The time is coming for me to get a tune I have a just purchased a haltech for my my r32 and im in the south of the state, wondering who is any good for cost and ease to deal with na major mods hoping for sorta 210 plus but should get there fairly easy just hear horror stories with their tunes and big dollars
https://www.sau.com.au/forums/topic/391710-who-should-tune-my-car/
  • Replies 62
How much was the tune? Are you happy? Satisfied?
Nick is excellent on the dyno... he pushes out some great tunes and is willing to work with you to get the result your looking for. He's a wealth of knowledge, so listen up.
Also, don't take a half done car to the dyno, make shure everything is sorted out before you drop it off.
Cheers
Justin
$1000000
He's lying. It cost much, much more than that. He won't tell me either, it worries me that he's probably given up his first born son or something..
Slightly more on topic, I've heard a lot of good things about GT but it really comes down to who you talk to and what you're doing I think :) For what it's worth, I reckon I'll take my car to GT for it's first tune.
yeah it's around $800 for an epic tune.
Brad at Boost would be my choice if I was up north.
If you want a built engine, get that 26\30 that Jangles is selling in the other thread, it's only $4k!!!
haltech will run the shit out of it.
Applications: Nissan Skyline R32, Nissan Skyline R33 Variations: GT-R, GTS-t Engine Codes: RB25DET, RB26DETT
I heard Xrated has some epic turbos for sale. $2500, add a bit more for manifolds, fronts and dumps, and lines. Should be mint.
Edited by zoidbergmerc
well do you want big power or not spend lots of money? They're your two options :P
200kw at the treads is enough to have fun with though.
Nick @ GT Garage is back from Holidays next week, I found e-mail is the best way to contact him.
this thread has quickly turned into i want something but dont want to spend money.
Im not saying buy it, but you would be hard pressed to get anything near the cost.
Power costs money, for 210kw you dont even need a haltech, save your money, buy a nistune and then once youve got your new motor/setup buy a more capable ecu
    • If it dies, then bypass. The task isn't difficult. I have one running on a standard R32 FPCM. That's after nearly 20 years of it running an 040, which pull substantially more current than the Walbro. They're not the same module, but I'd hope it indicates that the R33 one should be man enough for the job. I think people kill them when putting proper sized pumps on them, not these little toy pumps we're talking about here.
    • Silicone spray won't hurt anything. And if it does, that's an opportunity to put some solid steel spherical bushings in, so you can really learn what suspension noise sounds like, If you're going to try it, just spray one bush at a time, so you can work out which one is actually noisy. My best guess is that if the noise started only since putting the coilovers in, then it is just noise being transmitted up through the top mounts of the struts, and not necessarily "new" noise from bushes. But it's almost impossible to know.
    • Are you saying the 34 is SUV height, and not that we're talking about an SUV here? (because if we're talking about an SUV, you don't fix them. You just replace them when something breaks. Not worth establishing sufficient emotional connection with an SUV to warrant doing any work on one). I wouldn't jack my car up on a short little loop of 10mm steel rod poking out through a hole in the bumper bar, front or rear end. I realise that we're probably not talking about that type of loop at the front, being the one under/behind the bar on a Skyline.... but even for that one, trying to jack up on what amounts to a thin piece of steel, designed purely for withstanding a horizontal tension force, not a vertical compressive force (and so would be prone to buckling/crushing) and, my most particular bitch about it - located RIGHT AT THE EXTREME FRONT OF THE CAR, applying a load up through the radiator support panel, etc, with almost the entire mass of the car cantilevered between there and the rear wheels? Nope. Not doing that. Not on the regular. That structure out there in front of the front crossmember is not designed to carry load in the vertical direction. Not really designed to carry any load at all, really. The chassis rail that the tow point is connected to would be fine loaded in tension, as per towing. Not intended to carry the mass of the whole car, especially loaded all on one rail, with twisting and all sorts of shitty load distribution going on. No, I will happily drive up on some pieces of wood, thanks. That can only happen on driven wheels, and they are at the other end of the car, and this problem does not exist at that end of the car. And even then, I have been known to drive up on at least 1x piece of 2x8 each side at the rear, simply to reduce the amount of jack pumping necessary to get the car up high enough for the jack stands. What really really shits me about Skylines is the lack of decent places for chassis stands at either end of the car. You'd think they'd be designed into the crossmembers.
    • I've got MCA Blues on my V36 Skyline, and while I've managed to sort out issues with scrubbing/bottoming out by raising it a smidge and increasing the damping hardness, the rear end still sounds *super* noisy when driving on anything other than the flattest surface imaginable. It sounds like a small party of flamingos are just chatting away in the back, which makes me think there are several link points in the suspension contributing to the noise. Am I hearing dried out/worn bushings? None of it sounds like metal-on-metal, it sounds more like hard rubber squeaking on metal. It's been suggested that a bit of silicon spray on each bushing might quiet them down, but I'm not sure what material the current bushings are made of (probably factory, I imagine) and whether silicon spray will degrade that material.
    • The obvious answer here is get a ND2/3 RF with the Targa top. The red is nicer, too!
