  • Replies 167
Posted Images
Nick, where's the soccer mum Showdown vid with the gopro on your bonnet?
Ask Teren, that was his GoPro mounted on the bonnet. I'll have to get that footage off him.
You broke my cones nick!!
Woops, my bad! A few scratches were left on the bumper too, but meh... >_<:/
Sorry for being almost a week late, But thank you to everyone who helped on the day and made it another awesome SAU event!
I'm in the process of uploading somevideos to youtube. Might take a little longer though.
btw, This is me in the black 33gtst ;)
R32
if you want to embed something from youtube do the following.. Open the vid and click the share button, then tick the box 'long link' copy that and paste it in here, no need to use embed code..
Also the correct way to do that is [ url] *post link here*[ /url] but without the spaces in the brackets
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
