  • Replies 191
Hi how much for 6x id1300 injectors if U have them
Hi mate,
We don't do ID's we stock the BOSCH injectors which ID then match flow.
Cheers,
Brendan
(VM)
Then why are u advertising id for ?
Many sellers do it.
Riding the coat tail of injector dynamics I suppose .
Edited by Ben C34
  • 1 month later...
Massive clearance on Siemens/VDO metal body injectors - 380cc @ $95/each.
These are getting very rare and no longer manufactured.
  • 1 month later...
G'day mate,
Can I get a price on a set of 6x 1000cc TOP feed High Impedance injectors to suit 11mm Greddy fuel rail on a ECR33 RB25det... inc delivery to Perth.
Cheers.
Edited by Nemesis
G'day mate,
Cheers.
Hi,
Sure thing mate, BOSCH 1000cc injectors (E85) unit's, 11mm o-ring extensions and plugs would be $660 incl. delivery to Perth for the complete set-up.
Let me know,
Brendan
(VM)
  • 3 weeks later...
New 1150cc @ 4 BAR BOSCH injector's in stock now (unmodified)
> E85 compatible
> Improved Spray Pattern
  • 3 months later...
  • 1 month later...
  • 3 weeks later...
Hi mate!
I would go with the BOSCH 1000cc injectors, they are the only unit's which are purpose built for E85 and race fuels.
Price on a full set of 6x flow matched with extensions and plugs would be $660.
Cheers,
Brendan
(VM)
So these 1000cc EV14s are different from the other larger size injectors you offer?
How large do the bosch EV14s go?
Hi,
Sure, the 1000cc injectors are purpose built for use with all fuels including E85.
They are a 3/4 length injector however extensions can be supplied for them as well to make them full length.
Cheers,
Brendan
(VM)
Hi,
Cheers,
Brendan
(VM)
Yea these are the ones that I already have. I am wondering if you have the higher CC EV14s or are these the largest you have of these type of injector?
What are the larger options for R34 GTT?
Can I have a price please on a set of short (40mm) 1000cc top feeds and a rail to suit that will fit under a standard RB25 intake
Cheers
Andrew
Cheers
Andrew
Hi mate,
The only 1000cc inceptors we have are 3/4 length which are a slight longer unit.
Will this be suitable?
Cheers,
Brendan
(VM)
I'll have to do some measurements. but from memory they will foul.
Let me know though.
Do you have a part number for the specific ones you require?
  • 1 month later...
    • I assume clearances were all a-okay?
    • Shock tower brace is in +5Kw....LOL
