  • Replies 7.5k
Posted Images
Brenton, you just made me shit myself when I read your post, I thought "Crap, those guys are taking my car for joyrides :woot:"
The car is in for repairs for work that they previously did before Christmas, I was not happy at all with the work, spoke to Mike, he agreed and said he'd fix it, so hopefully it comes back this time all good. What condition was the car in when you saw it?
HAHAHAHHA. Lol who said it was in doyles. LOL i said it was AT doyles. DOing ringies out the fornt.
It was in the both at the back. Just looked like it was getting stored there over night.
Look clean actually.
Mines infront of about 5 other cars and im meant to be getting it back today. UMMMMMMMMMMM and its got white dust all over it and i have about 5 tools on my black roof. Not happy about that but oh well. If i aint happy Mike will be hearing about it.
I have never seen ur car before yesterday. Iwas looking at it then thought Hng On a minute. I no that number plate. Put 2 and 2 together and figured out it was urs.
Looks rather clean Luke.
Tah tah. off to get $$$ cheque to pay for said car. lol. Piece of crap just makes me angrier now after spending $12k on it and she is still stock. But Manual. LOL
goes well martin......didnt c ya tho :)
spotted VANGE on wednesday nite parked on a main road.....for the life of me i cant remember where
today, spotted a silver 32 gtr with white enkeis and some front end damage on south road near flinders (bout 10mins before martin spotted me).....got the thumbs up from him
and then a white 32 gtr on oaklands road by warradale army barracks.......think he said his username was Writeoff...........as for the sticker, u need to talk to patrick (PK_R33) if he's still got some :)
yesterday spotted a red 34 GTT with a chick driving near elizabeth (heading north) at about 2:30 i think it was.
also spotted a white stagea with 18/19 inch nismo wheels parked at munno para at about 6:30.
and today spotted a black 34 GTT on north terrace at 12:30
also a silver 32 GTR crusing down main north near mitre ten at 4:30-5.
Thanks. Did you notice my Regency spec exhaust note? Amazing how effective a baffle plate can be although I wasn't going to take it past 3,000 rpm.
Spotted SKY 031 on anzac after work yesterday arvo, and a 32 with plates "WANTD 2" turning from anzac to morphett this morning about 7:15, female driver
yeah wantd2 is my manager deeanne she has a nice supra with wantd plates on it aswell
Edited by paulmac
    • You won't need to do that if your happy to learn to tune it yourself. You 100% do not need to do that. It is not part of the learning process. It's not like driving on track and 'finding the limit by stepping over the limit'. You should not ever accidently blow up an engine and you should have setup the ECU's engine protection to save you from yourself while you are learning anyway. Plenty of us have tuned their own cars, myself included. We still come here for advice/guidance/new ideas etc.  What have you been doing so far to learn how to tune?
    • Put the ECU's MAP line in your mouth. Blow as hard as you can. You should be able to see about 10 kPa, maybe 15 kPa positive pressure. Suck on it. You should be able to generate a decent vacuum to about the same level also. Note that this is only ~2 psi either way. If the MAP is reading -5 psi all the time, ignition on, engine running or not, driving around or not, then it is severely f**ked. Also, you SHOULD NOT BE DRIVING IT WITHOUT A LOAD REFERENCE. You will break the engine. Badly.
    • Could be correct. Meter might be that far out. Compare against a known 5 ohm 1% resistor.
    • @Murray_Calavera  If I were an expert I wouldn't be in here looking for assistance.  I am extremely computer literate, have above average understanding on how things should be working and how they should tie together.  If I need to go to a professional tuner so be it, but I'd much rather learn and do things myself even if it means looking for some guidance along the way and blowing up a few engines. @GTSBoy  I was hoping it would be as simple as a large vacuum leak somewhere but I'm unable to find anything, all lines seem to be well capped or going where they need to be, and when removed there is vacuum felt on the tube.  It would be odd for the Haltech built in MAP to be faulty, the GTT tune I imported had it enabled from the start, I incorrectly assumed it was reading a signal from the stock MAP, but that doesn't exist.  After running a vacuum hose to the ECU the signal doesn't change more than 0.2 in either direction.   I'll probably upload a video of my settings tomorrow, as it stands I'm able to daily drive, but getting stuttering when giving it gas from idle, so pulling away from lights is a slow process of revving it up and feathering the clutch until its moving, then it will accelerate fine.  It sounds like I need to get to the bottom of the manifold pressure issue, but the ignition timing section is most intimidating to me and will probably let a pro do that part.  Tomorrow I'll try a different vacuum line to T off of, with any luck I selected one that was already bypassed during the DBW swap.  (edit: I went out and did it right now, the line I had chosen did appear to have no vacuum on it, it used to go to the front of the intake, I've now completely blocked that one off at the bracket that holds several vacuum lines by the firewall.  I T'd into the vacuum line that goes from that bracket to the vacuum pump at the front of the car, but no change in the MAP readings).  Using the new vacuum line that has obvious vacuum on the hose, im still only getting readings between -6.0 and -5.2.  I'm wondering why the ECU was detecting -5.3 when nothing was connected to the MAP nipple and ECU MAP selected as the source. @feartherb26  I do have +T in the works but wanted to wait until Spring to start with that swap since this is my good winter AWD vehicle.  When removing the butterfly, did it leave a bunch of holes in the manifold that you needed to plug?  I thought about removing it but assumed it would be a mess.   I notice no difference when capping the vacuum line to it or letting it do its thing.  This whole thing has convinced me to just get a forward facing manifold when the time comes though.
    • Update: tested my spark plugs that are supposed to be 5ohms with a 10% deviation and one gave me a 0 ohms reading and the rest were 3.9ohm<, so one bad and the others on their way out.
