Hi all , before I start I am NOT looking for cylindrical metal cored cats so please don't go there .
I have been searching for ceramic cat converters because I want a 3" one with a coated ceramic matrix . I want it to look like a cat because it IS a cat and it isn't needed for mega power - about 230-250 wheel Kw .
My GTS25T has had one for years and when I bought it there were two sizes of body basically big and small . The big one had a wider "biscuit" and would have been the higher flowing one of the two . I can't remember but it may have been a Catco .
Can anyone in the know point me towards the big style of oval ceramic cat with 3" fittings if they still exist .
I have not and WILL not use the shiny round cats because they are not legal and won't pass a road side inspection , something that attempts to look and smell like a real cat would and thats what I want .
Thanks in advance , cheers Adrian in Sydney .
They don't look like anything OE and I reckon if you'd done and emissions test it wouldn't pass .
I searched and eventually found what I was looking for which is a Catco 8007 . Big bastard at 7 point something litres and I thing 16 inches long . I think I remember the one on my R33 barely fitting between its direct fit flanges so if its can volume and biscuit frontal area are larger it should have less resistance to exhaust flow .
This is not where I found it , that was Sumit Racing , but if you scrol down to the cutaway pics on the left hand side you can see the differences .
http://www.catco.com.au/products.htm
Cheers A .
Catco last I looked were the only company who made cat converters that actually pass emissions and are have been certified by EPA testing. My car had a 2.25" Magnaflow compliance cat on it, compliance shop sure did a bodgy job on the flanges and cat temp sensor though.
Pretty sure xforce make them, high flow in ceramic stock looking shape. But from what I've read, they are dick shit. Catco's are good. there is a company, Australian, metal cat, they make legal metal high flow cats.
  • 3 weeks later...
The story I'm getting from exhaust people is that those metal cats don't look remotely like any OE or aftermarket replacement and that its up to the vehicles owner to prove the emissions are legal . I think 99% of the time that if a cop or RTA inspector goes looking and finds what looks like a conventional cat and the exhaust doesn't smell acrid they'd be happy . I'm sure these larger body and matrix area ceramic cats are no major issue for the 220-230 Kw I'd like from my Evo and I don't think they are real dear to buy .
A .
A .
My old car ran a gutted cat, I had no idea, it really didn't smell any different to my current car when it was with the stock cat or the metal cat. The RTA/Police are not legally able to dismantle your car on the street, they will have no idea if you have a piped, gutted stock cat, unless you're shooting flames.
Edited by SargeRX8
Its not like the cat glows red hot at idle, on the dyno sure but there's no way an infra-red temp gun would pick up much difference on the side of the road. I have heard stories of cops sliding fiberglass rods up the exhaust to check the core is still in place but they couldnt fine you as it may have just fallen out.
I made 230kw on a rubbish 2.5 inch dump and small ceramic cat. (although that was on e85) Im sure a large body ceramic cat would flow what the OP wants it to.
I would just fit a $150 100cpsi metal cat. :whistling:
Wouldent be glowing red, But i would think a temp gun on a punched cat would be alot cooler then a Complied Cat. The CAT in theroy should also be hotter then the rest of the piping back to the exit.
I would also think the only way you'd get pinched is a Road side inspection bay......Stand DECCA emmisions test you would just swap to a std cat, Though even then they would only test for what the Notice is for, Though i vaguely remember him checking the temp of my cat
have you thought about getting a used XR6 turbo cat?
That's what I would have suggested. And they will totally pass an emissions test the bf cats are euro4 compliant. Get bf cat it flows more than the ba but you may need to weld some flanges onto it to make it work.
    • I'm looking for some real world experiences/feed back from anyone who has personally ran a EFR7670 with a 1.05 exhaust housing or a .83 I'm leaning towards the .83 because its a street car used mostly for spirited driving in the canyons roads. I"m not looking for big numbers on paper. I want a responsive powerband that will be very linear to 8000 rpm. I dont mind if power remains somewhat flat but dont want power to drop off on top. The turbo I've purchased is a 1.05, although the mounting flange T3 vs T4 and internal vs external waste gates are different on both housings, I not concern about swapping parts or making fabrication mods to get what I want. Based on some of the research I've done with chat gpt, the 1.05 housing seems to be the way to go with slightly more lag and future proofing for more mods but recommends .83 for best response/street car setup. AI doesn't have the same emotions as real people driving a GTR so I think you guys will be able to give me better feed back 😀
    • Surely somebody has one in VIC. Have you asked at any shops?  Is this the yearly inspection or did you get a canary?
    • This is where I share pain with you, @Duncan. The move to change so many cooling system pieces to plastic is a killer! Plastic end tanks and a few plastic hose flanges on my car's fail after so little time.  Curious about the need for a bigger rad, is that just for long sessions in the summer or because the car generally needs more cooling?
    • So, that is it! It is a pretty expensive process with the ATF costing 50-100 per 5 litres, and a mechanic will probably charge plenty because they don't want to do it. Still, considering how dirty my fluid was at 120,000klm I think it would be worth doing more like every 80,000 to keep the trans happy, they are very expensive to replace. The job is not that hard if you have the specialist tools so you can save a bit of money and do it yourself!
    • OK, onto filling. So I don't really have any pics, but will describe the process as best I can. The USDM workshop manual also covers it from TM-285 onwards. First, make sure the drain plug (17mm) is snug. Not too tight yet because it is coming off again. Note it does have a copper washer that you could replace or anneal (heat up with a blow torch) to seal nicely. Remove the fill plug, which has an inhex (I think it was 6mm but didn't check). Then, screw in the fill fitting, making sure it has a suitable o-ring (mine came without but I think it is meant to be supplied). It is important that you only screw it in hand tight. I didn't get a good pic of it, but the fill plug leads to a tube about 70mm long inside the transmission. This sets the factory level for fluid in the trans (above the join line for the pan!) and will take about 3l to fill. You then need to connect your fluid pump to the fitting via a hose, and pump in whatever amount of fluid you removed (maybe 3 litres, in my case 7 litres). If you put in more than 3l, it will spill out when you remove the fitting, so do quickly and with a drain pan underneath. Once you have pumped in the required amount of clean ATF, you start the engine and run it for 3 minutes to let the fluid circulate. Don't run it longer and if possible check the fluid temp is under 40oC (Ecutek shows Auto Trans Fluid temp now, or you could use an infrared temp gun on the bottom of the pan). The manual stresses the bit about fluid temperature because it expands when hot an might result in an underfil. So from here, the factory manual says to do the "spill and fill" again, and I did. That is, put an oil pan under the drain plug and undo it with a 17mm spanner, then watch your expensive fluid fall back out again, you should get about 3 litres.  Then, put the drain plug back in, pump 3 litres back in through the fill plug with the fitting and pump, disconnect the fill fitting and replace the fill plug, start the car and run for another 3 minutes (making sure the temp is still under 40oC). The manual then asks for a 3rd "spill and fill" just like above. I also did that and so had put 13l in by now.  This time they want you to keep the engine running and run the transmission through R and D (I hope the wheels are still off the ground!) for a while, and allow the trans temp to get to 40oC, then engine off. Finally, back under the car and undo the fill plug to let the overfill drain out; it will stop running when fluid is at the top of the levelling tube. According to the factory, that is job done! Post that, I reconnected the fill fitting and pumped in an extra 0.5l. AMS says 1.5l overfill is safe, but I started with less to see how it goes, I will add another 1.0 litres later if I'm still not happy with the hot shifts.
