Sunday 16th of May at Wakefield.
It is on again and this one will be far the most hotly contested events we have run. There are lots of GTR's out there that really want to have a go and knock me of the fence and beat my zed. ZED V's GTR challenge. This track suits 4WD so it should be interesting. I know of three guys who are very good drivers and have full race car R32 GTR's that I suspect will give my slot car a real challenge. Terry who owns the GIO Gibson GTR said he will be bringing it.
No track experience necessary and it is a very safe track. Always a big turn out of GTR's and GTS-Ts. Free to come watch, or if you want to have a go.
We will have events caller, transponders in each car for timing, trophies and a short drift comp in the middle of the day.
, :wassup: details and entry form on our site.
Short Vid of GTR's http://gtr.com.au/movies/wakefield.mpeg
https://www.sau.com.au/forums/topic/39491-uas-track-day-wakefield-16-may-04/
  • Replies 106
Carlo has organised a trackday at Wakefield for the day after (17th) so I might go and watch this UAS day, stay over at my parents place in Goulborn Sunday nite and then drive on the Monday event.
Yes I plan on doing the same. Double wammy. As long as my zed survives.
Might take another set of tyres.
I was so sure that this would be a video of a Zed overtaking a GTR at Wakefield....
...... but then I realised that a Zed would had to have beaten a GTR for you to have footage of it :):(:rofl: :rofl:
... is it limited to this track only?
and :bahaha: to you Merli
Better watch out tho, I seem to remember the z setting about 1.08 last year....which is pretty competitve....and thats before the franken-zed was updated again....
never copped a whooping befor, doubt it would happen, but we'll jast have to see, neer been to this race track so might be fun first time at the track and over all winner.
I think someone is setting himself up for a very hard fall :(
    • Power steering is probably because someone has nuked the HICAS CU and you no longer have the variable power asist doing what it is supposed to. How much boost are you running? You are aware that any more than 10 psi on the stock ECU is just asking for it to go to full R&R (that's Rich & Retard, which is effectively Retarded and Retarded!) which kills all the power. Depending on the exact conditions, it can just be runnign on the fat and stupid end of the maps, then the conditions change, you make a little more boost and the ECU goes into panic.
    • @BuiltNotBought Just as GTSboy said.   If you want driveabilty and more low down torque..keep the stock runners. They are VERY good from a factory. I have them too on my RB25DET NEO and as a GTSboy i have fmic but with stock piping route(i have Blitz intercooler) Iam making around 320 BHP and the car pulls "hard" from like 2,5k all the way to 7k. I have it dyno tuned to mimic N/A power curve and making little less max torque due to the smallbox tranny. But driveability is very great. I had 350Nm below 3k so car feels very quick.
    • Looking to sort out a couple of issues on my skyline  It recently was rebuilt, however rebuilder long story short did not give two flying effs about the work he did. So moving forward it's running but I have two persistent issues 1) it has a misfire / lag type of issue (was at higher RPMs but I had a dead piggy back ecu removed which improved it) now it's not as bad but still does it at random, I thought it may have been a boost issue I'm running an older turbosmart dual stage controller, turbosmart told me to try running off gate pressure however it still has a lag at random times. It has New MAF, maf plug, coil packs, sparks, CP harness.. injectors tested and cleaned. Factory ECU. 2) Power steering issue. It is tight as anything. Flushed power steering, rebuilt my pump because the bearing was shot. Flushed again still tight (mainly when parking and going slow into my driveway etc)  No kinks in hard lines, replaced the lines I could see had cracks. Still tough to steer.  I was told to shim a coin and place into the solenoid plug? Is there anything else. My steering angle sensor also has a issue. It's a used one I replaced, does it need to be calibrated? I feel like I've tried everything and this car is my voodoo doll.
    • Holy shit... wow!!! I totally missed this
    • One main filter. Each tank has a prefilter to keep rocks and small children out, then the big main filter that also does water separation. Clogged the first one so bad it was like a rev limiter at 3200rpm. Literally just like dropping the throttle off and maintaining rpm!
