  • 9 months later...
Maybe that's what I've just had...two weeks of hell featuring tonsilitis, fevers, night sweats, migraines, vomit and muscle aches :(
And erythromycin can go and get fked. Looked up this nasty alternative to penicillin online...too little too late...almost every user rates it terribly because almost everyone gets the nasty side effects I just had. Can't believe they can prescribe such a drug.
After-effects of erythromycin can be candida symptoms unless hit quick with probiotics.
Think these are hitting me now. I've loaded up on yakult and probiotic choc balls. Have been dieting fairly sugar free so I'm hoping that all this is doing something...
Any other recommendations for candida? Worth getting a gut flora test?
Stage 1:- Kill back Candida albicans from system with a) Pau D'Arco say 3 a day & b) Neem 500mg caps also 3 a day
This kills it systemically
Stage 2:- Starve out the Candida with an anti-Candida diet (on web)
This stops any backlash
Stage 3:- Strong Probiotic a week after starting Stages 1 & 2
This assists digestion and cleans it out from your upper GI tract
Stage 4:- Echinacea/Garlic combo
This pushes the Candida down through the large intestine to the bowel.
Stages 1 & 2 should have a +ve effect by 1 week
Thanks Terry, will look at that. Can overgrowth confirmed with a guy flora test?
Genelle, I don't have any symptoms of thrush, but some people do depending how advanced it is. It's only suspected candida overgrowth at this stage, so I went on the anti-candida diet as a precaution and took probiotics...which can't harm me (it's a largely sugar free diet)...so I thought why not.
The only sort of reliable test is a "Dark Field Micro" test at some science labs.
Cytotoxic tests via Dr > pathology are fraught with too many false +ves and false -ves.
In the clinic I employ a Dr William Crooke Questionnaire. Is that on the net perhaps? If not I'll mail you one.
Look up erythromycin for more info...was prescribed by a doctor under the assumption I had a bacterial infection, and as an alternative to penicillin, which I am allergic too...though honestly I'd take the amoxicillin induced urticaria over the shitstorm that erythromycin hit me with.
Candidiasis Symptoms:- If you have 4 or more of the following, I'd attend to it.
* bloated tummy
* wind
* constipation or loose motions
* changes in your finger or toe nails
* urgency to urinate
* foggy thinking > affecting short term memory
* blocked sinuses
* rashes that come and go, especially in perspiration spots
* crotch itch
* halitosis
* post-viral cough
* post-nasal drip or catarrh
Has anyone done non-government site related research about the correlation between certain vaccines and their lesser known side effects? Pretty scary stuff...
You guys should look in to a supplement called L-Glutamine. It was touted for ages as "build more muscle!" blah blah, however that was soon squashed to be slightly plausible at best. It does, however, have a great off shoot.. It bolsters your immune system something awesome. Works with improving gut health and gut bacteria.. Not to mention strengthens the digestive-contained immune system. From which, I believe, a very large portion of pathogens enter through. The stuff is super cheap too, if you get it in unflavoured powdered form. I pay about $35 for 1kg. It's also the amino acid most commonly found within skeletal muscle.
Start off with 5 grams a day, mixed with a smoothie, water, etc. Usually in the morning. Work up to 20 - 30 grams a day, split evenly in doses. You'll notice your sleep will improve, muscle strength will have positive benefits, and your general sense of well being will improve. And you'll not have to worry about pathogens.. Combine that with some sort of fermented dietary change (adding in sauerkraut, natural yogurt etc) and you'll be laughing.
What really gets me is this whole concept of "cold and flu" season.. I mean, the pathogens responsible don't suddenly say, 'Guys it's winter! lets go mess some people up'.. Then the health organisations will tell you, "Oh but it's because of the people all being around each other in enclosed spaces" .. Pfft, what a load of nonsense.. People are far more likely to socialise in greater numbers in summer. And the same amount of people still use the train for work, work in the same buildings, do the same things..
But, I digress.
Vitamin C, L-Glutamine, fermented food/drink, green tea, and enjoy a good dose of chilli... delicious :D
Anyone else tried the glutamine approach? Or read about it? If so, what was your approach? If you chose not to, what was your reason? :)
I think it's more because immune system resistance drops in the colder temperatures, leaving us more susceptible to catching shit and therefore transmitting if. Plenty of colds going around in summer but I have definitely had more in winter.
Question (this may have been answered somewhere along the line) but it's come time for our office to have flu shots. I am not going to get it this year on the basis that the last 4-5 years I've got the jab, then fallen ill only a few days after. Sometimes just for a few days others I have been confined to bed for at least a week.
Why is this? I eat very well, lots of exercise. Fwiw I even had a cold a few years ago, went for the flu jab, told the lady I already have a cold.. She said I would be fine (bitch won me over with a red lollipop (red is the best)) but yet a day or so later I felt 100billionty times worse
I don't think you should have it either.
Some people have a high degree of sensitivity to vaccines - more so live vaccines rather than dead.
For you, prevention is paramount. But if you do cop it I'd get Chinese Acupuncture and if you're quick enough, esterified vitamin C, zinc and echinacea/garlic.
    • GCG is a good company, they're a major distributor for Garrett in Japan as well.
    • Nah, OEM washer bottle and brake fluid reservoirs are fine I don't know what it is with the plastic that Mazda used, some plastics, like the washer bottle and brake fluid res are fine, and still look new after 20 years use, where as the coolant expansion tank, and PS reservoir, that I replaced with new OEM items when I first got the car, turned yellow and started getting brittle a few years later If the dirty yellow stained plastics didn't trigger me there wouldn't be an issue, but they did, much like the battery bracket....... Meh As for going back to work full time to support car stuff, nope, why, because I own a Mazda NC MX5, not a Nissan R series Skyline 🤣
    • I've never heard of CJ-motor, so can't advise you on them. I'd just go straight to GCG for a GCG highflow though. Seems no point to use a middleman. I'm somewhat surprised that the price on the CJ site is lower than the GCG retail price. Even though CJ would get a discount of some sort, you would hardly expect them to give up so much margin. Maybe the price is out of date? Having said that "I'd go to GCG"...when I did my highflow, I went to Hypergear. I did this https://hypergearturbos.com/product/rb25dethighflow/#tab-dyno-results with the R34 OP6 450HP profile. With the BB centre (extra $400) and intially with the standard boost actuator, but I eventually got him to send me the high pressure one when I got to the point of being able to actually use it. Ends up costing the same sort of money as the GCG highflow, but this is, of course, the turbo that I KNOW has a shorter length core and so moves the comp cover rearwards. The GCG apparently doesn't do that. My mechanic also swears by the GCG highflow, given that we have another turbo rebuilder who does something essentialy the same as theirs, using Garrett wheels. He says it stands up at really low revs and makes good power. I haven't pushed my HG highflow past ~240-250rwkW yet (should have a little more in it, but unclear how much) and it does have a fairly gentle boost ramp. OK, it's much better now that I have gotten my boost controller tuned up on it.  A lot of my earlier unhappiness was because I couldn't keep the wastegate flap as closed as it needed to be (including some mechanical issues). I'd still prefer it to boost up nearly as quickly as the stocker, and it certainly a bit slower than that. So maybe the GCG one is worth the first look (for you).
    • Ok thanks 🙂 I will higly consider this. Any "known" company for a good reviews and experience to send that off? Is that CJ-motor good one? Or go straight to GCG site? I need to use VPN to even find some of those "shops" let alone access them 🙂
    • You can literally put in as much WMI as it takes to quench the combustion totally (and then back it off a little, obviously), and it will keep making more and more power. The power comes from the cooling effect of the water (and the meth) and the extra fuel (the meth, which also has massive octane). It is effectively exactly like running E85. One might be slightly better than the other, but they are damn close. But with either you can lean on the boost or the timing (or both) waaaay more than with just petrol and the results are similar. Here's the first thing I googled for an anecdotal bit of evidence. Can't access the attachment without being a gold member, but it is there for the getting if able to, or searched up elsewise perhaps. https://www.hpacademy.com/forum/general-tuning-discussion/show/wmi-vs-e85/
