Hmm ok. That does look a lot lighter then the momo steering wheel option.
There was a couple of options for woodgrain. The options catalogue in this post has them:
http://www.skylinesaustralia.com/forums/topic/293993-m35-stagea-sales-brochures-books/?p=4908287
Ahh cool, I hadn't seen that. And I finally can see my suspension is a Nissan option upgrade. Wish I knew what it said about the suspension. Also it's good to see I literally have every option I would have wanted from that book.
Little bit over two weeks to go. Getting excited but very nervous at the same time.
Gathering the stuff ready in two crates ready. Just have to buy oil and filter and im set.
Big thanks to Travis (one of the few non Vtards) who found me the missing bits of trim for my.option momo that someone on here sold me and has not been helpful at all. I think some of you know who it is.
Also looking for the woodgrain door grab trim strips. Would also be keen on a black leather/woodgrain gear shifter to match but not fussed.
#NF
Good to hear you found the pieces for your wheel mate.
In Aaron's defence, he's not actually on this forum; nor has he ever been.
When he stripped the car, his father kicked him out of his home, and had the partially dismantled car removed by Simsmetal and immediately destroyed.
I'm not saying you shouldn't feel hard done by; but I can assure you, he had far more important things to worry about than some covers for your steering wheel.
If he'd had the pieces, I believe he would have given them to you.
He is a stand-up guy, and a good friend of mine.
Glad to hear it's getting toward the end, you must be pumped.
Would have been nice of he told me that the covers were missing to begin with. Otherwise i wouldnt have bought it.
I asked him for the VIN or any form of identification of the car so i could goto nissan and get the parts.
Dont get me wrong hes a nice guy the emanage was a complete steal and im happy but the whole steering wheel thing wasnt right.
But hey whats done is done
Yes there are two different colours of "woodgrain" the lighter and more common tan colour and there is a dark chocolate almost black colour which i am yet to see in the flesh.
I rang nissan for all four trims and shifter ans it came to about 900. Got onto amayama and it was 476.
Getting pretty pumped!
The part numbers might be on the back of the hand grabs...
Also If you get a VIN with the optioned parts and put them into epcdata you might find the option.
*EDIT* I had a quick look could only find http://www.ebay.com.au/itm/03-04-05-Infiniti-G35-door-panel-wood-trim-grip-handle-/230775342365
Which I believe is only half of what you need :(. epcdata showed f**k all.
I asked for the model code and VIN of the car the wheel came off with no luck. But im sure many of you have seen that gold 2004 arx that can not be complied om ebay atm. It has a momo wheel, he put a picture up of the build plate and from that i rang Lake macquarie nissan here in newcastle with unable (or to lazy to use google translate) i rang hornsby NIssan and they gave me a rough quote of 900 for all four trims and shifter posted to aus. Was provided with part numbers and went on amayama and got quoted 476 without postage.
But josh the ones you linked us too i found on import monster which are for 47 so they will be getting watched closely.
http://page16.auctions.yahoo.co.jp/jp/auction/u63246415
Ha looks like there are 3 different colours.
I want that colour! If i find a momo in that id do that. It wont stand out like dogs balls like the one i have will. Ohwell.
Maybe get a set of these; it'll draw peoples attention away from the dogs balls.
  • Like 1
    • I think he was only proposing to use the wire, not the sender. Simply because it runs from the right place to the right place. Personally, I wouldn't hack up the factory wiring like that. I'd just lay in the Defi loom.
    • From memory it wasn't too hard to simply see which wire ran where when you plug that in. Unfortunately also from memory the OEM sender does not use the same configuration 99.9% of gauges run. So in other words if you connect the signal wire that was running to the OEM gauge to your DEFI gauge you might find your oil reads at 200C or some other incorrect value. I remember having the same line of thought and then running new wires/senders to match the gauges I have. The pinout is available in the R34 workshop manual.
    • Does anyone on here know which wire on the GTT triple gauge pod harness is for the oil temp gauge? my sensor works fine but I upgraded the gauges to DEFI advance. And if I can simply piggyback off the oem oil temp wire to the Defi oil temp sensor wire that would make life so much easier.
    • Even face her a wash now that’s it worth more than my house
    • This was what I was invisioning, or Pete cutting a beer can up and hose clamping it around the catch can! Ha ha ha
