Apart from Unique Autosports does anybody else make the brake caliper adapters to go from 296mm to 324mm rotors?
These are to use the stock GTST calipers with the larger GTR rotors (going to use the 2-piece ATTKD rotors I think).
If not I guess I'll just have to fork out the $350 for the adapters.
ADAPTERS
https://www.sau.com.au/forums/topic/393583-brake-adapters-gtst/
  • Replies 56
I recommend people ring a few machine shops and get some hourly rates from them. Unless you have a mate with the tools required who will do it for a case of beer, you will be in for a rude shock. $350 is pretty good value.
I will guess and break it down. $100 in material inc wastage which you have to pay for. That leaves $250 for labour, which is $125 each. So you think it can be done in less then an hour each...inc anodising?
Sure they are not cheap, but they are reasonably priced and having done these adaptors loads of time myself....you will be hard pressed to do it cheaper and get a known end result. My opinion only :cheers:
I will guess and break it down. $100 in material inc wastage which you have to pay for. That leaves $250 for labour, which is $125 each. So you think it can be done in less then an hour each...inc anodising? Sure they are not cheap, but they are reasonably priced and having done these adaptors loads of time myself....you will be hard pressed to do it cheaper and get a known end result. My opinion only
You're looking at it wrong. These are not being made as one offs. They are made in bulk. Maybe not huge numbers, but enough of a batch size to make the manufacturing more efficient. So on that basis, the material value in the adaptor itself wouldn't want to me be more than $25, including wastage. The fasteners are only going to be <$20 as well. Machining won't consume an hour each, and anodising is a batch process.
At $350/pr retail they are hard to justify. It would be hard to make them yourself at any decent saving, but that's not the point.
And I know what I'm talking about. I get stuff fabricated all the time, out of much more exotic materials than a bit of steel or 4041 (think inconel and other high temperature alloys - much harder to machine for a start). I know what one off cost and what you can save when the shop can tool up to do a run of them.
Diffence in opinion :) I will add what quantity do you think these are getting made in? I hear what you are saying, but it is likely to be quantities less then 10. Most shops would try and minimise the amount of dollars they have caught up in inventory.
Anyway, its a mute point. My perspective is if you are a business then you price a product to what the market will pay. And the average punter wont be able to do it much cheaper. Hell most punters wont be able to install the kit let along fabricate their own.
The beauty of forums are that you can learn so much and follow the DIY path. If you think its a rip and can do it cheaper then go for it. :thumbsup:
There is a guy (too much boost) selling a kit like this from SBS at the moment for a song at $500 inc rotors, calipers and mounts. just go buy that and sell your current calipers to an S13 owner. My thoughts are the 280mm kit is superior to the 296 kit anyways.
Yep $350 is probably too much for me. I thought there were other people on this forum who might have access to same/similar items for less.
Indeed you price at what the market will pay in order to get the best return. I don't think I will be paying $350 for these but I might (nahh...probably not). oohhh wait actually......meh.
Just buy these.... http://www.skylinesaustralia.com/forums/topic/385995-fs-330mm-big-brake-kit/page__p__6260824__hl__brake__fromsearch__1#entry6260824
$350 is a steal. By the time you mess around with someone machining them up and finding out they don't fit correctly blah, blah, blah...if they bolt on with simple cutting of backing plate then its a good deal. Many of the cheaper R33 kits are 3 piece brackets and that in my eyes is pretty nasty compared to the one piece UAS ones
have a look at this
http://www.ebay.com/...RS:1123&vxp=mtr
states 240sx(180sx s13) but its a direct bolt on for 32 gtr
also check these out the bolt up too will be gettin these for mine soon
have a look at this
They won't be a straight bolt up on an R32 GTR; you'll need a 340mm rotor.
If you have Z32 or R32 GTSt calipers, as std they run 280mm rotors.
R33 GTS25T and R32 GTR calipers have longer lugs to suit the larger diam 296mm rotors so if you were to use those brackets with R32 GTR calipers then the fit would be an absolute abomination, like posted above they are more suited to a 337-340mm rotor
how do u come to this conclusion ? "Abomination" ? I dont understand a few ppl i know have these on there cars and theyre fine 12.75 inch equals 324mm rotor which is r32 gtr vspec disc size or 350z standard rotors ppl want cheap and effective i dont understand where u get 340mm from
oh n one of those has a z32 300zx with them n theyre nuts
Edited by Travis32
Travis, you're completely missing the point. The Autosport ones ONLY suit calipers that came on cars with 296mm rotors. The cheaper ones from eBay are designed to suit calipers from cars with 280mm rotors. If you look carefully at the two different adaptors you will see that they are completely different design. The cheaper ones just push the 280mm legged caliper out to the 324mm rotor position. It does that radially. The Autosport one pushes the 296mm legged caliper out to the 324mm rotor position also, but because there's not enough room to do this purely radially, the adaptor also has to move the caliper around circumfrentially a little to provide room for both sets of fasteners. THIS is the giveaway that tells you you're not looking at the same thing. If you apply the 280-324 adaptor to the 296mm caliper, it will push it out even further than the 324mm position. About 340mm in fact. It is important to remember that the Z32 uses the same sized caliper as the R32, not the R33.
You do understand that the calipers used on an R32 GTR ARE NOT the same as as an R32 GTR V Spec?
These adaptor will only work with R32 GTS or 200SX Calipers; the ones that go with a 280mm x 30mm rotor. This is how you get to a 324mm rotor. These brackets are designed to work with a 324mm x 30mm 350Z Brembo rotor; the offset of the GTR Brembo 324mm x 30mm rotor is unsuitable, and also more expensive.
Applying the same dimensions (a 44mm dia increase) using an R32 GTR Caliper (which uses a 296mm x 32mm rotor) ; you end up with a 340mm rotor.
This is the last post I will make on the subject; You can argue if you like, you can even go and buy the brackets. In fact, I encourage you to do so. thumbsup.gif
You will then discover that; surprise surprise, they don't fit.
I have no problem with cheap, effective improvements, but this will not be one.
Edited by Daleo
    • So, I started this repair and got as far as "fixing" the holes with some fibreglass. God all those years working on boats came back quickly. I decided I'd reach out to some rust guys just to see what they would say about it. I came across a guy about 40 mins away and went to see him. He said the windscreen needs to come out, that there might be some more bits around the windscreen and he'd quote them at the time. But his quote was $300 to remove and replace windscreen and $3k for the damage he can see. He said he could respray the roof for $1200 and the bonnet for another $800 (somebody has previously rattle canned it, its horrendous). This is $5300 + any small additional bits. It's a lot, I get that and the name of one of my fave youtube channels 'Not Economically Viable' comes to mind.  I'm not being financially rational, but I've taken him up on the quote. He's opening a new shop in November with more room, so we're waiting for that. I'll leave the currently missing headliner out until then. I'm looking forward to it being fixed and having the paint looking nice again (lots of clear coat issues on the roof too). / flame suit on.
    • Oh and some up-and-comings; New rear drivers wheel bearing. I'll do that this weekend while the diff is out. The car is already up and the d/c axles and missing exhaust will help with space. This is the last bearing for me to do and I've been dragging my feet on it. I also have some new EBC blue stuff pads for the car and some new brake fluid. I haven't ever flushed the fluid in this car and looking forward to it. I have 600 degree fluid to put in. Not exactly "race fluid" but better than the typical stuff I have been using.
    • A proper clutch/plate type mechanical diff with quite a lot of pre-load and high locking % is better for drifting. Much more consistent in its behaviour. A helical can be annoyingly vague and inconsistent in how it responds under the sorts of abuse found in drifting.
    • Some updates here. I pulled the entire interior out, minus some trim to respray the seats with Colourlock dye. It turned out really nice though I accidentally let the dog in the car after and she scratched up the front seat.  This is what it looked like before, the colour was just washing out everywhere but thankfully the leather was in good nic. Then after the respray   And after the bloody dog jumped in The headliner is out waiting to be retrimmed, but it will stay out now until Nov - see why below. I replaced the stereo/headunit with a period-styled Android headunit. I have no after pics, but I'll get some. This is because of the missing pixels. I tried to fix this twice with replacement ribbon cables but couldn't. Also the bluetooth interface I'd bought for this was crap. Then there's the rusty roof. Pics and info in this other thread. I have decided to get this repaired professionally, but I'll update that thread. This is why the headliner will stay out for now. I'll be getting the roof and bonnet resprayed at the same time the rust is fixed. I also had an interesting issue with my drivers door lock.  For a small period I was having issues getting any 12v power to the car - I mean *any*. It would have no dash lights, nothing. It happened while I was at the shops and I couldn't get in the car. So, we had 2 problems. The most pressing here is that I was locked out. I have only a single physical key hole on the car, the drivers door and no amount of turning would unlock the car. Surely it doesn't need power for this? The second issue is why am I losing all power periodically, The battery isn't dead, its almost like the battery isn't even there. Two issues that were surprisingly easy to fix. You fellow BMW over-engineering lovers will appreciate this. The lock in the door has 5 states; mechanical lock, electric lock, neutral, electric unlock, mechanical unlock achieved at -90 degrees, -45 degrees, 0 degrees, 45 degrees and 90 degrees. Although, the unlock is towards the front of the car, so opposite for LHD countries. Sticking the key in and turning 45 left or right is what is used 99% of the time. It activates the central locking etc. 90 degrees is for dead battery access and, obvs, only un/locks the one door. But because the mechanical lock is never used and is 27 years old, it seizes up. I was totally unable to turn the key far enough to get to the mechanical unlock (At the time of locking myself out, I didn't even know this was a thing). I eventually did it with some vicegrips and teflon spray.  I made a quick vid for other E39 peeps.   The battery issue is totally new to me also - It wasn't making sufficient contact between the post and the terminal. The terminal was bolted on tight, but the car wouldn't have power. After checking the battery with my multimeter I accidentally contacted the terminal and the battery post and the car got power. The battery was only a few years old and in good condition. I cleaned the post and the terminal with a wire brush, bolted it back on tight and never had the issue again. I'm still surprised that despite having solid contact it didn't work. Also, the car was getting Warragamba sized pools of water in the back when it rained. My initial concern was another rust problem. But when I went out on Weds while it was raining and while I had no headliner in I could see a steady stream of water coming through the roof mounted aerial. As this aerial is for the (now removed) car phone I pulled it out and whacked a blanking grommet in the hole. It seems fine now. I'm thinking I might get the hole permanently filled when the rust is fixed. Moving forward and things in progress; The tailgate needs some attention. I have taken all the trim off to clean it all and address some small rust spots. I have partially done all of this but I'll finish it up hopefully this weekend. As all the trim are now entirely devoid of trim clips I have bought a heap of strong velcro and I'm hoping it does a good enough job as any of this trim in good condition is super expensive and usually in Europe as we dont have many of the wagons here. Suspension and brakes!!! This is exciting. In the front; New control arms New sway bar links New lower Eibach springs (the only modification I'm planning on this car) M Sport shocks (these came with the car and will replace the longer shocks in the car) New top mounts Used 540i calipers (stock brakes suck!) New 540i disks and pads (22x296 mm for 528 and 30x334 mm for 540i) New front wheel bearings (thank all that is holy for bolt on bearings!) Annnnd in the back; New control arms New sway bar links Adjustable air suspension arms (fool the car into what the current height is so the self levelling suspension can match the new front ride height) New ball joints I'll also be doing a brake fluid flush while I'm in there. I'm planning on switching the car over to the 16's that came with it so I can clean up and respray the M Sport 17's. They've lost a lot of colour over the years and have some gutter rash. None of this will start until the E90 is back.
    • You mean you will regret it for drifting duties? I don't quite follow.
