"steam Pipe" Single Turbo Manifolds On Fleabay....anyone Know Anythging About This Supplier And Their Products?
  • Replies 384
no probs will do. Its going on the dyno next Friday to test some thing else but that will also answer the spiking question. It seems to be holding and no where near as violent but I aint keen on thrashing it on the street to confirm.
  • 2 months later...
Run mine up today with one of these manifolds. 14psi spring in the manifold and dead steady boost control. Run it up to 17psi and no boost creep what so ever. Very happy.
Any pics of the setup on your car mate?
Sean would love that tight bend right before the throttle body :laugh:
You have the AFM in the cooler piping I take it??
Yeah its rather tight, after talking to a few more people about a FFP im really thinking it may be next :(
Yeah afm's just after the intercooler, i was expecting to have hose problems with it blowing off but didnt have one :)
No but I can grab some. Because the power steering line loops up on the 34's makes the intake pipe tight and the waste gate port runs pretty close to the a/c lines. Not problems though. Had to chop up a 14mm spanner to get 2 bolts done up to and trim 2 studs, actually easier to bolt on then my mate's 6 boost.
Just spent 2 days reading this whole thread (hiding at work haha) general concensus seems good for the money. At the end of the day it's stronger than a china manifold, but cheaper than a 6boost. As long as they fit + hold together + hold boost their a winner in my book. I couldn't care less about pretty welds if they do what their supposed to - but that's just me.
Pm sent
I'm going to wait till there's a twin scroll / split pulse one.. I'll be all over that shit like a sale at bunnings
We do Top mounts currently with split pulse,
Without gate? I am planning to mount the gate on the rear housing instead of off the manifold
Hey MSports what size gate did you end up using? I have to change mine to suit a bigger gate cos I'm spiking from 4500 and above witht the durty 30 with about 20psi worth of springs fitted. I used a Turbosmart 40mm gate.
Yeah, its still a tad messy, was in a rush to finish it, Still gotta neaten it all up.
does it clear the A/C lines, heater lines, extra brake lines (ABS)?
also with the gate installed, does it clear the suspension tower ok?
PICS PICS PICS of under car etc... :)
I used a Tial 44mm MVR, no spiking what so ever, flat boost curve the whole time.
I'll grab some pic's soon, been at work all week, i work 12hr shifts so havnt had a chance.
The A/C line's need to be moved towards the strut tower, i just cable tied it away. Heater hoses are clear although i heat wrapped mine and clear's the ABS fine. No clearance problems anywhere.
I had no clearance problems with my R33, but the gate pipe was sitting way too close to the aircon lines, so i cut it and adjusted the angle slightly and it sits better now. That part could do with a slight redesign tho.
the photos aren't that clear on his eBay site.... but is the wastegate port perpendicular to the flow of the outlet?
    • If the forester is anything like our old 2007 GTB Liberty, I could near on run ling Long's and "rate them", as no matter what, it just hung to the road, even when abusing it in a hard launch in the wet, or throwing it at corners.
    • LOL, all of the CAI like Craig I just need to put a hole saw through my bumper Done and dusted, the car runs, which is nice, I'll take it for a spin when the weather clears up Just need to put the bumper back on for good
    • Brooooo Please send ABS control unit schematic Please! R33 gts25t ABS (Its two plug ecu, black and white) wire colors possible? [email protected]
    • Don't even try to run it on the stock ECU if you're going to have the boost controller bring boost above ~10 psi. I've already told you that. If you use the Nistune ECU, you will need to CAREFULLY read the available documentation for Neo tuning, and read some threads on the Nistune forums, to discover the various things you have to do to prevent the ECU from going bananas when the boost is too high. The is a table associated with th boost sensor that must be modified to prevent it from shitting the bed. This is just one of the things that you will need to do to the tune in Nistune, because the Neo turbo ECU will be expecting to see a number of things (such as the TCS) that are not there, and you have to block the DTCs on those. It is totally not surprising to me that you are having the problems that you are, but the solutions to these problems have been known for >15 years. So just get it done.
