  • Replies 7.5k
Posted Images
silver 33 with a SAU sticker in the back quater window on findon rd?? unsure on road... but nice car ... and a black or deep purple R33 GTR on south road at the of the express way looked and sounded damn fine. :) .. ohh and a blue 32 coupe coming out of a drive way on south rd in reynella.
saw "not urs" a nice r32 this afternoon. looked very clean!
That would be me. Cant remember what road we were on when we saw u, well we only saw the one white 34 so assuming its u.
Just spotted on Hindley Street a white 32 with black bonnet and gtr front bar, SAU stickers front and back. Tooted at ya but u didnt hear us altho the chick getting in your car kinda looked as us strange.
Spotted today......Blue over grey R33 main north road/GJ intersection whilst washing car, then spotted a white R33 (Nozilla???) on south road near wheel worx, and a tough ceffy pulling outta wheel worx. Spotted in town about 1/2 hour ago Flick on west terrace whilst i was getting fuel!
Spotted a silver series 2 Stagea on NE Rd heading towards town this afternoon around 3:30 :P
Doesn't belong to anyone on here (yet) - it had trade plates on - wondering which car dealer has it? Could have been driving towards synergy?
Spotted CleanGTS-t on the way to work this moring on main north rd. Those rear rims with the deep dish look great , and the front as well LOL. Does make me miss my old 33 though (white and it had 17" roh adrenalins on it ), drive way used to look hot with the 2000 WRX ,R33 s-2 and 32GTR sitting in it. Now all thats there is the GTR.(and laser)
Sold the R33 to a chick in Brahma lodge. She came into work a few months later and said her boyfriend put it into a kerb at speed and stuffed up the front end but she got it fixed .
Pulled up next to David in the laser wagon and wound down the window to say high. You probably thought who's this at first , until I said I was a fellow skyliner. LOL
Day off tomorow but have to go into work anyway and will be taking the 32GTR . Whats the bet , I want see anyone . LOL
Also saw a R34 as I came of the gawler bypass into Willaston on tuesday night. Looked very tidy and I think it was platnium in colour with a female driver. It was coming from the malalla direction.
Hope to be spooted soon :blink:
yeah mate that was me coming back from mc doyles. i also saw that cefiro with gold mesh rims pull out of wworx whilst i was driving past. where were you or what were you in? oh i also spotted a silver 32 gtr a few secs heading south before spotting the cefiro.
    • @Haggerty you still haven't answered my question.  Many things you are saying do not make sense for someone who can tune, yet I would not expect someone who cannot tune to be playing with the things in the ECU that you are.  This process would be a lot quicker to figure out if we can remove user error from the equation.
    • If as it's stalling, the fuel pressure rises, it's saying there's less vacuum in the intake manifold. This is pretty typical of an engine that is slowing down.   While typically is agree it sounds fuel related, it really sounds fuel/air mixture related. Since the whole system has been refurbished, including injectors, pump, etc, it's likely we've altered how well the system is delivering fuel. If someone before you has messed with the IACV because it needed fiddling with as the fuel system was dieing out, we need to readjust it back. Getting things back to factory spec everywhere, is what's going to help the entire system. So if it idles at 400rpm with no IACV, that needs raising. Getting factory air flow back to normal will help us get everything back in spec, and likely help chase down any other issues. Back on IACV, if the base idle (no IACV plugged in) is too far out, it's a lot harder for the ECU to control idle. The IACV duty cycle causes non linear variations in reality. When I've tuned the idle valves in the past, you need to keep it in a relatively narrow window on aftermarket ecus to stop them doing wild dances. It also means if your base idle is too low, the valve needs to open too much, and then the smallest % change ends up being a huge variation.
