Hi all,
I have a problem and wondered if you can give me your thoughts please.
I have a 1998 R34gtt with about 70,000 miles and running a GT3076r and a Link G4 plug and play ECU running a 5 bar map sensor. It's been mapped on a dyno dynamics rig to 498hp at the flywheel. Internally it's stock apart from a 1.6mm metal head gasket. (Fmic, oil cooler etc) I have done 9000 miles with the car in this spec.
The problem:
Yesterday the water temperature started to climb, which also caused the oil temps to rise. General overheating occurred which resulted I'm a peak temp of 101 deg oil temp and 120 deg water temp before I shut it down. It will cruise on the motorway off boost for quite a while (70+ miles) and stay under 100deg water temp and about 85 deg oil. However, when you hit roundabouts or built up areas and speeds below 40mph she starts to overheat, heat soaks everything and it's all over. The top hose feels hard.
I pulled the thermostat and that's working properly. I pulled the water pump and that's perfect too. I have re-bled the cooling system and that's got no air in it either.
I think that the head has lifted and probably caused gasket failure between the water passage and cylinder or I have somehow cracked the head. But can anybody else give me any better ideas?
Cheers
Chris
https://www.sau.com.au/forums/topic/394441-rb25det-neo-water-temp-problem/
Is the radiator fan operating correctly? Assuming the OEM fan and shrouds are all in place.
Do you have evidence of coolant in the engine oil, or oil in the coolant?
probably the radiator
mine (50mm jjr one) got clogged (flushed the system with the cleaner stuff before i put the new rad on, but it just loosened it all up and eventually washed it into the new rad)
see if you can get it cleaned out
i ended up getting a new stock size rad off ebay (koyorad) for about AU$220 (the top tank split on my old stocker, hence the new alloy one)
  • 3 weeks later...
Okay now I'm totally boggled.
I have done a block test and it's come up clean, I have done a compression test and it's come up at 140psi (give or take) right across the board.
Oil is good, water is clear...
Took it out for a drive and boosted it to 1.4 bar. No problems until it got hot. When its at good temperatures it boosts fine, when it gets hot!- its almost like it hits a boost cut or is blowing out the spark when it hits high boost and WOT.
Engine doesn't overheat when standing idle ticking over - warms up correctly. Doesn't increase in temperature when already hot/overheating when then left to idle.
Plugs looked a good colour, not black or sooty, not white or charred. A nice light brown colour.
Drives perfectly fine off boost. ECU doesn't throw any other fault codes.
Engine doesn't smoke or pop balls of smoke in any way.
Does anybody have ANY idea? I'm utterly stumped.
Could the turbo be on its way out and cooking the water? It's only 10k miles old and doesn't make any noise or smoke?
Somebody mentioned that when the bearings are really warn they cause excess heat? But wouldn't this happen when just driving normally off boost too?
I really just have no damn idea.
Do a leak down test sounds like hg I recently bought a 26 with a busted head gasket was running fine just getting hot pulled the head off and the gasket was gone. Replaced it did a leakdown and cam back perfect results
In terms of cost and ease, you'd be better of trying to put a stock radiator in and retest (put the shroud back on too with the stocker radiator).
much quicker, cheaper and easier than pulling the head off.
Radiator cap in good condition?
New ones from Nissan are pretty cheap.
Edited by GTST
This is because the Link will have a temperature MAP lockout. Once it goes over 100'C it should throw a CEL to tell you. And anything over 100'C the MAP limit will more than likely be alot lower.
    • Oh dear. The panel beating needs to be done before the filler work. Do you have a photo of the dent before you started? Hard enough to not flex and only hit the high spots?  What do you mean it was just temporary?
    • Can u check this way it works for power supply?
    • These coils draw 10amps that what i read online
    • I appreciate the detailed explanation, think I understand now. I spent the better part of last night reading what I could about shuffle and potential solutions. I had replaced the OEM twin turbo pipe with an alternate Y pipe that is separated further away from the turbo. The current one is from HKS and I had a previous pipe that was separated even further away, both have shuffle. I had heard that a divider can be welded in to the OEM pipe to remove turbulence, and figure that aftermarket pipes that are more separated would achieve the same thing. From what I read, most people with -10 turbos get shuffle due to their size, though it's a bit less common with -5s on a standard RB26. I think Nismoid mentioned somewhere it's because OEM recirculation piping is common in Australia with -5 cars. It seems that the recommendation tends to vary between a few options, which I've ordered in what I think is most feasible for me:  1. Retune the MAP or boost controller to try to eliminate shuffle 2. Install OEM recirculation piping 3. Something called a 'balance pipe' welded onto the exhaust manifolds. I don't know if kits for this are available, seems like pure fabrication work 4. simply go single turbo My current layout is as follows: Garrett 2860 -5s HKS Racing Suction intake MAF delete pipes HKS racing chamber intake piping hard intercooler piping,  ARC intercooler HKS SSQV BOV and pipe Haltech 2500 elite ECU and boost solenoid/controller HPI dump pipes OEM exhaust manifolds HKS VCAM step 1 and supporting head modifications Built 2.6 bottom end All OEM recirculation piping was removed, relevant areas sealed off I'll keep an eye out for any alternative solutions but can get started with this.  Only other question is, does shuffle harm the turbo (or anything else)? It seems like some people say your turbo shafts will explode because of the opposing forces after a while and others say they just live with it and adjust their pedal foot accordingly.
    • That worked out PERFECTLY! Thank you big time to JJ. He was able to swap me his stock diff. He drove all the way to me as well. Killer! Removal & install was pretty straightforward. The diff itself is HEAVY. So that’s a 2 man job.  Man does the car drive nice now! Couldn’t have worked out any better 👌
