My idiot neighbour decided to restore a boat in his front yard.
He sprayed it with white 2 Pac last Thursday and over the weekend after washing it I've noticed the whole car is covered.
The car was locked up in a garage but the paint mist entered the top vents and settled everywhere.
I've tried on the wing paint cleaner and a cleaner wax, but won't come off.
If you pick hard with a finger nail at a spot, it will come off, but a scratch remains.
He said he will have it cleaned up at his expense but I'm worried it will be cut back heavily.
And yes the car is black, so every spot shows. It's all over the glass and lights too.
Are there any special products made or any secret methods I could suggest ?
cheers.
https://www.sau.com.au/forums/topic/392448-how-to-remove-overspray-please-help/
I was told, polish will get it out, if its just a fine mist layer of paint.
Get a buffer and go about it as you were to polish your car and it should take off the mist layer of paint.
I did this on my car but it had a little built up of sticky grime, which had harden and I took it of with the polish.
But best to PM Craved, he has given me awesome tips on paint as he deals with that for a living.
And go with what he thinks, I'd say.
Get a clay bar and get going, be very are full about polishing cos ur gonna have swirl city.
If he's happy to pay for it then it's gonna cost him about $300 take it to a proper detailer, one who knows how to go about "paint correction"
If you can wash a car & chamois without scratching; you can use a Clay bar.thumbsup.gif
I've had to remove overspray exactly like you're dealing with; Clay bar FTW!
Check this "How to"; http://www.bowdensown.com.au/I_Like_It_Smooth
As all have said,
Personally, i'd do this -
1) Go to super cheap auto and purchase -
- Meguiars quick clay bar kit
- Meguiars ultimate compound
- Meguiars ultimate polish
- Meguiars ultimate wax
2) apply in that sequence with either a DA polisher or by hand.
3) Send your neighbour the bill.
If your scratching the paint with the clay, chances are theres not enough lubrication - so use the quick detailer which comes in the kit regularly. Wash the car first and always knead the clay so your working with a clean side and if you drop it - throw it out and dont reuse. I always set up a blanket / mat on the area that im working with so if i drop the clay - it doesnt go to waste. Thats the only reasons i could think why the paint would be getting scratched.
Hope it helps.
    • Well GTSBoy, prepare yourself further. I did a track day with 1/2 a day prep on Friday, inpromptu. The good news is that I got home, and didn't drive the car into a wall. Everything seemed mostly okay. The car was even a little faster than it was last time. I also got to get some good datalog data too. I also noticed a tiny bit of knock which was (luckily?) recorded. All I know is the knock sensors got recalibrated.... and are notorious for false knock. So I don't know if they are too sensitive, not sensitive enough... or some other third option. But I reduced timing anyway. It wasn't every pull through the session either. Think along the lines of -1 degree of timing for say, three instances while at the top of 4th in a 20 minute all-hot-lap session. Unfortunately at the end of session 2... I noticed a little oil. I borrowed some jack stands and a jack and took a look under there, but as is often the case, messing around with it kinda half cleaned it up, it was not conclusive where it was coming from. I decided to give it another go and see how it was. The amount of oil was maybe one/two small drops. I did another 20 minute session and car went well, and I was just starting to get into it and not be terrified of driving on track. I pulled over and checked in the pits and saw this: This is where I called it, packed up and went home as I live ~20 min from the track with a VERY VERY CLOSE EYE on Oil Pressure on the way home. The volume wasn't much but you never know. I checked it today when I had my own space/tools/time to find out what was going on, wanted to clean it up, run the car and see if any of the fittings from around the oil filter were causing it. I have like.. 5 fittings there, so I suspected one was (hopefully?) the culprit. It became immediately apparent as soon as I looked around more closely. 795d266d-a034-4b8c-89c9-d83860f5d00a.mp4       This is the R34 GTT oil sender connected via an adapter to an oil cooler block I have installed which runs AN lines to my cooler (and back). There's also an oil temp sensor on top.  Just after that video, I attempted to unthread the sensor to see if it's loose/worn and it disintegrated in my hand. So yes. I am glad I noticed that oil because it would appear that complete and utter catastrophic engine failure was about 1 second of engine runtime away. I did try to drill the fitting out, and only succeeded in drilling the middle hole much larger and now there's a... smooth hole in there with what looks like a damn sleeve still incredibly tight in there. Not really sure how to proceed from here. My options: 1) Find someone who can remove the stuck fitting, and use a steel adapter so it won't fatigue? (Female BSPT for the R34 sender to 1/8NPT male - HARD to find). IF it isn't possible to remove - Buy a new block ($320) and have someone tap a new 1/8NPT in the top of it ($????) and hope the steel adapter works better. 2) Buy a new block and give up on the OEM pressure sender for the dash entirely, and use the supplied 1/8 NPT for the oil temp sender. Having the oil pressure read 0 in the dash with the warning lamp will give me a lot of anxiety driving around. I do have the actual GM sensor/sender working, but it needs OBD2 as a gauge. If I'm datalogging I don't actually have a readout of what the gauge is currently displaying. 3) Other? Find a new location for the OEM sender? Though I don't know of anywhere that will work. I also don't know if a steel adapter is actually functionally smart here. It's clearly leveraged itself through vibration of the motor and snapped in half. This doesn't seem like a setup a smart person would replicate given the weight of the OEM sender. Still pretty happy being lucky for once and seeing this at the absolute last moment before bye bye motor in a big way, even if an adapter is apparently 6 weeks+ delivery and I have no way to free the current stuck/potentially destroyed threads in the current oil block.
