hi guys i have some heavy bulid up of brake dust on my front rims on the dish, tried grease remover, car wash liqued and a sponge with jiff on it mate told me to give it a try lol. None of the above work dont know what else to use with out damaging the polished dish so any ideas would be very helpful thanks
https://www.sau.com.au/forums/topic/391376-brake-dust/
The cheap Import brand wheel cleaner from Autobarn works great for the price. Spray your callipers too. :thumbsup:
If you are worried about the polished alloy, try the less agressive acid free ones, but they dont work as well.
https://www.sau.com.au/forums/topic/391376-brake-dust/#findComment-6229993
  • 4 weeks later...
AUTOSOL is great
https://www.sau.com.au/forums/topic/391376-brake-dust/#findComment-6269370
bendix ultimates are known to be one of the dustiest pads on the market lol
this iron X shit looks good!
IRON-X IRON-X IRON-X IRON-X IRON-X check out my site www.immaculatereflections.com.au there should be a fair few pics of iron x being used on wheels (turns purple)
nothing on your site comes up for Iron X ?
https://www.sau.com.au/forums/topic/391376-brake-dust/#findComment-6273647
I concur Bendix ultimates being dusty as hell...
and yep I agree the Iron x stuff sounds like an awesome answer brake dust removal...
he did say he has pics of it being used on his website but his shop is empty...
It seems only waxit has it for sale, just a shame the postage is $12.50, group buy??... I want 500ml
Does anyone know the diff between the gel and the paste, it says the paste will allow it do work over longer time, does that mean it will get even more stubborn brake dust build up off?
Should I get the paste of the gel?
https://www.sau.com.au/forums/topic/391376-brake-dust/#findComment-6273737
No one else lives on the Central Coast or works in the Sydney CBD that I can tempt to get some Iron X with me?
Im trying to save on the postage cost?
Im yearning for this stuff, Ive got two sets of rims that are freshly powdercoated but have brown haze on them from brake dust....
this stuff should make em look new again...
https://www.sau.com.au/forums/topic/391376-brake-dust/#findComment-6275675
Im pretty keen to get some mainly from seeing it in action from Mitch's work and hearing other great results.
When are you planning to get some?! :D
https://www.sau.com.au/forums/topic/391376-brake-dust/#findComment-6282360
In Cessnock myself, keen nonetheless!
https://www.sau.com.au/forums/topic/391376-brake-dust/#findComment-6282365
  • 4 weeks later...
    • Brooooo Please send ABS control unit schematic Please! R33 gts25t ABS (Its two plug ecu, black and white) wire colors possible? [email protected]
    • Don't even try to run it on the stock ECU if you're going to have the boost controller bring boost above ~10 psi. I've already told you that. If you use the Nistune ECU, you will need to CAREFULLY read the available documentation for Neo tuning, and read some threads on the Nistune forums, to discover the various things you have to do to prevent the ECU from going bananas when the boost is too high. The is a table associated with th boost sensor that must be modified to prevent it from shitting the bed. This is just one of the things that you will need to do to the tune in Nistune, because the Neo turbo ECU will be expecting to see a number of things (such as the TCS) that are not there, and you have to block the DTCs on those. It is totally not surprising to me that you are having the problems that you are, but the solutions to these problems have been known for >15 years. So just get it done.
    • Hi. Sry iam not a mechanic and iam not at the car atm so i dont know 100% but they told they measure those and even try to change those. AFM they have two. Coils are new a they have my old one too. Plugs too. ECU...we have 25 NEO stock and Nistune 25 NEO.   But i dont know if any one those could be the problem and why/if/what can cause this, Only thing they did not check is fuel...but that walbro 255 is new(like 1,5 years)... That fuel pressure gauge idk...but i let them know Any suggestions?   EDIT: how can they know if it is like you say he ECU pull power when it reaches a specific boost level that is too high? Tha car has boost controler
    • Can you clarify what you mean by boost cut, do you mean it misfires both when under load (driving) and when stationary and out of gear? Or does the ECU pull power when it reaches a specific boost level that is too high (boost control issue)? Does it occur at idle with no throttle? When you say "the ECU is OK", what ECU is it and why do you think it is OK? Have you used the NEO ECU, and if so do you have a MAP sensor attached? Same for the AFM, why do you think it is OK? Do you have any way to put a fuel pressure gauge on it (even just a mechanical one between the fuel filter and fuel rail)?
