great idea!
are there currently any stickers available or if not i wonder if anyone on here is able to make some to order?
ive been offered sum by a girl in brisbane but i dont know how many and if we have to pay she asked me how many i wanted :)
i more or less said how many have you got... its this 1
http://www.skylinesaustralia.com/forums/in...st&id=54630
  • Replies 7.5k
Posted Images
personally, i dont like that one at all.
I much prefer Howie's design in the "GTR" shape - would look great over the GT badge on the front guards - not too obtrusive, but easily identifiable to other SAU members.
That would be me, 34 4 door looks cool in that colour.
Awesome car mate - so very clean! I am not big on white cars, but for some reason R34s (especially Rs) look great in white! Do you live around here - I am like 200m from the shopping centre. Would love to get some photos of them together!
Pity mine was absolutely filthy when you saw it :P .... but thanks for the compliment anyhow
Cheers. I live just across north east rd. It looks clean from a distance but you can see the dust and collection of (f%#@ing) cat paw prints all over it when you get close.
Yours sounds better than mine, silly stock GTR exhaust is almost silent.
Photos would be cool.
    • Yeah well per the video it took 15s for the stock unit to start up....even if I give it a few seconds discount for starting that is at least 12 sec before you get a reverse camera if you are trying to leave a park.  The android unit is way faster, but 2016 for the stock unit is a long time ago in consumer electronics
    • Yea that’s why I said ima test them with multimeter and see the reads.
    • Only at idle. Isn’t a problem when rev it seems.
    • @Haggerty This seems silly to ask, but are you confident in your ability to tune the Haltech?
    • Next on the to-do list was an oil and filter change. Nothing exciting to add here except the oil filter is in a really stupid place (facing the engine mount/subframe/steering rack). GReddy do a relocation kit which puts it towards the gearbox, I would have preferred towards the front but there's obviously a lot more stuff there. Something I'll have to look at for the next service perhaps. First time using Valvoline oil, although I can't see it being any different to most other brands Nice... The oil filter location... At least the subframe wont rust any time soon I picked up a genuine fuel filter, this is part of the fuel pump assembly inside the fuel tank. Access can be found underneath the rear seat, you'll see this triangular cover Remove the 3x plastic 10mm nuts and lift the cover up, pushing the rubber grommet through The yellow fuel line clips push out in opposite directions, remove these completely. The two moulded fuel lines can now pull upwards to disconnect, along with the wire electrical plug. There's 8x 8mm bolts that secure the black retaining ring. The fuel pump assembly is now ready to lift out. Be mindful of the fuel hose on the side, the hose clamp on mine was catching the hose preventing it from lifting up The fuel pump/filter has an upper and lower section held on by 4 pressure clips. These did take a little bit of force, it sounded like the plastic tabs were going to break but they didn't (don't worry!) The lower section helps mount the fuel pump, there's a circular rubber gasket/grommet/seal thing on the bottom where the sock is. Undo the hose clip on the short fuel hose on the side to disconnect it from the 3 way distribution pipe to be able to lift the upper half away. Don't forget to unplug the fuel pump too! There's a few rubber O rings that will need transferring to the new filter housing, I show these in the video at the bottom of this write up. Reassembly is the reverse Here's a photo of the new filter installed, you'll be able to see where the tabs are more clearing against the yellow OEM plastic Once the assembly is re-installed, I turned the engine over a few times to help build up fuel pressure. I did panic when the car stopped turning over but I could hear the fuel pump making a noise. It eventually started and has been fine since. Found my 'lucky' coin underneath the rear seat too The Youtube video can be seen here: https://www.youtube.com/watch?v=uLJ65pmQt44&t=6s
