think i mite have spotted Showza on payneham road this morning. Looked like his 4 door (gtr front end, and what looked like white work emotions stickin out the guards). was drivin the other way in the Y-Climb truck
  • Replies 7.5k
Posted Images
Nah, wasn't me :laugh: My car's sittin out the front of my house with no motor :)
Had Dan (sinista) behind me going from Wakefield onto Pultney St today, till he turned off at the Ale House.. Doubt you recognised me as I was in the SP23 , but I saw your silver mirrors a mile off!! (and your mug through the windscreen haha)
Haha thats ok lol was goin to look at a nitro rc car :laugh:
Silver 34 4 dour up at lofty tonite, chick driver. Said shes a member but not very active on the forums.
Also spotted us needing RAA assistance when lukes mums car wouldnt start up at lofty. Apparently all the signals from antennas etc effect some alarm/immobiliser equipment. Grrr
spotted "R32GTR" at mitre 10 in salisbury just a little while ago
Spotted twice now > :):) The line came out on a sunday because the laser was needed for family duty with my wife .(YAY :) )
The car is filfy though at the moment (damm water restrictions)
My ears are tuned to hear RB's lol . Were you in your line because I didnt hear you.(very busy day mind u).
Spotted today, a white 33 on goodwood road bout 12.15pm, stopped at the crossing. You would have seen me cos you were watching me look at ya car lol Then ya took off from the lights haha
Also tonight at 5.30pm a greyish R32 gtst at the tram line on south road heading towards anzac. Number plates were Stock looking.
Edited by GTR-32
spotted a bayside-blue looking series 1 r33 on main nth rd today, turned down the rd that goes past parafield airport, went a bit fast tho ad made a little bit of smoke and sideways motion as he was turning :D
Spotted today:
Silver R32 GTR going down south road near the tram line heading away from anzacs. Was around 7.00am this morning. Nice car mate. I was the dude walking down the medium strip if ya saw me and if your on here.
Black R34 on south road heading away from anzacs again near the tram line, was at 5.15pm tonight.
And a Red R33 every morning heading towards the city down south road, Plates are BB 600? Was at autosalon in the SAU display so ya on here.. Nice looking car :D
Edited by GTR-32
    • If as it's stalling, the fuel pressure rises, it's saying there's less vacuum in the intake manifold. This is pretty typical of an engine that is slowing down.   While typically is agree it sounds fuel related, it really sounds fuel/air mixture related. Since the whole system has been refurbished, including injectors, pump, etc, it's likely we've altered how well the system is delivering fuel. If someone before you has messed with the IACV because it needed fiddling with as the fuel system was dieing out, we need to readjust it back. Getting things back to factory spec everywhere, is what's going to help the entire system. So if it idles at 400rpm with no IACV, that needs raising. Getting factory air flow back to normal will help us get everything back in spec, and likely help chase down any other issues. Back on IACV, if the base idle (no IACV plugged in) is too far out, it's a lot harder for the ECU to control idle. The IACV duty cycle causes non linear variations in reality. When I've tuned the idle valves in the past, you need to keep it in a relatively narrow window on aftermarket ecus to stop them doing wild dances. It also means if your base idle is too low, the valve needs to open too much, and then the smallest % change ends up being a huge variation.
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
