Just wanting to know if there's any recommendations for Advanced Driving Courses in melb?
Especially after the GOR cruise and really, never having driven so hard before, trying to keep up with everyone, I'm keener then ever to do a few courses!
I've got a few mates who wouldn't mind doing it too.
So, past experiences? Money for value places? etc.
And do they check your car for mods? One of my mates is a P plater (like myself) who has extractors and a couple other things that technically we shouldn't have.
https://www.sau.com.au/forums/topic/392284-advanced-driving-courses/
Driver Dynamics for sure. I did their base course and it was great. They also do other days like track and skidpan days.
Bec works for them, so maybe shoot her a PM or give her a call? 1300 652 693
I did the level one course with Drivers Dynamic a couple of months ago, although it wasn't as fun as I expected, but I did learn a couple of things about braking, I wouldn't mind trying the level two course on a skid pan lol
You would find it quicker to ring Bec at Driver Dynamics on 1300 652 693.
They could still be doing there $99 deal .
I'm keen on an advanced drivers course too. Would it be possible to organise a SAU driver day?
We prob won't look to do one as we don;t ahve the resources that folks like Drivers Dynamics have.
I would suggest getting a few mates together and give Bec a call.
Also I think (Bec can you confirm) if you are a SAU paid member you get a 10% off the entry (excluding the $99 summer special)
    • Yeah well per the video it took 15s for the stock unit to start up....even if I give it a few seconds discount for starting that is at least 12 sec before you get a reverse camera if you are trying to leave a park.  The android unit is way faster, but 2016 for the stock unit is a long time ago in consumer electronics
    • Yea that’s why I said ima test them with multimeter and see the reads.
    • Only at idle. Isn’t a problem when rev it seems.
    • @Haggerty This seems silly to ask, but are you confident in your ability to tune the Haltech?
    • Next on the to-do list was an oil and filter change. Nothing exciting to add here except the oil filter is in a really stupid place (facing the engine mount/subframe/steering rack). GReddy do a relocation kit which puts it towards the gearbox, I would have preferred towards the front but there's obviously a lot more stuff there. Something I'll have to look at for the next service perhaps. First time using Valvoline oil, although I can't see it being any different to most other brands Nice... The oil filter location... At least the subframe wont rust any time soon I picked up a genuine fuel filter, this is part of the fuel pump assembly inside the fuel tank. Access can be found underneath the rear seat, you'll see this triangular cover Remove the 3x plastic 10mm nuts and lift the cover up, pushing the rubber grommet through The yellow fuel line clips push out in opposite directions, remove these completely. The two moulded fuel lines can now pull upwards to disconnect, along with the wire electrical plug. There's 8x 8mm bolts that secure the black retaining ring. The fuel pump assembly is now ready to lift out. Be mindful of the fuel hose on the side, the hose clamp on mine was catching the hose preventing it from lifting up The fuel pump/filter has an upper and lower section held on by 4 pressure clips. These did take a little bit of force, it sounded like the plastic tabs were going to break but they didn't (don't worry!) The lower section helps mount the fuel pump, there's a circular rubber gasket/grommet/seal thing on the bottom where the sock is. Undo the hose clip on the short fuel hose on the side to disconnect it from the 3 way distribution pipe to be able to lift the upper half away. Don't forget to unplug the fuel pump too! There's a few rubber O rings that will need transferring to the new filter housing, I show these in the video at the bottom of this write up. Reassembly is the reverse Here's a photo of the new filter installed, you'll be able to see where the tabs are more clearing against the yellow OEM plastic Once the assembly is re-installed, I turned the engine over a few times to help build up fuel pressure. I did panic when the car stopped turning over but I could hear the fuel pump making a noise. It eventually started and has been fine since. Found my 'lucky' coin underneath the rear seat too The Youtube video can be seen here: https://www.youtube.com/watch?v=uLJ65pmQt44&t=6s
