Yep. It has been mentioned by a few people in the know that a lot of the jap brand name valve springs do not have sufficient seat pressures when they are fitted without setting them up for intended use.
For example, a high boost/ high lift setup would need a modified seat pressure to suit, by either a correctly shimmed spring, setup to avoid coil bind.
Or a dual valve spring such as BC (brian crower) etc.
Due to Paul's fairly non standard setup, seat pressures could definately be an issue, as opposed to most people on here running bigger duration but not much lift and mild boost....
Or I could be just adding my 2cents lol...
^ lol Aggroman
He's made his mind up....that is all :)
Annnndddd 450KW :D
I asked the same thing about trigger. He said it was fine and no blips all the way past 8500RPM....
that is a very valid point - i remember once my intank pump sucked up a piece of rubber from 1 of the mounts & it sat in the inlet (had no fuel pump filter, not my doing) and symptoms were slower revs
maybe slower fuel delivery?
sounds like fuel to me Paul. Have you cleaned or replaced your in tank filter.
I had a similar problem in the gtr Marko. car would miss under load but you could feather the throttle to peak revs no problem.
The in tank filter was munted. changed it out and presto! all good.
I had the exact same problem. Under load above 4000rpm (dependant on load situation) both on road and on dyno (ramped, etc) when accelerated hard my car would have a miss and sort of hesitation. If i eased on the accelerator, the problem did not occur. We changed fuel pump, had all injectors flow tested, etc, as they are brand new, and car still hesitated (missed). I WAS running NGK platinum plugs (gapped to 0.8mm) and the car still had same symptoms (exactly like you are saying). I have super tech valves with titanium retainers, etc, 1.5mm overized valves stainless on intake and nitrite coated on exhaust. My springs are 95pounds at the seat and still car hesitating under load. Problem was found that my spark plugs were arching out under load. (Simple rule of thumb for old school mechanics - plugs up top, points down low) checked my coil packs, they were fine. Changed the plugs to v-grove and solved my issues instantly. Have also since put SplitFire coil packs and HKS plugs. I was running 12psi when this was occurring so had nothing to do with coil binding or a dud valve spring.
That's just my two cents. Hope this info helps.
If running E85 you may need to change heat range of plugs and re-gap them smaller. Give it a run on 98 and see if you have the same miss. I was having this problem on my car but only on e85. swapped to 98 and problem would dissapear. Turned out to be a cheap and easy fix after i had spent hours chasing bugs.
Tried that. Nothing has changed since the night it died. Plugs the same type (just new ones gapped to the same as what they were, coils the same, fuel the same, ecu was the same.
I'll ring tomorrow and see how they went.
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
