  • Replies 7.5k
Posted Images
Just spotted a goober in a nice black mitsi GTO being a knob. He raced up to get next to me at the lights with a beer in one hand :blush: and then proceeded to rev his car up at the lights for a drag. Not the best time of year to be doing this with double demerits and was a busy intersection. His missus was even shaking her head at him, then he booted off at the green, leaving me taking of normal. To make himself look worse when i got next to him he tooted his horn at us and turned off. I think he was pissed off at himself being embarassed :banana:
^^ was he a black man? rofl and fully sick shopping list on his car? if so that guy is an embarassment to his family lol...
When you mean shopping list, do you mean like sticker vinyls ie: Blitz etc? I think i even seen nitrous on there??
He certainly was a wally!
Edited by Leeman
wayyy to many spots to remember over the last few days. Think i waved at every single one too lol
Few i can remember...
White 33 today on Mcintyre i think it was? bout 2ish, had an SAU sticker on front window.
Black 33 with gold rims on walkeys yesterday arvo, got a wave back
white 33 at jas033's work tonite
at marion shops bout 6:30, a silver 33 turning into the carpark, red 32 with possibly drift-teks leaving the carpark and a white 32 going up the ramp that looked and sounded alot like richo's car
spotted my car's twin (well when it was stock lol) no wing, full stock body, white had a for sale sticker on the side quarter panel window, saw it south rd,
then on salisbury hwy a silver r34, looked pretty clean too.
spotted Flick's car out the front of her work around 9:30am this morning - looking hot as always!
Then spotted Tangles turning off a road down south onto another road down South at around 10am (I wasn't in the R34 - was in the family wagon with the lads on the way to play golf at Links Lady Bay - Yankalilla).
spotted a purple r33 gtr going down montacute rd.....very nice!
also had a black r33 along side me for a while down main nth rd.......until the chick driving decided to floor it.........so very uncool love :)
spotted also a gunmetal grey r32 on main nth rd
    • If you take the top half of the intake off you can unbolt the flap off the shaft and leave the shaft in there blocking the hole. Then you can remove the little vacuum canister off from under the manifold and get a spare vacuum line to run to the ECU. I can take some photos of it later. Probably best to get the vacuum source to the ECU sorted first though. Mine all worked mint with the base map from the GTT an I've pretty much let the closed loop sort the fueling and took 1 degree out of the whole timing map.
    • This IS something you also have to configure in Haltech (or at least I did in the past when going from onboard-to-ECU map sensor and an external MAP sensor in haltech land).
    • I'm hoping it's something as simple as the ECU is looking for an external MAP sensor, but he is trying to use the onboard MAP sensor.
    • You won't need to do that if your happy to learn to tune it yourself. You 100% do not need to do that. It is not part of the learning process. It's not like driving on track and 'finding the limit by stepping over the limit'. You should not ever accidently blow up an engine and you should have setup the ECU's engine protection to save you from yourself while you are learning anyway. Plenty of us have tuned their own cars, myself included. We still come here for advice/guidance/new ideas etc.  What have you been doing so far to learn how to tune?
    • Put the ECU's MAP line in your mouth. Blow as hard as you can. You should be able to see about 10 kPa, maybe 15 kPa positive pressure. Suck on it. You should be able to generate a decent vacuum to about the same level also. Note that this is only ~2 psi either way. If the MAP is reading -5 psi all the time, ignition on, engine running or not, driving around or not, then it is severely f**ked. Also, you SHOULD NOT BE DRIVING IT WITHOUT A LOAD REFERENCE. You will break the engine. Badly.
