  • Replies 7.5k
Posted Images
thats exacly what i thought... :D
in the "sa people post a pic of your car thread" friendlygarage posted pics of his cefiro and said,
cefiro yewwww 6th registered in sa
so there are actually 6.. whoops....
Edited by wyzokie
spotted white r33 turn onto o'connel from main north rd at about 1015pm sat nite, didnt get a chance 2 c plate cos of traffic but was somthing like 'robski', passed him cos some idiot was trying to parallel park infront of him...some drivers stress me lol
only 6 ceffys?? theres 2 in victor harbor i know of, there was also anotha 1 down here that was written off down here recently, so thats 3 just on the south coast. and i know of another 2 ceffys. thats 5 that i know. i have seen more around adelaide when i have been up there crusing round.
spotted 2 black 33s, 1 black 32, 1 red 33, 1 red 32, 2 white 33s, 2 silver, 1 gunmetal, 1 200sx, 1 mr2 and a commodore cruising through the hills, oh wait i was there, where were the rest of you???? :blink:
lol
spotted 2 black 33s, 1 black 32, 1 red 33, 1 red 32, 2 white 33s, 2 silver, 1 gunmetal, 1 200sx, 1 mr2 and a commodore cruising through the hills, oh wait i was there, where were the rest of you???? :D
:lol:
His car has 350kw@rw (lots of money spent like black33_26)
Understand dude?
Phu has 300kw wants to get it too 350 which he has in progress just money holding him back, saw him yesterday(tuesday) and laughed as he wishes it was. He should have back on the road soon.
Not quite gonna spend as much on my car as he has, is in pretty good shape as is and id rather save for a house.
Doesnt mean moneyt wont be poured into it :P
BIg difference from 300 rwkw dude another 50rwkw is awesome get your shit together
[ :)  there were heaps of sik ass skylines out cruising last nite seen heaps down da bay!! all seem to be GUYS!!!! YUMMY  :)
There you go boys, MISS-R33-MEL must be one of those chicky's you's spot all the time in 33's!! :)
nice. <_<
    • What are we supposed to be seeing in the photo of the steering angle sensor? The outer housing doesn't turn, right? All the action is on the inside. The real test here is whether or not your car has had the steering put back together by a butcher. When the steering is centred (and we're not caring about the wheel too much here, we're talking about the front wheels, parallel, facing front) then you should have an absolutely even number of turns from centre to left lock and centre to right lock. If there is any difference at all then perhaps the thing has been put back together wrongly, either the steering wheel put on one spline (or more!) off, and the alignment bodged to straighteb the wheel, or the opposite where something silly was done underneath and the wheel put back on crooked to compensate. Nut there isn't actually much evidence that you have such a problem anyway. It is something you can easily measure and test for to find out though. My money is still on the HICAS CU not driving the PS solenoid with the proper PWM signal required to lighten the load at lower speed. If it were me, I would be putting either a multimeter or oscilloscope onto the solenoid terminals and taking it for a drive, looking for the voltage to change. The PWM signal is 0v, 12V, 0V, 12v with ...obviously...modulated pulse width. You should see that as an average voltage somewhere between 0V and 12V, and it should vary with speed. An handheld oscilloscope would be the better tool for this, because they are definitely good enough but there's no telling if any cheap shit multimeter that people have lying around are good enough. You can also directly interfere with the solenoid. If you wire up a little voltage divider with variable resistor on it, and hook the PS solenoid direct to 12V through that, you can manually adjust the voltage to the solenoid and you should be able to make it go ligheter and heavier. If you cannot, then the problem is either the solenoid itself dead, or your description of the steering being "tight" (which I have just been assuming you mean "heavy") could be that you have a mechanical problem in the steering and there is heaps of resistance to movement.
    • Little update  I have shimmed the solenoid on the rack today following Keep it Reets video on YouTube. However my steering is still tight. I have this showing on Nisscan, my steering angle sensor was the closest to 0 degrees (I could get it to 0 degrees by small little tweaks, but the angle was way off centre? I can't figure this out for the life of me. I get no faults through Nisscan.
    • The BES920 is like the Toyota Camrys of coffee machines. E61 group head is cool, however the time requirements for home use makes it less desirable. The Toyota Camry coffee machine runs twin boilers and also PID temp control, some say it produces coffees as good as an E61 group head machine.
    • And yes with a full tank it will hit limiter free revving or driving 6B6CDF6E-4094-426D-A9CB-6C553475FE36.mp4
    • One way of putting the fuel surge idea to rest, is that even when in neutral/clutch in or free revving it still has the same issue, it can’t even get to limiter (7800) so to me that says it can’t be g force, I’m not trying to argue I just want to find the f&$king issue 😡
