Yeah saw the same one parked on the footpath just outside waves/casino with a Porsche GT3 on the other side. I'd take the GT3 anyday, but then again if I sold that huuge beast id be able to buy 10 Porsche GT3s.
btw SAZilla is no more: name-change :P
  • Replies 7.5k
Posted Images
eyy i kinda slowed down & waited for u to catch up to suss ur car out, whether its a genuine GTR or not :P
still waiting for my personalised SA plate to come
likewise, would love to cruise with the original 'Godzilla'
Haha I wanted to do the same, considering you had no wing, I had to check it wasn't just a kitted up GT-T! But the flared guards etc helped me out.
Seems you do the same as me, always check to see their genuine too haha
i need to replace a set of bulbs at the back of the car
these include 2 rear lights (red) 2 reverse lights (white), what ones do I go out and buy to fit them myuself?
they just normal ones, take em out and go 2 petrol station n they will match them 4 u
nice, didnt know if there was some part number u could reference for me to just go in and get them but i guess dissasembly of the tail lights isnt soo hard.... gonna have to do it anyway i guess
Saw a white R31 GTS1 or 2 on Marion road today, then it pulled into the BP by the marion hotel. R31 skyline club sticker on the back window
Also saw a Maroon VL commodore with a massive NISSAN sticker across the front windshield, lol, respekt~
Saw an R32 GTR parked on the Seacliff Esplanade tonight. <3
vange, ever considered that the heat is where ur missing kw have gone... its like as it gets closer to summer ur KW have dropped wildly and maybe u got some bad runs on the dyno being that 15kw out?
that GTS1 sounds like Randall............odd lookin rear bar on it?
spotted your car in its usual spot, bout 2 this arvo
and had a yellow 33 with veilside kit and LED tail lights next to me on marion road about 12:30. he got a wave from a black 32 with nice large FMIC near Hamilton college :P. I was in the white Hino tipper next to it LOL
    • If you take the top half of the intake off you can unbolt the flap off the shaft and leave the shaft in there blocking the hole. Then you can remove the little vacuum canister off from under the manifold and get a spare vacuum line to run to the ECU. I can take some photos of it later. Probably best to get the vacuum source to the ECU sorted first though. Mine all worked mint with the base map from the GTT an I've pretty much let the closed loop sort the fueling and took 1 degree out of the whole timing map.
    • This IS something you also have to configure in Haltech (or at least I did in the past when going from onboard-to-ECU map sensor and an external MAP sensor in haltech land).
    • I'm hoping it's something as simple as the ECU is looking for an external MAP sensor, but he is trying to use the onboard MAP sensor.
    • You won't need to do that if your happy to learn to tune it yourself. You 100% do not need to do that. It is not part of the learning process. It's not like driving on track and 'finding the limit by stepping over the limit'. You should not ever accidently blow up an engine and you should have setup the ECU's engine protection to save you from yourself while you are learning anyway. Plenty of us have tuned their own cars, myself included. We still come here for advice/guidance/new ideas etc.  What have you been doing so far to learn how to tune?
    • Put the ECU's MAP line in your mouth. Blow as hard as you can. You should be able to see about 10 kPa, maybe 15 kPa positive pressure. Suck on it. You should be able to generate a decent vacuum to about the same level also. Note that this is only ~2 psi either way. If the MAP is reading -5 psi all the time, ignition on, engine running or not, driving around or not, then it is severely f**ked. Also, you SHOULD NOT BE DRIVING IT WITHOUT A LOAD REFERENCE. You will break the engine. Badly.
