Haha if u wana be dickhead...u have a way of writing emails which cracks me up.
Those pretty stickers are good for your toolbox.
U running tomei exhaust manifolds right?
:D.
Nah mate. HKS ported me a set.
I learnt the hard way with stainless junk!
:D.
now I remember when the tomei items cracked on u. Do u mind sharing a pic of these hks manifolds, when u get the chance?
this thing is going to be off its head!!!!
Yes, I believe it will, I'm thinking when it starts up Satan will be wanting to sponsor it and any red blooded male with get a warm feeling in their pants.
I'm more partial to a startup engine sound that induces a feeling of fear... Oh crap what have I built ! Instead of one that provokes a bunch of guys to get a semi...
Fear is where its at!
So no VCAM just yet... Are you still planning on using the Mines 10mm lift cams you were talking about at the nats?
Ian. No Vcam yet but I put the Exhaust cam in that HKS and the guy that built the head recommended IF i decide to go that way later on. Actually even without Vcam Hiroyuki recommended the 264's anyway. I will be getting his 'recomended' cam settings and go from there. I'm hoping the idle will be nice and smooth, not a grumpy prick like it was with the 270's.
But fear gives me a semi
Next time your scared... don't come near me :P
Dont be near Wakie on the 19 of May then, the fear levels may drop after the first session if the engine bay isnt covered in oil.
Im loving the power of the boat ATM but the oil issues are breaking my balls, hopefully will be fixed after the new cam covers/baffles and catch can are in.
Either that or Im just going to go and buy some Drag Radials for the rear and only go in a straight line, the car has no problems doing that, stupid f**king car.
Well hopefullt this does it. You can't have any more black lines in your bay. It will look like a spiders web.
Have you got your latest graph handy? Throw it up if you could be bothered!
    • I was getting anxious with the DVLA not knowing if the paperwork is fine or not, so I rang them. No update had been given, but I  was reassured that providing the box was ticked on the V750 then the application will go through fine. I've been checking the DVLA website pretty much every day, in the hope that it would have been done. Fast forward to Monday 29th  and I was greeted with a new screen on the check, and it finally showed as Taxed and MOT'd, woohoo! The car was in desperate need of a clean, not knowing when this day was coming it was put off. As far as I was concerned I had another 3 weeks  I'm not normally one for using snow foam, but I wanted to give it another try It hasn't cleaned up too bad considering it's 21 years old and lived on a boat for a number of weeks. The personalised number plate is J2 XBK, an illegally spaced number plate would have it read J2X BK. BK could either represent  the colour black or Baker, which is my surname. I filmed the first drive, the Youtube link will be at the end. I used the same driving route I did with the 323F V6 when I had a new exhaust installed, heres a couple of photos A few more since then Youtube video can be viewed here: https://www.youtube.com/watch?v=TjkFHPzjGDw
    • Thank you, 100% the intent. New coils were due and the 17" sixers look/feel loads better than the stock wheels. The aero options are so spot on.   Thanks for the warm welcome, all!
    • 98 r34 gtt Been rocking my latest setup and car running like never before. Have put a good 200 miles on it since all the latest changes and additions. everything is dialed in and have been driving it a bunch.   However, all a sudden last weekend as soon as I pushed throttle passed 4k and the engine stumbles, (slow or fast acceleration) hesitates and doesn’t go above 4100 or so, like a misfire. Everything else seems fine. I had a “good” set of coil packs that I removed from car when I first got it when I changed them over to new coils. I swapped out current ones for those, but no change. I also changed the plugs, no change. Seems to rev over 4 when out of gear with no load just fine no “misfire”, but as soon as its in gear with a load of any kind, it “misfires” as soon as rpm drop back below 4 k it runs perfectly, smooth, starts, restarts and drives fine as long as I keep it below 4 k while in gear. All readings look fine, no CEL   Any idea as to what could all a sudden cause an issue when pushing rpms passed 4 k?
    • When you say your cams are 272/262 is that 272in and 262ex?
