb25det-neo/page/3/#findComment-6223610 Share on other sites More sharing options...
dori34 Posted February 7, 2012 Share Posted February 7, 2012 bro, your washer bottle is low, it needs a top. "ahh, no wonder i was down on power" Link to comment https://www.sau.com.au/forums/topic/390549-plazmaman-plenum-on-rb25det-neo/page/3/#findComment-6223769 Share on other sites More sharing options...
Granthem Posted February 8, 2012 Share Posted February 8, 2012 Plenty of space in the boot for a washer bottle! - (no I'm not joking, that's where mine is). Worth popping your boot to fill it up when you have this Link to comment https://www.sau.com.au/forums/topic/390549-plazmaman-plenum-on-rb25det-neo/page/3/#findComment-6223856 Share on other sites More sharing options...
STATUS Posted February 8, 2012 Share Posted February 8, 2012 IAC valves can easily be replaced by a competent tuner. My Plazmaman plenum allowed me to run the stock RB25 IAC (upside down / had to extend two wires) but I ended up pissing it off and replacing it with a piece of flat steel, some silicon and the bolts that normally hold the IAC in place. Not really, pwr steer idle up, a/c idle up, auto anti stall etc are all required for the niceties of a daily driver.... many afm based ecu's strugle without one. Nistune for one is happy to make upwards of 500rwkw but does not like having the iac removed. if your ecu allows it and your not fussed about having a higher idle than std etc than yes it can be tuned around (mostly map based ecus). The only people who seem to get good results with these are guys who need to justify the fact they sold it to the customer.... yes we tuned heaps yes they work (like std) would i put one on my own car ... no. Link to comment https://www.sau.com.au/forums/topic/390549-plazmaman-plenum-on-rb25det-neo/page/3/#findComment-6224034 Share on other sites More sharing options...
dori34 Posted February 8, 2012 Share Posted February 8, 2012 i wanted to run mine without IAC but my tuner advised against it for the above reasons for a/c, power steering etc as it is recommended to run it. if i could, i would remove it and tune without it as it makes my engine bay look so messy. Link to comment https://www.sau.com.au/forums/topic/390549-plazmaman-plenum-on-rb25det-neo/page/3/#findComment-6224069 Share on other sites More sharing options...
boostn0199 Posted February 8, 2012 Share Posted February 8, 2012 Plenty of space in the boot for a washer bottle! - (no I'm not joking, that's where mine is). Worth popping your boot to fill it up when you have this Off topic here but gota say those rims on black look crazzy! Link to comment https://www.sau.com.au/forums/topic/390549-plazmaman-plenum-on-rb25det-neo/page/3/#findComment-6224077 Share on other sites More sharing options...
STATUS Posted February 8, 2012 Share Posted February 8, 2012 Off topic here but gota say those rims on black look crazzy! screw that.... that whole car is super sexy. Link to comment https://www.sau.com.au/forums/topic/390549-plazmaman-plenum-on-rb25det-neo/page/3/#findComment-6224082 Share on other sites More sharing options...
Granthem Posted February 8, 2012 Share Posted February 8, 2012 Off topic here but gota say those rims on black look crazzy! screw that.... that whole car is super sexy. Thanks! Looks totally different since this pic - alot has changed. Sadly it was the only shot I had that showed my plenum so I had to use it. The plazmaman makes you actually look forward to changing plugs, instead of putting it off because of the annoying cross pipe set up Link to comment https://www.sau.com.au/forums/topic/390549-plazmaman-plenum-on-rb25det-neo/page/3/#findComment-6224197 Share on other sites More sharing options...
PM-R33 Posted February 8, 2012 Share Posted February 8, 2012 Yep was one of my most favourite mods. Link to comment https://www.sau.com.au/forums/topic/390549-plazmaman-plenum-on-rb25det-neo/page/3/#findComment-6224954 Share on other sites More sharing options...
ACTIVE-LSD Posted February 8, 2012 Share Posted February 8, 2012 hi just got a quick question. is a r33 rb25det going to experience this same problem your having with a greddy copy? Link to comment https://www.sau.com.au/forums/topic/390549-plazmaman-plenum-on-rb25det-neo/page/3/#findComment-6225229 Share on other sites More sharing options...
Hanaldo Posted February 8, 2012 Author Share Posted February 8, 2012 You mean the loss in torque? That's got nothing to do with the motor, it's the length of the runners on the intake. As a general rule, shorter runners = less mid-range more high end, longer runners = more mid-range less up top. Link to comment https://www.sau.com.au/forums/topic/390549-plazmaman-plenum-on-rb25det-neo/page/3/#findComment-6225235 Share on other sites More sharing options...
2rismo Posted February 19, 2012 Share Posted February 19, 2012 Not really, pwr steer idle up, a/c idle up, auto anti stall etc are all required for the niceties of a daily driver.... many afm based ecu's strugle without one. Nistune for one is happy to make upwards of 500rwkw but does not like having the iac removed. if your ecu allows it and your not fussed about having a higher idle than std etc than yes it can be tuned around (mostly map based ecus). The only people who seem to get good results with these are guys who need to justify the fact they sold it to the customer.... yes we tuned heaps yes they work (like std) would i put one on my own car ... no. Niceties of a daily driver? Lol. Sometimes I forget that my priorities don't extend to giving a shit about those things. Still the car functions perfectly well, doesn't stall, steers fine and doesn't have air-con. Link to comment https://www.sau.com.au/forums/topic/390549-plazmaman-plenum-on-rb25det-neo/page/3/#findComment-6242148 Share on other sites More sharing options...
34GeeTeeTee Posted February 19, 2012 Share Posted February 19, 2012 Bugger that, for a daily i want aircon All i gotta do is figure out an A/C fan to replace the stock one as the Plazmaman intercooler is so much thicker than my old ARC Link to comment https://www.sau.com.au/forums/topic/390549-plazmaman-plenum-on-rb25det-neo/page/3/#findComment-6242585 Share on other sites More sharing options...
Hanaldo Posted February 20, 2012 Author Share Posted February 20, 2012 Quick question for those with FFPs and stock bovs, where are you relocating your bov to and how did you do it? I'm currently thinking about what I'm going to do with my stock GTR bov. Ideally I'd like to keep it, but if it's too much hassle/cost then I am considering just ditching it. As I understand it, the closer to the TB the better, yes? What about flanges, where can I get a weld on flange? Link to comment https://www.sau.com.au/forums/topic/390549-plazmaman-plenum-on-rb25det-neo/page/3/#findComment-6244080 Share on other sites More sharing options...
KiwiRS4T Posted February 20, 2012 Share Posted February 20, 2012 Quick question for those with FFPs and stock bovs, where are you relocating your bov to and how did you do it? I'm currently thinking about what I'm going to do with my stock GTR bov. Ideally I'd like to keep it, but if it's too much hassle/cost then I am considering just ditching it. As I understand it, the closer to the TB the better, yes? What about flanges, where can I get a weld on flange? My fabricator put the bov near the ffp and it vents to atmosphere ( I have a G4 Link with a MAP sensor). I hate the sound. I plan to relocate it to the other side (hot side) of the intercooler so I can plumb it in. I will need a long vacuum line so may make up a hard line. No nearer the T/B is not better. Garrett actually say as close as possible to the turbo. I am sure there will be a fluid dynamic engineer or suchlike who can correct me but my take is that bovs are not about flow but about pressure relief and so it doesn't matter where it is. Some manufacturers put them on the intercooler itself. Link to comment https://www.sau.com.au/forums/topic/390549-plazmaman-plenum-on-rb25det-neo/page/3/#findComment-6244113 Share on other sites More sharing options...
