24 minutes ago, TanjuAydin said:
I currently have 18 x 9 +30 on the front with 18 x 10.5 +38 on the rear. Absolutely regretted it. Ended up putting 15 mm spacers on front and 25 mm spacers on the rear. Not to mention the rears were like a mm from hitting the coilovers. Definitely would go more aggressive then what you were originally planning. Keep in mind my guards are rolled and cars fair low so you might possibly need to roll guards depending how aggressive you go and how low the car is. Im not an expert but the
18 x 8.5 +25
18x9.5 +30
Sounds like it would sit much better.
Thank god i didnt place the order. I saw some photos and didnt look aggressive enough for me.
I've read 18x9.5 +20 all round is a good size for the gtts, do you think 9.5 +20 will fit in the front?
I think ill go 18x9.5 +20 for the rears, stupid question but the lower the offset the more concave i get from the spokes right?
1 minute ago, TanjuAydin said:
I thought the whole idea of having a forum on the internet is to ask random people who have no idea for advice on how to do things😜😅
I had to double check the thread title r34 gtt offset advice lol. Thought maybe i posted on the wrong thread. 😂
This is a recipe for disaster*
Note: Disaster is relative. The thing that often gets lost in threads like this is what is considered acceptable poke and compromise between what one person considers 'good' looks and what someone else does.
The quoted specs would sit absurdly outside the guards with the spacers mentioned and need  REALLY thin tyres and a LOT of camber AND rolling the guards to fit.
Some people love this. Some people consider this a ruined car.
One thing is for certain though, rolling the guards is pretty much mandatory for any 'good' fitment (of either variety). It is often the difference between any fitment remotely close to the guards.
"Not to mention the rears were like a mm from hitting the coilovers."
I have a question though - This spec is VERY close to what I was planning to buy relative to the inboard suspension - I have an offset measuring tool on the way to confirm it. When you say "like a mm" do you mean literally 1mm? Or 2mm? Cause that's enough clearance for me in the rear :p
I actually found the more limiting factor ISNT the coilover but the actual suspension arms. Did you take a look at how close those were?
^ lots of good points made above.
The thing is, "aggressive" or "flush" fitment is relative depending on how much you have been influenced by social media.
My starting point is always "look at the Nismo RWD specs". That is where you should start, then start measuring as GTSBoy as sort of mentioned, because every car will be slightly different.
My 8.5"+35/9.5+38 will not be "flush" enough for you because you want more "pumped" look, which is why you measure.
Tyre sizes and brand/models also make a difference. Some tyres are more chunky/square, some are more rounded. That means you could get away with more aggressive offsets without rubbing. But then it also depends on your ride height. Also depends on how much your car copped damage before being shipped from Japan.
So it goes back to measuring your car yourself and determining what can work.
Those Nismo specs are used bacause it's a safe spec for standard car (suspension. body) with chunky tyres. But then I put 265/35 wide tyres on R34 GT-R wheels, and currently run 285/30 tyres on 18x10 wheels.
  • 4 weeks later...
Another fitment photo.
Found the 19´s i´ve been looking for. audi peelers, im running 5x112 pattern. need to get new center caps with nissan logos. also car wrapped to different color. need to get it low next.
with spacers its:
Front: 19x8.5 ET33 - 235/35
Rear: 19x8.5 ET39 - 235/35
    • I've looked up the parts number (41011AL501). It's around $700 OEM. Usually our Infiniti G35 here in Canada have interchangeable parts with my Stagea but the parts number are not the same. I have looked around and it seems the JDM 2005 V35 Skyline (which is the same as our G35) has the same caliper but I cannot confirm. And I can't find a repair kit. The inner brake pads drags on the rotor, seems to be rusty piston. Thanks for the info by the way
    • This coupled with 6-9 speed autos with ridiculously short gearing is why these modern shitbox cars always seem so fast off the line. If it wasn't for those things, Raptors would not seem fast. The problem we have is there is a driveability gap between a more gentle take off and a wheelspinning sideways launch. The difference between ankle flex required to achieve one and ankle flex required to achieve the other is about 0.5°.
    • Yeah I think I'm also with the opposite here. It's 'hard to keep up with traffic' because in the real world I'm accelerating with 15% throttle and they are pinning it. It feels like I'm being an overt dickhead at anything above 15% throttle, so the car sounds like I'm being an overt dickhead to keep up with/get ahead of traffic when I'm really just trying to drive with traffic. There would be no issue 'keeping up with traffic' if we used the same level of throttle input/aggression to drive around. People really do just drive around with their foot nearly pinned in econoboxes.
    • To be fair it's the other way around. 300kw is boring in a modern Golf or BMW. They are so competent / well-engineered / devoid of emotion that you have to go stupid fast to feel anything. Whereas the <300kw RB still makes all the right noises and it feels good to drive. Can pull off at the lights with the turbo whooshing and the blow-off pssshing and feel like the coolest kid on the block. Just don't look to the side where you'll see the bored housewifes in their shitbox Yaris/Corolla/Camry that kept up because you didn't go fast at all
    • 300kW is so boring in a Skyline, you'll get spanked by someone's mum's Golf with Alibaba pipes, and an email tune.
