  • Replies 7.5k
Posted Images
hope 2 c u crusing more often...as of tomm every1 will c my car with my new plates "VANGE" lol
get it through regency yet? any probs?
yeah took it down last week and got through, went with my dad and had him do all the talking but obviously they knew the car was mine, they did pick up on the window tint being far too dark however they let that one slide and just suggested that i have it rectified, apart from that they didnt pick up on anything else and i only bothered to take the turbo timer out so i was rather happy!
Can someone point out to me what the point is of letting everyone know where in Adelaide nice cars frequent, and are generally located?
If i owned a nice r34GTR (or just my 32) and had people saying "saw it here" or i see it all the time here...wouldnt that make your car more of a target for thieves / police ??
I just dont see the sense in saying where u saw x car at y.
Dont wanna sound like a pri(k, just dont put up where you saw, or think you saw me or my car driving/hanging around etc....
Feel free for everyone else though....
I think you guys MASSIVELY underestimate car thieves. They already know where we all live (as it's not at all hard in a smal town like Adelaide to find out owners names etc), and before raiding or stealing one of our cars, they case it all out to the nth degree. If you think otherwise, you are kidding yourself. People posting on here 'I saw this car on Greenhill Rd' isn't really going to cause cars thieves to 'lick their lips' now, is it?
i agree
they keep tabs on cars, where they park at nite, when the ower goes 2 sleep, their routine etc....
thats it, i try to generalise as much as i possibly can if i post that i have seen someone or their car. as long as adresses or number plates arent noted, i cant see the harm.
I have,
i spotted you sun afternoon (when i was returning from svd xmass barbie) you were just coming past adelaide children's hospital as i was going up the hill in opp direction!
Regards,
SKYLINE (Kym) B)
I have,
  Regards,
            SKYLINE (Kym) B)
lol was on the way 2 glenelg, wat car were u in?
saw u curising at glenelg in the afternoon
again, the new BP at cross rd at night when i was on my way home
:D
was at glenelg getting some hogs breath steak to recover from night before
that new bp just popped out of nowhere haha subway and wokinabox
i recommend the new chicken parmagana sub...
    • Yea that’s why I said ima test them with multimeter and see the reads.
    • Only at idle. Isn’t a problem when rev it seems.
    • @Haggerty This seems silly to ask, but are you confident in your ability to tune the Haltech?
    • Next on the to-do list was an oil and filter change. Nothing exciting to add here except the oil filter is in a really stupid place (facing the engine mount/subframe/steering rack). GReddy do a relocation kit which puts it towards the gearbox, I would have preferred towards the front but there's obviously a lot more stuff there. Something I'll have to look at for the next service perhaps. First time using Valvoline oil, although I can't see it being any different to most other brands Nice... The oil filter location... At least the subframe wont rust any time soon I picked up a genuine fuel filter, this is part of the fuel pump assembly inside the fuel tank. Access can be found underneath the rear seat, you'll see this triangular cover Remove the 3x plastic 10mm nuts and lift the cover up, pushing the rubber grommet through The yellow fuel line clips push out in opposite directions, remove these completely. The two moulded fuel lines can now pull upwards to disconnect, along with the wire electrical plug. There's 8x 8mm bolts that secure the black retaining ring. The fuel pump assembly is now ready to lift out. Be mindful of the fuel hose on the side, the hose clamp on mine was catching the hose preventing it from lifting up The fuel pump/filter has an upper and lower section held on by 4 pressure clips. These did take a little bit of force, it sounded like the plastic tabs were going to break but they didn't (don't worry!) The lower section helps mount the fuel pump, there's a circular rubber gasket/grommet/seal thing on the bottom where the sock is. Undo the hose clip on the short fuel hose on the side to disconnect it from the 3 way distribution pipe to be able to lift the upper half away. Don't forget to unplug the fuel pump too! There's a few rubber O rings that will need transferring to the new filter housing, I show these in the video at the bottom of this write up. Reassembly is the reverse Here's a photo of the new filter installed, you'll be able to see where the tabs are more clearing against the yellow OEM plastic Once the assembly is re-installed, I turned the engine over a few times to help build up fuel pressure. I did panic when the car stopped turning over but I could hear the fuel pump making a noise. It eventually started and has been fine since. Found my 'lucky' coin underneath the rear seat too The Youtube video can be seen here: https://www.youtube.com/watch?v=uLJ65pmQt44&t=6s
    • It was picked up on the MOT/Inspection that the offside front wheel bearing had excessive play along with the ball joint. It made sense to do both sides so I sourced a pair of spare IS200 hubs to do the swap. Unfortunately I don't have any photos of the strip down but here's a quick run down. On the back of the hub is a large circular dust cover, using a flat head screw driver and a mallet I prised it off. Underneath will reveal a 32mm hub nut (impact gun recommended). With the hub nut removed the ABS ring can be removed (I ended up using a magnetic pick up tool to help). Next up is to remove the stub axle, this was a little trickier due to limited tools. I tried a 3 leg puller but the gap between the hub and stub axle wasn't enough for the legs to get in and under. Next option was a lump hammer and someone pulling the stub axle at the same time. After a few heavy hits it released. The lower bearing race had seized itself onto the stub axle, which was fine because I was replacing them anyway. With the upper bearing race removed and the grease cleaned off they looked like this The left one looked pristine inside but gave us the most trouble. The right one had some surface rust but came apart in a single hit, figure that out?! I got a local garage to press the new wheel bearings in, reassemble was the opposite and didn't take long at all. Removing the hub itself was simple. Starting with removing the brake caliper, 2x 14mm bolts for the caliper slider and 2x 19mm? for the carrier > hub bolts. I used a cable tie to secure the caliper to the upper arm so it was out of the way, there's a 10mm bolt securing the ABS sensor on. With the brake disc removed from the hub next are the three castle nuts for the upper and lower ball joints and track rod end. Two of these had their own R clip and one split pin. A few hits with the hammer and they're released (I left the castle nuts on by a couple of turns), the track rod ends gave me the most grief and I may have nipped the boots (oops). Fitting is the reversal and is very quick and easy to do. The lower ball joints are held onto the hub by 2x 17mm bolts. The castle nut did increase in socket size to 22mm from memory (this may vary from supplier) The two front tyres weren't in great condition, so I had those replaced with some budget tyres for the time being. I'll be replacing the wheels and tyres in the future, this was to get me on the road without the worry of the police hassling me.
