Have these parts leftover from a R33 GTST and R32 GTR wreck
R33 GTST:
Front Brake calipers and rotors - $300
Rear Brake calipers and rotors - $200
Front hubs and bearing assembly - $50
--- PACKAGE: Front and rear brakes with front hubs - $450 ---
Flywheel x 2, have surface rust - $40 each
Standard clutch with near new friction plate - $100
Engine backing plate - $20
Clutch master cylinder - $40
Turbo heatshield x 2 - $20 each
Throttle cable - $30
Centre console / armrest - $30
Series 2 airbag dashpad - $100
Parcel shelf - $40
Castor rods with urethane bushes - $30 each
Rear lights, left and right. Painted white - $40 each
Brake master cylinder - $40
Passenger side airbag - $50
Rear bar, white. Good paint - $100
Rear bar reinforcement - $50
Manual gearstick surround with vinyl boot - $50
Rear 'skyline' garnish, white. - $40
Climate control unit - $40
AAC Valve - $30
Passenger window switch - $25
Clutch & brake pedal - $30 each
Drivers side door card, series 2 - $40
Manual radiator, very good condition - $100
Aircon condenser, very good condition - $80
Radiator plastic shroud - $40
Space saver spare wheel - $40
Fuel pump - $20
Indicator and wiper stalks - $20 each
R32 GTR:
Stock front Coilovers x 2, good condition with no leaking - $100 each
Stock rear Coilover, good condition with no leaking - $100
Washer Bottle - $30
Aircon fan - $50
Drivers Mirror - $50
Fuel Pump - $50
Passenger window switch - $30
Parts located in Emerald, Victoria. Can post smaller items, prefer pick-up for larger items. Contact me here or through PM.
Edited by Shano3000
https://www.sau.com.au/forums/topic/396771-leftover-parts-r33-gtst-r32-gtr/
Yes, they are called coilovers when stock. No stock coilovers are adjustable as far as i know.
Generally, they are referred to as struts.
Coilovers are generally aftermarket adjustable type of suspension.
Hope this helps.
Strut or Coilover who gives a f**k, two different names for the exact same thing.
Don't know why I'm bothering answering this as it is a moot point.
BTW: The COILOVERS are still for sale.
  • 5 weeks later...
dude are they adjustable?
  • 5 months later...
Is this Series 1 or Series 2?
Series 1 - smooth
Series 2 - matte finish
Also is the boot OEM or aftermarket?
    • It was a great, but typical track day, and some VB was ingested at the night time debrief 🤪
    • And so, to round this out, I couldn't be happier to confirm @MBS206 has decided to buy the car. He drove down from sunny QLD with a trailer last week and it is off to its new home today. I'll let Matt confirm on next steps but I understand broadly that the plan is to leave it pretty much as is, and just get some quality wheel time with a nicely balanced car that is pretty much track ready. There are a few a jobs still to be done first but nothing too major and I think its a very smart buy Dinner last night at the Paragon with a round of VBs (mostly) for Neil
    • Well, 50 pages and the end of a chapter for this car. We took it out for a shakedown at Wakie yesterday, and everything went well. There were a couple of niggles: - Oil cooler fitting leak - tightened, cleaned, stopped leaking - Radiator cap overflow fitting was leaking....Mark called it, the overflow fitting was threaded in and not tight....tightened, tested and held pressure - Small oil leak at the rear of the block, probably the turbo oil feed - too hot to get at it comfortably but probably just needs to be nipped up - leak at the driver's side rear brake line where it meets the hardline. Fitting wasn't loose, so Matt backed it off and back on, no further leaks - there's also a leak somewhere on the top of the fuel tank, maybe that cross over fuel line - that was has been left to fix when its on a hoist Otherwise than those niggles the car went great, turned great and stopped great so it was a very successful day out. I'm always really nervous when a car first hits the track after a long break, especially with a brand new engine as well but it was great. VID-20251011-WA0007.mp4  Big thanks to @The Bogan who dropped by and helped out, @MBS206 and my nephew Lachlan the apprentice.  Neil's wife Mel also surprised the hell out of all of us by dropping by; she's up in Tamworth these days but was travelling to Melbourne so had plausible deniability for turning up at the garage, it was great to see her but also obviously a bit sad all round.
    • Skyline R33 Series 2 sedan tail lights in excellent condition. These are becoming harder to find, especially in this state.    BOTH SETS ARE IN FANTASTIC CONDITION (REFER TO PHOTOS)    ✅ No broken covers or cracks ✅ Lenses are in flawless condition ✅ All rear mounting lugs intact ✅ Comes complete as pictured ✅ Perfect for restoration, replacement, or upgrade   These lights are ready to go, no surprises just quality OEM parts.   These are definitely one of the better sets we have seen in a while. With minimal wear and tear they will come as you see. Bear in mind they are not brand new they are almost 30 years old now. To find them in this condition isn’t easy they can only be obtained on the second hand market.   Australia Wide Postage Available At Buyers Expense. Silver Set:$850 Grey Set:$850 PM Me for purchase or any other questions  IMG_2166.dng IMG_2165.dng IMG_2172.dng IMG_2173.dng IMG_2174.dng IMG_2179.dng IMG_2180.dng IMG_2260.dng IMG_2258.dng IMG_2259.dng IMG_2261.dng IMG_2266.dng IMG_2273.dng IMG_2274.dng IMG_2276.dng
    • Unsolicited advice? Keep the engine as close to stock as you can. Nothing wrong with adding some boost and making a little more power, but given where you are, you really don't want to try to make it into a monster. I can't imagine the roads are up to it, and the lack of locla support when it grenades will be a ball ache. FWIW, If there is a dyno around that you can access, then brand new injectors are a good idea, which will lead you to (at least) putting a Nistune in it, which will allow you to put an R35 AFM on it, all of which will make it possible to make it much much nicer to drive and live with.
