972FDE76-81E2-40D4-9009-FED29B987CB8-174
That was our 9th or 10th run. Called it a night. To hold 25 psi up top we need to give it 29 ish early. Cams are set to 0 - 0 still. They will have a filddle next week.
With the controller off (20ish PSI) it made 441 RWKW. I got my goal of 400RWKW @ 5000 RPM which is awsome. AHhhh let me drive it!!!!!
  • Like 2
Great results ...Now max those snails out , i wanna see 500 kw :P
They have nothing left. Thats it. If I could run more I would :(. Could fiddle with cam timing but i want that bulldog midrange!
I know 29 psi would be maxing them out , shame it drops off a little though.. Im just shit stirring .
Congrats on the awesome figures ..could still squeeze a few more with some timing , but those are killer numbers.
It should be real fun to drive ..And now i know which cams to get too :thumbsup:
Edited by ezy_09s
massive power & being low mounts would put those arguments to rest :)
great result - congrats paul
i never expected this level of power, just goes to show the results you have yielded comes down to a great setup & as u said before, all these small percentages here & there = big numbers!!!
Well done Paul. Awesome to these numbers especially so early in the revs.
What turbo actuators are you running?
Standard Garrett item's that have been tricked up by Racepace. I have backed them off to 20 PSI.
    • To back this up, I'm always looking on the outside, seeing the level, and then opening it up anyway, as I'm worried the level I've looked at, is more so a scunge line. Then you end up dipping your damn finger in it too depending on the type of tank you're looking at just to make sure I'm not going insane.   PS, Mark, polish up the none moroso one a bit and then give it a clear coat. The Moroso one looks to be way shiner (not mirror polished, just shinier) and it'll still look weird with the two different alloys beside each other. Either that, or Id probably paint them a flat black...
    • Good old Orange Park hey... 😛   f**k I miss that race track
    • lo, it was a death trap. Good times. Got any Fatz Drift Day DVDs still available?
    • Yes, overthinking. Many PS reserviors are completely opaque. Our Skyline ones, for example. Have to remove lid, peak inside, swirl the dipstick, try to remember how to read it, etc etc. Normal. Radiator overflows are often sufficiently opaque and scunged up that you can't see the true level inside anyway, and have to open and have a peak. Besides which, I replaced the (massively expensive, even back then) plastic overflow in my Alfa GTV, back in the '90s with a stainless one that I had a good fabricator make up to be dimensionally same-same, that looks remarkably similar to the Bogan's Moroso one above, and I never suffered any particular paranoia that I didn't know how much coolant was in it.
    • Looks great, but I'm always concerned that it makes it difficult to see what level the fluids are at. Am I overthinking this?
