  • Replies 7.5k
Posted Images
Vange - I have had good service and results from Turbo Tune, so I wouldn't worry. Michael has tuned my S15 for 2 years and always has a safe/rich tune (at my request), and will not try to get every last rwkw at the risk of detonating an engine (like some other tuners around will).
Every workshop has people who have had bad experiences, so don't worry about what everyone has to say.
My car was last there 2 months ago and I am very happy. Lots of the stories you will hear are from x years ago - so aren't really up to date. That said, everyone is human and every single workshop has had some sort of mistake or failure that people will always tell you about. You hear little of good reports.
However, Boostworx is one workshop I have heard nothing but good things about. Maybe get Shaun to put it on his dyno just to make sure the tune and afrs look ok - if you are worried, that is.
Graham West on Marion Rd can tune the eManage.
I only ever did a power run on their dyno, so can't vouch for their work, but from talking to them they seem like really a good bunch down there.
yeh im not worried, was happy with the boost controller they put on, n he set it at max 10psi so i dont blow anyting. seems 2 b running ok anyway...got new sparkies as well, the others were stuffed lol.
i might have 2 get it re-dynoed cos since it was last dynoed i had new clutch, new spark plugs and hiflow cat.
was thinking of getting a emanage, how much they cost 2 get installed, prob do the fuel pump as well...any1 know if the fuel economy gets better or worse with an emanage or better fuel pump?
i get mine done at hitech dyno on south rd, so does Phu 'PHUMAN' and he highly recommends it. Boostworx wouldnt touch my emanage ultimate, the guy said he had to call John (hitech) to get it to work as he couldnt figure it out??? I was shocked. Still got my fuel pump done there and is fine. Should be getting my emanage ultimate put in before the up coming cruise
Whats to be shocked about. Shaun specialises in Power FC's and Microtech computers...Hitech may know emanage and something else. You cant expect everyone to know everykind of computer out there...
hey hot chick spotted in a R33.........
brunett in a black 33 ser 1 m spec on OG road turning right to marden shops at 4:45pm today, anyone on forums ?
gotta love hoy chicks in lines.....
Edited by trick
yeah spotted DriftR_33 yesterday went for small cruise through the windies!
spotted silver 32 at Mobil servo Morphett Vale, stopped and chatted compared cars, mods.
Good to see other 32's getting around. :(
spotted chick in burgandy 33 on South road
spotted a black 32 on the espi and another white 33 at Woodroft with P's
alot of skylines out today!
Edited by HR-32
    • Yeah well per the video it took 15s for the stock unit to start up....even if I give it a few seconds discount for starting that is at least 12 sec before you get a reverse camera if you are trying to leave a park.  The android unit is way faster, but 2016 for the stock unit is a long time ago in consumer electronics
    • Yea that’s why I said ima test them with multimeter and see the reads.
    • Only at idle. Isn’t a problem when rev it seems.
    • @Haggerty This seems silly to ask, but are you confident in your ability to tune the Haltech?
    • Next on the to-do list was an oil and filter change. Nothing exciting to add here except the oil filter is in a really stupid place (facing the engine mount/subframe/steering rack). GReddy do a relocation kit which puts it towards the gearbox, I would have preferred towards the front but there's obviously a lot more stuff there. Something I'll have to look at for the next service perhaps. First time using Valvoline oil, although I can't see it being any different to most other brands Nice... The oil filter location... At least the subframe wont rust any time soon I picked up a genuine fuel filter, this is part of the fuel pump assembly inside the fuel tank. Access can be found underneath the rear seat, you'll see this triangular cover Remove the 3x plastic 10mm nuts and lift the cover up, pushing the rubber grommet through The yellow fuel line clips push out in opposite directions, remove these completely. The two moulded fuel lines can now pull upwards to disconnect, along with the wire electrical plug. There's 8x 8mm bolts that secure the black retaining ring. The fuel pump assembly is now ready to lift out. Be mindful of the fuel hose on the side, the hose clamp on mine was catching the hose preventing it from lifting up The fuel pump/filter has an upper and lower section held on by 4 pressure clips. These did take a little bit of force, it sounded like the plastic tabs were going to break but they didn't (don't worry!) The lower section helps mount the fuel pump, there's a circular rubber gasket/grommet/seal thing on the bottom where the sock is. Undo the hose clip on the short fuel hose on the side to disconnect it from the 3 way distribution pipe to be able to lift the upper half away. Don't forget to unplug the fuel pump too! There's a few rubber O rings that will need transferring to the new filter housing, I show these in the video at the bottom of this write up. Reassembly is the reverse Here's a photo of the new filter installed, you'll be able to see where the tabs are more clearing against the yellow OEM plastic Once the assembly is re-installed, I turned the engine over a few times to help build up fuel pressure. I did panic when the car stopped turning over but I could hear the fuel pump making a noise. It eventually started and has been fine since. Found my 'lucky' coin underneath the rear seat too The Youtube video can be seen here: https://www.youtube.com/watch?v=uLJ65pmQt44&t=6s
