So currently putting a list together on what mods ile be doing to my 25, have a 8g budget im working with too achieve close too 400hp and build my 32 into a drifter, will never be rego'ed again.
currently im going with
definite mods
HyperGear G3 turbo
DW300 in-tank fuel pump
740cc Deatschwerks injectors
Maybe mods
EWP
6boost midmount
Greddy manifold
But im stuck deciding if i should go with E85 or a WMI setup, both have there pros and cons, for me E85 is harder too buy as im in queensland but the power gains and and anti det will be alot more then WMI, but WMI will bring my temps down, engine will run alot cleaner and is easy to get...or run 50/50 E85 and 98ron...hummm
any advice will be appreciated,
Thanks in advance!
Edited by 51NNA
https://www.sau.com.au/forums/topic/397600-wmi-or-e85-stuck-on-a-choice/
you can easily run WMI on E85, but now your talking some serious power lol more than you will push from a G3
for a track dedicated car in a non E85 friendly area, WMI will be easier to make do with.
once E85 is easier to come by you wont be at too much of a loss to retune and on sell the WMI kit. The WMI kits are under $500 for something that will do the job.
Why is E85 hard to get for a track only car in brisbane? There's a caltex at goodna which sells it, you'd go past that on the way to QR. There's also one in ipswich itself, a few over on the bayside and one near mt gravatt.
WMI is a BC E85 or agrestic Oz [where E85 is unavailable] solution. If you have good access to E85 and never travel outside the metro area/s then use it - its cheaper and easier to set up than WMI. For all us erudites unable to take advantage of E85, WMI is the answer.
I think the question that determines which way you go is how often do you drive the car. A lot of k's will mean WMI.
I'd like to see someone try a little straight water with E85. You would spray 1/2 the volume that you would if using a WMI setup for the same power level. Around 400cc for 400kw atw.
The advantage I see is that you could run the E85 tune a lot leaner, into the 12.x:1 range. Which will help a little with fuel economy in the long run. I can't remember exactly, what he told me but Piggaz's car drinks E85 at a pretty alarming rate. Well over 10lt/minute at wide open throttle.
From what I understand about E85 tuning, rich AFR's under full load are needed to help keep detonation at bay and also to keep things from getting too hot. In this way E85 tunes more similar to pure methanol burning engines than ULP.
Im running a Microtech LT12s btw, its going to be a track car so distance isnt that much of an issue, you use around 45% more fuel when your on E85 because to get the same amount of energy from the fuel you require alot more, just like Avgas, i just dont want to have to bring 100LTs of E85 too every drift event lol
Can someone explain how you'd do the 50/50 ethanol mix, does this mean mixing fuel at home from a drum or would you have 2pumps at the servo, one for 98 and one for ethanol?
What kind of gains would you get from 50% mix if your making say 300kw with 98?
id say get 2 20lt drums and put both in your fuel tank, i wouldnt buy e85 from the pump, only the drums, i assume it would be simlar gains too straight E85 but not as much, would also require less fuel then straight E85
just go flex-fuel setup.
Ethanol content sensor
ECU with digital input (Link G4, some of the Haltechs etc)
And get some ID1000's at least, to leave you some headroom if you change your mind. Better injectors anyway.
    • For these last 7 years of ownership, I've always had to use a small scissor jack under one of the front tow hooks to raise the front just enough so my low-profile jack fits under to reach my subframe jack point. I'm beginning to get annoyed of always having to do this. Are there any lower low-profile jacks that fit under the gtr lip on a dropped car?
    • Seat of the pants assessment of the new intake: The car is way less "doughy" when hitting the loud pedal, especially off idle when stopped or in traffic, I did use a cheapo lazer thermal thingo to measure the temp around where the pod filter got its air, it was between 55 - 60°C, in saying this the car was shut off and not moving, so the OEM intake pipe was not supplying any fresh air to where the pod was when the car was at least moving A weird bonus was induction noise on the throttle in the cabin increased a bit,  I was worried that I was actually going to lose some of that induction noise I love so much, outside though, when I got the daughter to do a WOT drive by pass for me, the induction noise has increased alot when on the throttle, not quite ITB doort, but well up there I'm extremely happy with the results and have been exploring the country roads in the region  As for house mods: 1.New front fence is up and is awesome, it really upgraded how the joint looks from the street, and the added security is nice 2. Electricians have replace some interior lights, and with more lighting in the garage, a few new motion detecting lights out the front above the garage, front room, and at the front door, which I have already found heaps helpful coming and going, also now has fancy pants CCTV all round the house The only hold point for power though is the solar and batteries due to supply issues, although this will happen over the next few weeks 3. I have done a heap of landscaping out the front and I'm almost ready to do a new small retaining wall with some nice blocks to replace the brick and cemented in rocks around the raised garden beds cemented in river stone "was the fashion at the time" the house was built. I currently have a pallet of retaining wall blocks and 2 bulka bags of 20mm blue metal to replace the wood chip that is in the raised garden beds around the house 4. I now have 3 big raised garden beds for out the back to grow some vegetables, about 70cm high, 200cm long and 100cm wide 5. My 2 compost bins are already pretty full with brown, green and kitchen waste from the landscaping I'vedone so far, but they will probably take a few months to break down, so anything else that gets chopped, trimmed, and kitchen waste will just start filling the base of the raised garden beds to about 30cm before I start throwing 40cm of good compost, and stuff, for the vegetables to grow in, I'll need a few ton of compost and soil, but the local supplier can sent me bulka bags of the stuff Basically the logs, wood chips and a few strategically placed rocks for drainage, will give the beds some good organic materials down low to break down over time, and they will hold moisture during the warmer months to save the water in my big arse water tank if we don't get alot of rain So, all in all, the car and house mods are going well, and I'm really enjoying being retired, I sleep in too 0700 and slowly plod around inside until I feel like actually doing anything, and only work in the yard for as long as want, which has actually been alot over the last few weeks,  although when you look at it, it seems that not a huge amount of work has been done,  until I look at the before I started the work pics Happy days and good times indeed
    • hahaha yeah. Plan is to get side skirts and probably just rear pods. But going to do them one-by-one. I've got a set that I really like from RHDJapen, but that one isn't shipped to AU. So need to find someone who can get it for me
    • Here's an idea, answer the questions I asked you as they are trying to work out WHY the LSD will be binding up in a straight line.
