Series one and two headlights are different for OEM the series one has a flatter bottom while the series two goes down more and flicks up closer to the grill.
Sedan headlights are all the same, its the outer shape that you need to worry about.
Differance between S1 & S2 from what I can see is that they changed the look on the inside slightly and added height adjustment.
  • Replies 478
Quick update: $500 including shipping....still trying to negotiate and bring it down further.....have told the seller that we are ready to wait a bit longer with respect ro change in shipping methods which could bring the cost a bit down...will keep u guys posted.....
Guys have a look at this link and see if this is the right model...My link
Edited by shiva
Finaly cost is $452 through sea shipping which will take 6 - 9 weeks......Please confirm the below list if you guys are still interested.....
Update list:
Chrome housing(Coupe Models)
1. Shiva
2. 81gSKy
3. Heretical
4. Bigdr33gtst (damian)
5. Nightcrawler
6. thinktea:
Black housing(Coupe Models)
1. Jawrgy
2. gkzlah
3. Mick_V35 (Mick)
4. Runner4life
5. Dreadnought
6. Mayo_85
Sedan: Black Housing
1. Howaitonaito, black housing series one sedan.
Edited by shiva
Confirmed for me: Dreadnought - Black housing
The link above looks right Shiva.
If there are any issues with HID Ballast, Series 1 or 2 etc, I'll work through them on the fly. I don't have any particular expertise here but am happy to test.
I'm also happy to work with the Melbourne/SA people to arrange distribution.
have already asked jesse to check the compatibility of these headlights for series 1 and series 2.....once we confirm the 12 pairs, then we can give jesse different address and he will give his NAB account to which we can transfer the money and he will ship the lights in packages of 2 pairs of lights.....as mentioned earlier, it will be by sea so wait time is 6 to 9 weeks.....
Confirmed List:
1. 4evershiva - Chrome housing
2. Dreadnought - black
Hi Shiva,
Thanks for all your work so far. I have series 3 (bi-xenon lights). Can I trouble you to just double check with Jesse that the series 2 coupe lights are compatible with the series 3 coupe lights. Shouldn't be a difference but wouldn't mind a double check.
Thanks,
Keith
Update list:
1. Shiva
2. 81gSKy
3. Heretical
5. Nightcrawler
6. thinktea:
1. Jawrgy
2. gkzlah
3. Mick_V35 (Mick)
4. Runner4life
5. Dreadnought
6. Mayo_85
I'm still in! WOOT! Can't wait to f@#$ off these oxidated headlights! LOL!
Confirmed List:
Chrome housing:
1. 4evershiva
2. 81gSKy y
3.Nightcrawler
Black housing:
1.Dreadnought
Hey Keith have already asked Jesse to check its compatibility from the early model to the latest...so he will inform me if there is any issues......COMMON GUYS, LETS GET THE LIST CONFIRMED AND GET THIS GOING AS JESSE IS NOT READY TO SPEND MORE TIME ON THIS BUY.......
Still in :)
Should we set an expiry date on the group buy confirmation? I'm not trying to pressure people but we could spin this out for months if not careful.
Edited by Dreadnought
    • GCG is a good company, they're a major distributor for Garrett in Japan as well.
    • Nah, OEM washer bottle and brake fluid reservoirs are fine I don't know what it is with the plastic that Mazda used, some plastics, like the washer bottle and brake fluid res are fine, and still look new after 20 years use, where as the coolant expansion tank, and PS reservoir, that I replaced with new OEM items when I first got the car, turned yellow and started getting brittle a few years later If the dirty yellow stained plastics didn't trigger me there wouldn't be an issue, but they did, much like the battery bracket....... Meh As for going back to work full time to support car stuff, nope, why, because I own a Mazda NC MX5, not a Nissan R series Skyline 🤣
    • I've never heard of CJ-motor, so can't advise you on them. I'd just go straight to GCG for a GCG highflow though. Seems no point to use a middleman. I'm somewhat surprised that the price on the CJ site is lower than the GCG retail price. Even though CJ would get a discount of some sort, you would hardly expect them to give up so much margin. Maybe the price is out of date? Having said that "I'd go to GCG"...when I did my highflow, I went to Hypergear. I did this https://hypergearturbos.com/product/rb25dethighflow/#tab-dyno-results with the R34 OP6 450HP profile. With the BB centre (extra $400) and intially with the standard boost actuator, but I eventually got him to send me the high pressure one when I got to the point of being able to actually use it. Ends up costing the same sort of money as the GCG highflow, but this is, of course, the turbo that I KNOW has a shorter length core and so moves the comp cover rearwards. The GCG apparently doesn't do that. My mechanic also swears by the GCG highflow, given that we have another turbo rebuilder who does something essentialy the same as theirs, using Garrett wheels. He says it stands up at really low revs and makes good power. I haven't pushed my HG highflow past ~240-250rwkW yet (should have a little more in it, but unclear how much) and it does have a fairly gentle boost ramp. OK, it's much better now that I have gotten my boost controller tuned up on it.  A lot of my earlier unhappiness was because I couldn't keep the wastegate flap as closed as it needed to be (including some mechanical issues). I'd still prefer it to boost up nearly as quickly as the stocker, and it certainly a bit slower than that. So maybe the GCG one is worth the first look (for you).
    • Ok thanks 🙂 I will higly consider this. Any "known" company for a good reviews and experience to send that off? Is that CJ-motor good one? Or go straight to GCG site? I need to use VPN to even find some of those "shops" let alone access them 🙂
    • You can literally put in as much WMI as it takes to quench the combustion totally (and then back it off a little, obviously), and it will keep making more and more power. The power comes from the cooling effect of the water (and the meth) and the extra fuel (the meth, which also has massive octane). It is effectively exactly like running E85. One might be slightly better than the other, but they are damn close. But with either you can lean on the boost or the timing (or both) waaaay more than with just petrol and the results are similar. Here's the first thing I googled for an anecdotal bit of evidence. Can't access the attachment without being a gold member, but it is there for the getting if able to, or searched up elsewise perhaps. https://www.hpacademy.com/forum/general-tuning-discussion/show/wmi-vs-e85/
