  • Replies 7.5k
Posted Images
That was me, was picking up the other half from her last day of her old job to go for some drinks.
And yes you are correct in thinking that an rb26 lies under the bonnet, makes for lots of fun! :)
Those poor unsuspecting commodore drivers never seem to know what just happened......the look of "i think just got cained by a volvo" cracks me up everytime! :(
any chance of you bringing your 260rs stag to the photoshoot next saturday?
Haven't seen one except in photos. :(
is this why i havnt seen u this week Matty
spotted a nice S5 Rx7 @ the car wash on the corner of south road and Pt. Road with white R32 rims spoke to the owner for a minute he was a nice bloke only young had plans for a wolf3d :D - beacause they dont require a AFM i lol'd and said if you want the cops breathing on you and defecting you you could go that route or see about a Apexi - but mildrens recommended the wofl so yea
West tce hungries tonight silver gtr and a black r33 parked with bonnets up think saw jman drive past as well.
Were the two cars parked people from here on the cruise ? was gonna say ello but got some weird looks so went back to getting ice for work tonight lol
Saw the same cars too. I was on the other side of the road heading north. One of the blokes there actually raised his hand high to wave. Waved back... (not sure he was waving to me ot not thou :sleep: )
Also my gr spotted VANGE parked on currie st. today. :dry:
Edited by bixby
sorry man i saw u there and look like you wanted to say hello but Troy the tall lad was tellimg me sumthing so didnt was to interupt... you should of just blurted out SAU FTW and we would of laughted and said yeah man not to worry btw the silver car is a gun metal grey 4door GTS4 (baby godzilla)
Saw the same cars too. I was on the other side of the road heading north. One of the blokes there actually raised his hand high to wave. Waved back... (not sure he was waving to me ot not thou :huh: )
Also my gr spotted VANGE parked on currie st. today. ;)
sorry bixby was waving to mxtcy who i spotted heading south on wst tce
Edited by Madaz
spotted a few r33's in town today. didnt recognise any faces so unlikely anyone from on here.
also spotted two very lovely looking evo's. red evo 9 with complimenting p plates and a silver evo 8 that was for sale.
ah to the gts4 :P didnt get to close only saw the different grill thats why i thought it was a gtr :) i guess it wouldnt have been cuz it was four door but i was trying not to look like a total weirdo :(
Kinda know what yas look like so if i see yas there again ill come say ello, most prob would have if i was in the line but was in the dodgey lazer :ninja:
west tce aagin tonight n way home saw a nice white line dont know wot sort dark charcoal mags
ah to the gts4 :) didnt get to close only saw the different grill thats why i thought it was a gtr :) i guess it wouldnt have been cuz it was four door but i was trying not to look like a total weirdo :(
Autech make a 4door GTR :P
    • After using a protractor for an actually accurate assessment of what is required,  and by NOT using my uncalibrated eyeball I worked out I need a 25° silicone bend from the TB ro the MAF, but, my choice was either a 30° or a 23° (23° is a weird spec), so I grabbed the 23° one from Raceworks I also grabbed 1mtr of 3" straight from Just Jap, I needed 350mm, but they only had 300mm, or 1mtr lengths....meh Also ordered a 1/2" hose bulkhead fitting from fleabay, this has a smoothish mushroom looking head (they are designed for below the water line of boats) that will fit inside the bend, the hose bit and threaded bit looks to long, but nothing that a hacksaw cannot fix if required, the hose will then just get jamed on the threaded bit up to the retaining nut Fingers crossed and the unsightly amount of hose clamps will be reduced down to 4 once all the parts arrive
    • Oil change does not trigger code 21. Code 21 is for coilpacks primary side connection. You can try to clear the code with a battery disconnect, hold down the brake pedal to drain capacitors through the brake lights with the ignition on for 10-15 seconds before you reconnect the battery. I have seen R35 coil conversion permanently cause this code with no ill effects so it might be the resistance it wants to see isn't quite right on one or more coilpacks. Could be inside the ECU, could be the harness, could be a coil. You can test it all if you want or just ignore until the car actually starts misfiring.
    • I forgot you have a Nistune ECU. Use Nistune to do all the tests I mentioned instead of faffing with 30+ year old electrical connectors. You can read MAF volts off that too, there are reference values in the service manual to tell you roughly what it should be in different conditions.
    • No. I think it might be the AFM. Hence the use of the terms "swaptronics", which implies the use of swapping out electronics for the purpose of diagnosis. It's about the only way to prove that a small/niggling/whatever problem with an AFM or a CAS or similar is actually caused by that AFM/CAS/whatever. A known good item swapped in that still gives the same problem is likely to be caused somewhere else. They're all the same. Spraying AFMs with cleaner is an each way bet between cleaning it and f**king it.
    • Oh wow! This might actually work amazingly. Do you know the ratio of the diff? I was told the only thing you need to make sure of is if the front & rear diff ratios are the same. Ours is a 4.083 Thanks!
