Thanks alot lads, looks like im doing something right then!! If only i didnt live out in the middle of nowhere, we could cruise out ( Talking to my W.A brothersthumbsup.gif)
Parcel has arrived, just gotta find time to fit it. CAN NOT WAIT
okay okay
full SUPERIOR AUTO CREATIVE DASH SURROUND, door switch panel, gear and handbrake boot, east bear clear indicators and nismo smoked repeaterslaughing-smiley-014.gif
  • Replies 102
Posted Images
Looking great, the blue headliner lights wouldn't go with mine as I have a green roll cage lol but looks good.
I think I have seen the Superior Auto interior panel things from Nengun also however I dare say the RHD Japan may be a little cheaper than Nengun
Great stuff :thumbsup:
cheers marty!!
the dash panels are stick on, i dont think you can get a full dash replacement...
finished it off today
new dash set up complete and smoked repeaters in
Edited by JDM33
  • 3 weeks later...
thanks lads im doing my best!
im loving the nitto's, i dont drive the care in the wet so i dont have to worry about wet weather performance but for day driving and some spirited driving i think its more than enough.
When they start to let go its very audible and progressive, i got no grimes with them anyway
  • 4 weeks later...
small update, changed indicators to East Bear crystals. Waiting on my order from japan is the only thing thats happening so far. Replaced gear boot and handbrake boot with black leather with red stitching. Small change but visually its a huge difference
one next to my ute which il be selling soon!!!
IMG_1332.jpg:action-smiley-069:
  • 1 month later...
:action-smiley-069:
been awhile. Since then this has happened
BRIDE GIAS II LOW MAX seats with low rails + Auto Select front lip.
Car is gonna get some suspension work in the garage soon. Hit up my blog for more details :domokun:
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
