972FDE76-81E2-40D4-9009-FED29B987CB8-174
That was our 9th or 10th run. Called it a night. To hold 25 psi up top we need to give it 29 ish early. Cams are set to 0 - 0 still. They will have a filddle next week.
With the controller off (20ish PSI) it made 441 RWKW. I got my goal of 400RWKW @ 5000 RPM which is awsome. AHhhh let me drive it!!!!!
  • Like 2
Great results ...Now max those snails out , i wanna see 500 kw :P
They have nothing left. Thats it. If I could run more I would :(. Could fiddle with cam timing but i want that bulldog midrange!
I know 29 psi would be maxing them out , shame it drops off a little though.. Im just shit stirring .
Congrats on the awesome figures ..could still squeeze a few more with some timing , but those are killer numbers.
It should be real fun to drive ..And now i know which cams to get too :thumbsup:
Edited by ezy_09s
massive power & being low mounts would put those arguments to rest :)
great result - congrats paul
i never expected this level of power, just goes to show the results you have yielded comes down to a great setup & as u said before, all these small percentages here & there = big numbers!!!
Well done Paul. Awesome to these numbers especially so early in the revs.
What turbo actuators are you running?
Standard Garrett item's that have been tricked up by Racepace. I have backed them off to 20 PSI.
    • Not sure the US can import anything other than the C34 Stagea's, but if you can and you need to to tow, DO NOT under any circumstances get an M35 Stagea. If it is just as a family car and your country/state allows it, absolutely and definitely get an M35 (3.5L if possible as it is effectively a 350Z) over a C34.
    • Punch your VIN (nm35-xxxxxx) into Amayama.com You can see everything there quite easily.
    • Thanks for that, I'll check it all out. I can always do the brakes last anyway if its a problem.  The 16's are super cool, if they do fit I'll cruise around with them for a bit.
    • Well, that's kinda the point. The calipers might interfere with the inside of the barrels 16" rims are only about 14" inside the barrels, which is ~350mm, and 334mm rotors only leave about 8mm outboard for the caliper before you get to 350, And.... that;s not gunna be enough. If the rims have a larger ID than that, you might sneak it in. I'd be putting a measuring stick inside the wheel and eyeballing the extra required for the caliper outboard of the rotor before committing to bolting it all on.
    • OK, so again it has been a bit of a break but it was around researching what had been done since I didn't have access to Neil's records and not everything is obvious without pulling stuff apart. Happily the guy who assembled the engine had kept reasonable records, so we now know the final spec is: Bottom end: Standard block and crank Ross 86.5mm forgies, 9:1 compression Spool forged rods Standard main bolts Oil pump Spool billet gears in standard housing Aeroflow extended and baffled sump Head Freshly rebuilt standard head with new 80lb valve springs Mild porting/port match Head oil feed restrictor VCT disabled Tighe 805C reground cams (255 duration, 8.93 lift)  Adjustable cam gears on inlet/exhaust Standard head bolts, gasket not confirmed but assumed MLS External 555cc Nismo injectors Z32 AFM Bosch 023 Intank fuel pump Garret 2871 (factory housings and manifold) Hypertune FFP plenum with standard throttle   Time to book in a trip to Unigroup
