  • Replies 7.5k
Posted Images
Followed SLY 032 @ 1.00 pm today heading north on Goody Rd, Daw Park for a short distance...........nice wheels!
Wasn't in my 34.....was in a sedan? with black windows. :blink:
Starting to really like the look of 32's!! :rofl:
Spotted a bayside blue 34 GTR on Port Rush Road today about 4pm (he was heading north, me south). Plates something to do with VSPEC I think, but DAMN it was nice. young-middle age guy driving.
spotted kisin's old 34 parked on north terrace (at one of the hotels, cant remember/dont care which) last night at about 7pm.
and today at about 3pm seeing my magna that has served me faithfully for 300,000 kays being loaded onto the back of a flatbed. dead as a doornail.
Edited by scandyflick
Carl (bezender) at seacombe / brighton road lights before i heard ya :happy:
haha, couldnt a missed u either matt... u damn near hangin all the way out ur ute waving ;)
i got a couple dirty looks from other people as i drove past u in a calm and orderly manner
Edited by bezender
spotted miss r34?? a white 34 with decals TRYING to get out of ttp on saturday.. was pretty busy there. i was in a corolla looking at you.
yeah that was me.........and it was terrible trying to get out that car park.........i never want to go through that again!
spotted a black r34 on portrush rd early this morning around 6.30 am, and then a white r34 with no wing and with a bomex kit on main north rd late this afternoon
very noice!!!!!
saw a silver 33 about 9ish tonight heading down marion rd, had a gunmetal 180 infront of it with twin cannons.
Also a silver 34 parked at the small lot of shops on south rd just after the bp, cant remember wat intersection, but it the big bp with the truckstop kinda near port rd.
spotted red 33 at the start of pt wakefield st, got a wave gave a delayed 1 back (i only jus woke up)
also spotted a rather tough looking r33 GTR on mcintyre rd not sure if it was black or dark purple(my sunnies make everything shiny n black look purple)
also spotted the xmas grinch reversed into my daily at the shop and failed to leave a note (i know its a piece of sh*t but reversing into it a 40k's is a lil disrespectful) and again a few days later smashing the window to try and get into a car that can be opened with a pair of scissors, only to check out my extensive retro cassette tape collection (go the 8track)
Edited by gzilla
spotted a gunmetal grey 32 gtr get pulled over on anzac international raceway last nite about 10pm... also spotted that same cop try to pull me over (i had a 'phone call' and had to stop while they drove past ;) FYI this works 9/10 times when the cops r following u and sussing out ur car and you dont feel like a possible defect).
also spotted a red 2 door 31 with white wheels driving like a complete fk tard turning off sth rd onto anzacs heading toward town.. i have nothing against a bit of spirited driving, but with a car full of ppl and in a densely populated area??? hope its no one from here
    • This is where I share pain with you, @Duncan. The move to change so many cooling system pieces to plastic is a killer! Plastic end tanks and a few plastic hose flanges on my car's fail after so little time.  Curious about the need for a bigger rad, is that just for long sessions in the summer or because the car generally needs more cooling?
    • So, that is it! It is a pretty expensive process with the ATF costing 50-100 per 5 litres, and a mechanic will probably charge plenty because they don't want to do it. Still, considering how dirty my fluid was at 120,000klm I think it would be worth doing more like every 80,000 to keep the trans happy, they are very expensive to replace. The job is not that hard if you have the specialist tools so you can save a bit of money and do it yourself!
    • OK, onto filling. So I don't really have any pics, but will describe the process as best I can. The USDM workshop manual also covers it from TM-285 onwards. First, make sure the drain plug (17mm) is snug. Not too tight yet because it is coming off again. Note it does have a copper washer that you could replace or anneal (heat up with a blow torch) to seal nicely. Remove the fill plug, which has an inhex (I think it was 6mm but didn't check). Then, screw in the fill fitting, making sure it has a suitable o-ring (mine came without but I think it is meant to be supplied). It is important that you only screw it in hand tight. I didn't get a good pic of it, but the fill plug leads to a tube about 70mm long inside the transmission. This sets the factory level for fluid in the trans (above the join line for the pan!) and will take about 3l to fill. You then need to connect your fluid pump to the fitting via a hose, and pump in whatever amount of fluid you removed (maybe 3 litres, in my case 7 litres). If you put in more than 3l, it will spill out when you remove the fitting, so do quickly and with a drain pan underneath. Once you have pumped in the required amount of clean ATF, you start the engine and run it for 3 minutes to let the fluid circulate. Don't run it longer and if possible check the fluid temp is under 40oC (Ecutek shows Auto Trans Fluid temp now, or you could use an infrared temp gun on the bottom of the pan). The manual stresses the bit about fluid temperature because it expands when hot an might result in an underfil. So from here, the factory manual says to do the "spill and fill" again, and I did. That is, put an oil pan under the drain plug and undo it with a 17mm spanner, then watch your expensive fluid fall back out again, you should get about 3 litres.  Then, put the drain plug back in, pump 3 litres back in through the fill plug with the fitting and pump, disconnect the fill fitting and replace the fill plug, start the car and run for another 3 minutes (making sure the temp is still under 40oC). The manual then asks for a 3rd "spill and fill" just like above. I also did that and so had put 13l in by now.  This time they want you to keep the engine running and run the transmission through R and D (I hope the wheels are still off the ground!) for a while, and allow the trans temp to get to 40oC, then engine off. Finally, back under the car and undo the fill plug to let the overfill drain out; it will stop running when fluid is at the top of the levelling tube. According to the factory, that is job done! Post that, I reconnected the fill fitting and pumped in an extra 0.5l. AMS says 1.5l overfill is safe, but I started with less to see how it goes, I will add another 1.0 litres later if I'm still not happy with the hot shifts.
    • OK, so regardless of whether you did Step 1 - Spill Step 2 - Trans pan removal Step 3 - TCM removal we are on to the clean and refill. First, have a good look at the oil pan. While you might see dirty oil and some carbony build up (I did), what you don't want to see is any metal particles on the magnets, or sparkles in the oil (thankfully not). Give it all a good clean, particularly the magnets, and put the new gasket on if you have one (or, just cross your fingers) Replacement of the Valve body (if you removed it) is the "reverse of assembly". Thread the electrical socket back up through the trans case, hold the valve body up and put in the bolts you removed, with the correct lengths in the correct locations Torque for the bolts in 8Nm only so I hope you have that torque wrench handy (it feels really loose). Plug the output speed sensor back in and clip the wiring into the 2 clips, replace the spring clip on the TCM socket and plug it back into the car loom. For the pan, the workshop manual states the following order: Again, the torque is 8Nm only.
    • One other thing to mention from my car before we reassemble and refill. Per that earlier diagram,   There should be 2x B length (40mm) and 6x C length (54mm). So I had incorrectly removed one extra bolt, which I assume was 40mm, but even so I have 4x B and 5x C.  Either, the factory made an assembly error (very unlikely), or someone had been in there before me. I vote for the latter because the TCM part number doesn't match my build date, I suspect the TCM was changed under warranty. This indeed led to much unbolting, rebolting, checking, measuring and swearing under the car.... In the end I left out 1x B bolt and put in a 54mm M6 bolt I already had to make sure it was all correct
