Rang the guys at UE today. A new set of injectors are in the car. It hasn't been ran up under load yet so we don't know if thats the issue. Tomorrow we will know. I have a funny feeling its a valve spring. Stupid car!
I wouldn't think it's a valve spring because you say it only does it when loaded up .. A dud valve spring & it would be rooted everywhere .
At 19 psi it happens at 7000 RPM
at 26 is happens at 5000 RPM off
at half throttle we can turn it to 8500.
More pressure behind the valve forcing it open? I'm sure the ramp rates of these cams are not helping the situation haha.
I had a miss with my other gtr and the cause was a faulty coil pack (what do u expect after 20yrs of abuse). Splitfires fixed that.
However, your above post throws my theory out as it definitely sounds more mechanical. I agree with u paul but its not an educated guess.
Definately not coils. Borrowed Joey's set which did 430 ish 2 hours before hand.
Wasn't this a freshly built head with new springs etc ..
Hmm it's strange alright but I would still think if a spring was off you would still encounter problems at 8500 rpm .. But it doesn't do it at partial throttle.
Everything in the head was brand new. The springs are HKS step 2's. Maybe due to the fast closing of the valve it's just enough to cause issue with higher boost at higher RPM?
Shim the valve springs. They need more seat pressure!
What Sean said . I tried looking for the spring pressures on HKS step 2's , but can't find figures .
It would seem you may have a much too aggressive profile for the springs .
    • For once a good news  It needed to be adjusted by that one nut and it is ok  At least something was easy But thank you very much for help. But a small issue is now(gearbox) that when the car is stationary you can hear "clinking" from gearbox so some of the bearing is 100% not that happy... It goes away once you push clutch so it is 100% gearbox. Just if you know...what that bearing could be? It sounding like "spun bearing" but it is louder.
    • Yeah, that's fine**. But the numbers you came up with are just wrong. Try it for yourself. Put in any voltage from the possible range and see what result you get. You get nonsense. ** When I say "fine", I mean, it's still shit. The very simple linear formula (slope & intercept) is shit for a sensor with a non-linear response. This is the curve, from your data above. Look at the CURVE! It's only really linear between about 30 and 90 °C. And if you used only that range to define a curve, it would be great. But you would go more and more wrong as you went to higher temps. And that is why the slope & intercept found when you use 50 and 150 as the end points is so bad halfway between those points. The real curve is a long way below the linear curve which just zips straight between the end points, like this one. You could probably use the same slope and a lower intercept, to move that straight line down, and spread the error out. But you would 5-10°C off in a lot of places. You'd need to say what temperature range you really wanted to be most right - say, 100 to 130, and plop the line closest to teh real curve in that region, which would make it quite wrong down at the lower temperatures. Let me just say that HPTuners are not being realistic in only allowing for a simple linear curve.
    • I feel I should re-iterate. The above picture is the only option available in the software and the blurb from HP Tuners I quoted earlier is the only way to add data to it and that's the description they offer as to how to figure it out. The only fields available is the blank box after (Input/ ) and the box right before = Output. Those are the only numbers that can be entered.
    • No, your formula is arse backwards. Mine is totally different to yours, and is the one I said was bang on at 50 and 150. I'll put your data into Excel (actually it already is, chart it and fit a linear fit to it, aiming to make it evenly wrong across the whole span. But not now. Other things to do first.
    • God damnit. The only option I actually have in the software is the one that is screenshotted. I am glad that I at least got it right... for those two points. Would it actually change anything if I chose/used 80C and 120C as the two points instead? My brain wants to imagine the formula put into HPtuners would be the same equation, otherwise none of this makes sense to me, unless: 1) The formula you put into VCM Scanner/HPTuners is always linear 2) The two points/input pairs are only arbitrary to choose (as the documentation implies) IF the actual scaling of the sensor is linear. then 3) If the scaling is not linear, the two points you choose matter a great deal, because the formula will draw a line between those two points only.
